GPGME Error No data
I can’t update my system after reinstall manjaro
Sudo pacman -Syu
Erron: GPGME Prron: No data
error: GPGME error: No data
error: GPGME error: o data
:: Sunchronizing package databases...
Core
extra
COmnunity
multilib
error: GPGHE error: No data
error: failed retrieving file 'core.dh from mirror.dkm.cz SSL certificate problem: certificate is not yet valid
error: failed retrieving file 'core.db from mirror.is.co.za : SSL certificate problem: certificate is not yet valid
error: failed retrieving file 'Core.db from nirrors.ucr.ac.cr : SSL certificate problem: certificate is not yet valid
error: failed retrieving tile extra.db from mirror.dkm.CZ
error: aI1ed Tetrievrs T2E
ertificate
a
uet valid
rom mi
.cr : SSL Certificate problem: certificate is not yet valid
ns 1ed etriPViDg ile Communitu.db' from mirror.dkm.cz : SSL Certificate problem: certificate is not yet valid
arning: tOO manu errors from mirror.dkm.cz, skipping for the remainder of this transaction
error: failed retrieving file 'community.db' from mirror.i.co.za : SSL certificate problem: certificate is not yet valid
swarning: too many errors from mirror.is.co.za, skipping for the remainder of this transaction
error: failed retrieving file 'Community.db from mirrors.ucr.ac.cr : $SL certificate problem: certificate is not yet valid
warning: too many errors from mirrors.ucr.ac.cr, skipping for the remainder of this transaction
error: GPGME errr: No data
1027
SS
B8.19 KiB/s 00:00
bncon
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
Thank you for Reply but i think i still have problems
Sudo pacman - Syyu
sudo pacman-Syyu
error: failed to synchronize all databases (no servers configured for repository)
Refresh your mirrors.
pacman-mirrors --geoip
Still the same error
This is the result
Sudo Pa nrg
rgConnection: HTTPSConnectionPool (host='repo,manjaro.org', port=443): Read timed out. (read timeout=2)
nTNG eepn mansare nsConnection: HTTPSConnectionPool (host='repo.manjaro,org porta443): Max retries exceeded with url: (Caused by SsL
rOSSLCentvericationEror([SSL CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (-ssl.c:997)"))*
MRRNING httpst/ikipedia.orgConnection: HTTPSCannectionPool (host='wikipedia,org port=443): Read timed out. read timeout=2
SMRRNING httpsi//bitbucketiorg Connection: HTTPSConnectionPopl (hạst='bitbucket.org' port=443) : Read timed out. (read timeaut=2) "
MARNING The mirror file /varlib/pacman-nirrors/status.json is missing
MRRNING Falling back to /usr/share/pacman-mirrors/mirrors.json
::INFO User generated mìrror list
INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
INFO Using default mirror file
..Australia
geoiR
:INF0 uerying mìrrors- This may take some time
Australia
: http:nirror.ventraip.net ,au/Manjaro
t tERROR Connecti on: HTTPConnectionPool (hogt=' mirror ventraip .net . au', port=80) : Max retries exceedee with urli Manjaro/stable/core/xes64rcorogr
gz (Caused by NewConnectionError(' (urllib3,connection.HTTPConnection object at 0x7fc9d2ecdd20>: Failed to establish a new connection: (Errno 101] Netwo
rk is unreachable )
: http://manjaro,melbournei tmirror.net/
:ERROR Connection: HTTPSConnectionPool(host='manjaro.melbourneitmirror.net, port=443) : Read timed out. (read timeout=2)
:INFO Writìng mìrror list
INF0 Mìrror list generated and saved to:
Lphant@phanTom *s
fetc/pacman.d/mirrorlist
Is your machine drunk?
I think so
What do you think of this
The internet is not working correctly. Do you use some kind of sketchy VPN or proxy? Did you modify your connection in anyway?
And why is this output to garbled?
The command is sudo pacman -Syyu ← Note the spaces.
Did you type all that by hand? Try this:
pacman-mirrors --geoip > ~/pacman-mirrors_output.txt
…That should print the command output to a text file in your home directory. Then copy/paste the text from that file here instead.
I’m sorry about the output because i just installed the os i don’t have something on my laptop i just take pictures of the output and make copy that why theres some Mistakes and i just connected with my wifi and sorry about my English
Sorry about that it just Mistakes in copying
I see. Which Manjaro distribution have you installed? (Your English is better than many fluent speakers on this forum :wink: )
Thank you
Cat /etc/*-release
Manjaro Linux
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=22.0
DISTRIB_CODENAME=Sikaris
DISTRIB_DESCRIPTION="Manjaro Linux"
Manjaro Linux
NAME="Manjaro Linux"
PRETTY_NAME="Manjaro Linux"
ID=manjaro
ID_LIKĚ=arch
BUILD_ID=rolling
ANSI_COLOR="32;1;24;144;200"
HOME_URL="https://manjaro.org/
DOCUMENTATION_URL="https://wiki .manjaro .org/"
SUPPORT_URL="https:/I forum . manjaro.org/"
BUG REPORT_URL="https://docs.manjaro .org/reporting-bugs/"
PRIVACY_POLICY_URL="https://manjaro.org/privacy-policy/"
LOGO=manjarolinux
For reference: Pacman Mirrors.
You might try a later installer - Yours is about 9 months old.
Manjaro 23.0 is available to download, and you could choose a specific ISO for your needs; for example, KDE Plasma, XFCE, or Gnome.
Most likely a time problem. SSL needs the correct time.
Check:
timedatectl
Enable online time update:
timedatectl set-ntp true
