GPU Clock stuck at low frequency after thermal throttling
Hey, So I was gaming using steam and my GPU was running at the clock speed of around 1300-2000 Mhz. After a while maybe 30 minutes or so it throttled down to 30 Mhz and then it went back up to 400 Mhz. After that it just stuck to 400 Mhz and It doesn’t reset and work more till I reboot. I used the Nvidia Setting’s PowerMizer to look at the clock speeds and have set the offset to 200 Mhz to see if that makes any difference. I game a lot so this is really important to me, any kind of help would be appreciated. Thanks! Below is my system info.
  Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=b0f29e7e-c258-40cc-9fb9-fef0f4148eb8 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 8478 v: 70.60 serial: <superuser required>
    part-nu: 4QM25PA#ACJ uuid: <superuser required> UEFI: Insyde v: F.29
    date: 11/10/2022
  ID-1: BAT1 charge: 7.6 Wh (100.0%) condition: 7.6/52.8 Wh (14.5%) volts: 12.5
    min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
    status: full
  Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1000 high: 1001 min/max: 800/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1001 2: 1000 3: 1000
    4: 1000 5: 1000 6: 1000 7: 1000 8: 1000 bogomips: 36812
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
    ports: active: none off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
    driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: HDMI-A-2 empty: none bus-ID: 01:00.0
    chip-ID: 10de:1c8d class-ID: 0300
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
    Integrated Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-5:5 chip-ID: 05c8:03bc class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x261mm (19.02x10.28")
    s-diag: 549mm (21.61")
  Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
    model: Acer QG221Q B serial: <filter> built: 2023 res: 1920x1080 dpi: 102
    gamma: 1.2 size: 476x267mm (18.74x10.51") diag: 546mm (21.5") ratio: 16:9
    modes: max: 1920x1080 min: 640x480
  Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: BOE Display 0x07a1
    built: 2016 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1050 driver: nvidia v: 550.78 device-ID: 10de:1c8d
    surfaces: xcb,xlib
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-3: JMTek LLC. USB PnP Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0c76:17e0 class-ID: 0300
  API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7
  Local Storage: total: 1.14 TiB used: 63.89 GiB (5.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 238.47 GiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: EDFMG1.5 temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A3T0 scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 50.38 GiB (21.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 68.0 C pch: 60.0 C mobo: N/A gpu: nvidia temp: 57 C
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB available: 15.5 GiB used: 4.49 GiB (28.9%)
  Processes: 320 Power: uptime: 1h 45m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1370 libs: 394 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.34
