Gpg: packet with unknown version 252
I’m getting the following error when installing the updates:
Package (2)             Old Version  New Version  Net Change
core/archlinux-keyring  20230225-1   20230320-1     0,00 MiB
core/manjaro-keyring    20221028-4   20230318-1     0,00 MiB
Total Installed Size:  2,31 MiB
Net Upgrade Size:      0,00 MiB
(2/2) checking keys in keyring        [----------------------------------------------------------------------------------------] 100%
(2/2) checking package integrity        [----------------------------------------------------------------------------------------] 100%
(2/2) loading package files        [----------------------------------------------------------------------------------------] 100%
(2/2) checking for file conflicts        [----------------------------------------------------------------------------------------] 100%
(2/2) checking available disk space        [----------------------------------------------------------------------------------------] 100%
(1/2) upgrading archlinux-keyring        [----------------------------------------------------------------------------------------] 100%
==> Appending keys from archlinux.gpg...
gpg: packet(14) with unknown version 252
gpg: keydb_search failed: Unknown version in packet
gpg: keydb_get_keyblock failed: Value not found
gpg: [don't know]: invalid packet (ctb=76)
gpg: /etc/pacman.d/gnupg/pubring.gpg: copy to '/etc/pacman.d/gnupg/pubring.gpg.tmp' failed: Invalid packet
gpg: error writing keyring '/etc/pacman.d/gnupg/pubring.gpg': Invalid packet
gpg: error reading '/usr/share/pacman/keyrings/archlinux.gpg': Invalid packet
gpg: no valid OpenPGP data found.
gpg: import from '/usr/share/pacman/keyrings/archlinux.gpg' failed: Invalid packet
gpg: keyring_get_keyblock: read error: Unknown version in packet
gpg: keyring_get_keyblock failed: Invalid keyring
gpg: failed to rebuild keyring cache: Invalid keyring
gpg: keydb_get_keyblock failed: Invalid keyring
gpg: validate_key_list failed
gpg: error reading key: Unknown version in packet
# Skipped long output
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
==> ERROR: Trust database could not be updated.
error: command failed to execute correctly
(2/2) upgrading manjaro-keyring        [----------------------------------------------------------------------------------------] 100%
 >>> Run `pacman-key --init` to set up your pacman keyring.
 >>> Then run `pacman-key --populate manjaro` to install the Manjaro keyring.
(1/2) Reloading system manager configuration...
(2/2) Arming ConditionNeedsUpdate...
Running the suggested commands fails as well.
Trying the solution that helped in the past here
gives a lot of errors during sudo pacman-key --refresh-keys like
gpg: error retrieving 'gostrc@gmail.com' via WKD: No data
gpg: error reading key: No data
gpg: refreshing 1 key from hkps://keyserver.ubuntu.com
gpg: key 7FB1A3800C84C0A5: 1 duplicate signature removed
gpg: key 7FB1A3800C84C0A5: "Thomas Dziedzic <gostrc@gmail.com>" 2 signatures cleaned
gpg: Total number processed: 1
gpg:     signatures cleaned: 2
gpg: depth: 0  valid:   1  signed:   5  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:   5  signed:  94  trust: 0-, 0q, 0n, 5m, 0f, 0u
gpg: depth: 2  valid:  72  signed:  27  trust: 72-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-07-12
gpg: key 539DFD48135182EF: "Jürgen Hötzel (Arch Linux Developer Key) <juergen@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-10-29 [SC] [expires: 2025-10-28]
      209A36D43CE2E87DA861FC58539DFD48135182EF
uid           [  full  ] Jürgen Hötzel (Arch Linux Developer Key) <juergen@archlinux.org>
sub   cv25519 2021-10-29 [E] [expires: 2025-10-28]
And finally fails with
sudo pacman -Sy manjaro-keyring
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
warning: manjaro-keyring-20230318-1 is up to date -- reinstalling
resolving dependencies...
