After sudo pacman -Syyu , it happens this problem:
error: GPGME error: No data
core 167,1 KiB 83,5 KiB/s 00:02 [######################] 100%
extra 1879,1 KiB 917 KiB/s 00:02 [######################] 100%
community 7,5 MiB 2,51 MiB/s 00:03 [######################] 100%
multilib 171,0 KiB 353 KiB/s 00:00 [######################] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
It seems to be the same problem described here. But the solutions don’t work for me.
My inxi output:
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3166b4b0-bcde-4374-afff-6c0a82189b50 rw quiet
cryptdevice=UUID=ddb32a0b-e7ae-492b-bf8b-399dddc7c48a:luks-ddb32a0b-e7ae-492b-bf8b-399dddc7c48a
root=/dev/mapper/luks-ddb32a0b-e7ae-492b-bf8b-399dddc7c48a apparmor=1
security=apparmor
resume=/dev/mapper/luks-0ef43c26-ca99-4ad3-ab53-68b26f608a4a
udev.log_priority=3
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 3583 v: N/A
Mobo: Dell model: 0T0MC0 v: A00 serial: <superuser required> UEFI: Dell
v: 1.8.0 date: 02/12/2020
ID-1: BAT0 charge: 7.5 Wh (27.6%) condition: 27.2/42.0 Wh (64.9%) volts: 11.0
min: 11.4 model: BYD DELL FW8KR03 type: Li-ion serial: <filter>
status: discharging
RAM: total: 7.64 GiB used: 3.01 GiB (39.5%)
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 28808
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 0c45:671e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0808 built: 2018 res: 1366x768 hz: 60
dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6
speed: 64 GT/s port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:3 chip-ID: 8087:0aaa class-ID: e001
Device-1: luks-ddb32a0b-e7ae-492b-bf8b-399dddc7c48a maj-min: 254:0
type: LUKS dm: dm-0 size: 922.41 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 922.42 GiB
Device-2: luks-0ef43c26-ca99-4ad3-ab53-68b26f608a4a maj-min: 254:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: sda3 maj-min: 8:3 size: 8.8 GiB
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 197.83 GiB (21.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-75Z10T3
type: HDD rpm: 5400 serial: <filter> rev: 4514 scheme: GPT
ID-1: / raw-size: 922.41 GiB size: 906.86 GiB (98.31%)
used: 197.83 GiB (21.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ddb32a0b-e7ae-492b-bf8b-399dddc7c48a label: N/A
uuid: 3166b4b0-bcde-4374-afff-6c0a82189b50
used: 456 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: BC67-C252
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-0ef43c26-ca99-4ad3-ab53-68b26f608a4a label: swap
uuid: 6b2f5ca9-e540-4608-8713-766c07e6b4f3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Microdia Integrated_Webcam_HD type: Video
Device-2: 1-10:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.0 C pch: 36.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 270 Uptime: 1h 6m wakeups: 59 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1437 libs: 377 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.23
I tried this:
sudo rm -r /etc/pacman.d/gnupg
sudo pacman -Scc
sudo pacman-mirrors --country all --api --protocols all
sudo pacman -Syy gnupg archlinux-keyring manjaro-keyring
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
sudo pacman -Syu
And it doesn’t work.
Then I tried this:
sudo cp -f "/etc/pacman.conf" "/etc/pacman.conf.orig"
sudo sed -i 's/SigLevel.*/SigLevel = Never/' /etc/pacman.conf
sudo pacman -Syy gnupg archlinux-keyring manjaro-keyring --ignore manjaro-system
sudo mv -f "/etc/pacman.conf.orig" "/etc/pacman.conf"
sudo pacman -Syu
And it also doesn’t work.
What else could I do?