Package (1)           Old Version  New Version  Net Change  Download Size
core/manjaro-keyring  20230318-1   20230318-1     0,00 MiB       0,53 MiB
Total Download Size:   0,53 MiB
Total Installed Size:  0,71 MiB
:: Retrieving packages...
 manjaro-keyring-20230318-1-any        547,7 KiB   447 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
(1/1) checking keys in keyring        [----------------------------------------------------------------------------------------] 100%
(1/1) checking package integrity        [----------------------------------------------------------------------------------------] 100%
error: manjaro-keyring: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-keyring-20230318-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] Y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Any input would be great.
This is happening on all (!) of my machines…
Run $ sudo pacman-mirrors --fasttrack 10
Then read:
@Yochanan apart from splitting my post into a new thread, do you have any input on the issue?
I’m seeing this on all (!) of my machines which is kinda worrying to be honest…
Thanks for the reply but that fails already:
$ sudo rm -r /etc/pacman.d/gnupg
$ sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
 core is up to date
 extra        1866,7 KiB  1429 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
 community        7,6 MiB  4,64 MiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
warning: gnupg-2.2.41-1 is up to date -- reinstalling
warning: archlinux-keyring-20230320-1 is up to date -- reinstalling
Package (3)             Old Version  New Version  Net Change
core/archlinux-keyring  20230320-1   20230320-1     0,00 MiB
core/gnupg              2.2.41-1     2.2.41-1       0,00 MiB
Total Installed Size:  10,88 MiB
(3/3) checking keys in keyring        [----------------------------------------------------------------------------------------] 100%
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: keyring is not writable
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
$ sudo pacman-key --init
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/AB09BA1ADA6AF5E9A353D1E73528EE31B37E3A1D.rev'
gpg: Done
==> Updating trust database...
gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
 core is up to date
 extra is up to date
:: Import PGP key FC1B547C8D8172C8, "Levente Polyak <anthraxx@archlinux.org>"? [Y/n]
:: Import PGP key 6D42BDD116E0068F, "Christian Hesse <eworm@archlinux.org>"? [Y/n]
:: Import PGP key 150C200743ED46D8, "Mark Wagie <mark@manjaro.org>"? [Y/n]
(3/3) checking package integrity        [----------------------------------------------------------------------------------------] 100%
error: gnupg: signature from "Levente Polyak <anthraxx@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gnupg-2.2.41-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: archlinux-keyring: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/archlinux-keyring-20230320-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Try to run:
$ sudo pacman-key --populate archlinux manjaro
$ sudo pacman-key --refresh-keys
You can cancel running sudo pacman-key --refresh-keys if it takes too long. Then try running the next command line.
That fails as well…
==> Appending keys from manjaro.gpg...
gpg: error reading key: No public key
==> Locally signing trusted keys in keyring...
  -> Locally signed 23 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
  -> Disabled 42 keys.
gpg: depth: 0  valid:   1  signed:  21  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  21  signed:  95  trust: 0-, 0q, 0n, 21m, 0f, 0u
gpg: next trustdb check due at 2023-07-07
gpg: key A6234074498E9CEE: "Christian Hesse <eworm@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-08-12 [SC]
      02FD1C7A934E614545849F19A6234074498E9CEE
uid           [  full  ] Christian Hesse <eworm@archlinux.org>
uid           [marginal] Christian Hesse (Arch Linux Package Signing) <arch@eworm.de>
sub   rsa2048 2011-08-12 [E]
sub   ed25519 2019-08-29 [S]
sub   cv25519 2019-08-29 [E]
gpg: key 25EA6900D9EA5EBC: "George Rawlinson <george@rawlinson.net.nz>" 1 new signature
gpg:         new signatures: 1
pub   ed25519 2016-11-03 [C]
      034D823DA2055BEE6A6BF0BB25EA6900D9EA5EBC
uid           [ unknown] George Rawlinson <george@rawlinson.net.nz>
uid           [  full  ] George Rawlinson <grawlinson@archlinux.org>
sub   ed25519 2016-11-04 [A]
sub   ed25519 2016-11-03 [S]
sub   cv25519 2016-11-04 [E]
gpg: key 07D06351CA5B31BE: "Torsten Keßler <tpkessler@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-12-07 [SC] [expires: 2023-12-07]
      04CF0CD6F6EE93AE1896F58407D06351CA5B31BE
uid           [  full  ] Torsten Keßler <tpkessler@archlinux.org>
sub   cv25519 2022-12-07 [E] [expires: 2023-12-07]
gpg: key EA4F7B321A906AD9: "Daniel M. Capella <polyzen@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2016-01-03 [SC] [expires: 2024-11-09]
      04DC3FB1445FECA813C27EFAEA4F7B321A906AD9
uid           [  full  ] Daniel M. Capella <polyzen@archlinux.org>
sub   rsa4096 2016-01-03 [E] [expires: 2024-11-09]
gpg: key D147F94364295E8C: "Carsten Haitzler <raster@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2015-06-08 [SC]
      04F7A0E31E08D3E08D39AFEBD147F94364295E8C
uid           [  full  ] Carsten Haitzler <raster@archlinux.org>
uid           [ unknown] Carsten Haitzler <raster@rasterman.com>
sub   rsa4096 2015-06-08 [E]
gpg: key EB763B4E9DB887A6: "Thore Bödecker <foxxx0@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2017-05-22 [SC]
      051EAD6A6155389D69DA02E5EB763B4E9DB887A6
uid           [  full  ] Thore Bödecker <foxxx0@archlinux.org>
sub   rsa4096 2017-05-22 [E]
gpg: WARNING: unacceptable HTTP redirect from server was cleaned up
gpg: error retrieving 'frederik.schwan@linux.com' via WKD: No data
gpg: key 9D4C5AA15426DA0A: "Frederik Schwan <frederik.schwan@linux.com>" 1 new signature
pub   ed25519 2018-10-31 [SC] [expires: 2023-12-01]
      05C7775A9E8B977407FE08E69D4C5AA15426DA0A
uid           [ unknown] Frederik Schwan <frederik.schwan@linux.com>
uid           [ unknown] Frederik Schwan <frederik.schwan@mailbox.org>
uid           [ unknown] Frederik Schwan <frederik@schw4n.de>
uid           [ unknown] Frederik Schwan <frederik@schwan.it>
uid           [ unknown] Frederik Schwan <frederik@tty42.de>
uid           [  full  ] Frederik Schwan <freswa@archlinux.org>
sub   ed25519 2020-04-18 [A] [expires: 2023-12-01]
sub   cv25519 2018-10-31 [E] [expires: 2023-12-01]
gpg: error retrieving 'alexfilgueira@cinnarch.com' via WKD: Connection timed out
gpg: error reading key: Connection timed out
gpg: key 59B3122E2FA915EC: 1 duplicate signature removed
gpg: key 59B3122E2FA915EC: "Alexandre Filgueira <alexfilgueira@cinnarch.com>" 2 signatures cleaned
gpg: key 32EAB0A976938292: "Konstantin Gizdov (Arch Linux) <kgizdov@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2019-04-12 [C] [expires: 2024-04-10]
      0A9DDABB64B993D82AD45E4F32EAB0A976938292
uid           [  full  ] Konstantin Gizdov (Arch Linux) <kgizdov@archlinux.org>
uid           [ unknown] Konstantin Gizdov <arch@kge.pw>
uid           [ unknown] Konstantin Gizdov <kgizdov@gmail.com>
uid           [ unknown] keybase.io/kgizdov (Keybase) <kgizdov@keybase.io>
sub   rsa4096 2021-04-15 [E] [expires: 2026-04-14]
sub   ed25519 2019-04-12 [A] [expires: 2024-04-10]
sub   ed25519 2019-04-12 [S] [expires: 2024-04-10]
sub   cv25519 2019-04-12 [E] [expires: 2024-04-10]
gpg: error retrieving 'stephane@archlinux.org' via WKD: No data
gpg: key EA6836E1AB441196: 1 duplicate signature removed
gpg: key EA6836E1AB441196: "Stéphane Gaudreault <stephane@archlinux.org>" 2 signatures cleaned
gpg: key 11675C743429DDEF: "Massimiliano Torromeo <mtorromeo@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2017-12-20 [SC] [expires: 2026-10-21]
      0CADAACF70F64C654E131B3111675C743429DDEF
uid           [  full  ] Massimiliano Torromeo <mtorromeo@archlinux.org>
uid           [ unknown] Massimiliano Torromeo <massimiliano.torromeo@gmail.com>
sub   ed25519 2017-12-20 [A] [expires: 2026-10-21]
sub   cv25519 2017-12-20 [E] [expires: 2026-10-21]
gpg: error retrieving 'me@vild.io' via WKD: No data
gpg: error retrieving 'arch@vild.io' via WKD: No data
gpg: error retrieving 'dan@mutate.se' via WKD: No data
gpg: error retrieving 'xwildn00bx@gmail.com' via WKD: No data
gpg: key 22E3B67B4A86FDE7: 1 duplicate signature removed
gpg: key 22E3B67B4A86FDE7: "Dan Printzell <me@vild.io>" 1 new user ID
gpg: key 22E3B67B4A86FDE7: "Dan Printzell <me@vild.io>" 2 new signatures
gpg: key 22E3B67B4A86FDE7: "Dan Printzell <me@vild.io>" 8 signatures cleaned
gpg:           new user IDs: 1
gpg:         new signatures: 2
gpg:     signatures cleaned: 8
gpg: key 3348882F6AC6A4C2: "Pierre Schmitz (Arch Linux Master Key) <pierre@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa3072 2011-11-18 [SC] [revoked: 2018-10-07]
      0E8B644079F599DFC1DDC3973348882F6AC6A4C2
uid           [ revoked] Pierre Schmitz (Arch Linux Master Key) <pierre@master-key.archlinux.org>
gpg: error retrieving 'vmlinuz386@gmail.com' via WKD: No data
gpg: error retrieving 'djgera@archlinux.org' via WKD: No data
gpg: key 5ED514A45BD5C938: 1 duplicate signature removed
gpg: key 5ED514A45BD5C938: "Gerardo Exequiel Pozzi <vmlinuz386@gmail.com>" 4 signatures cleaned
gpg:     signatures cleaned: 4
gpg: key 632C3CC0D1C9CAF6: "Balló György <bgyorgy@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2022-12-09 [SC] [expires: 2025-01-01]
      14E46FE5FD69F2E287E244DB632C3CC0D1C9CAF6
uid           [  full  ] Balló György <bgyorgy@archlinux.org>
sub   rsa4096 2022-12-09 [A] [expires: 2025-01-01]
sub   rsa4096 2022-12-09 [E] [expires: 2025-01-01]
gpg: key 14BC4F30B3B92EBA: "Giancarlo Razzolini (Arch Linux Master Key) <grazzolini@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2022-02-13 [SC] [revoked: 2022-02-13]
      159F3A43AEB246C5746C033814BC4F30B3B92EBA
uid           [ revoked] Giancarlo Razzolini (Arch Linux Master Key) <grazzolini@master-key.archlinux.org>
gpg: key F83424824B3E4B90: "Orhun Parmaksız <orhun@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2021-01-03 [SC]
      165E0FF7C48C226E1EC363A7F83424824B3E4B90
uid           [  full  ] Orhun Parmaksız <orhun@archlinux.org>
uid           [ unknown] Orhun Parmaksız <orhunparmaksiz@gmail.com>
sub   rsa4096 2021-01-03 [E]
gpg: Total number processed: 0
gpg: error retrieving 'jerome@leclan.ch' via WKD: No fingerprint
gpg: key 37E0AF1FDA48F373: "Jerome Leclanche <jerome@leclan.ch>" not changed
gpg:              unchanged: 1
pub   rsa4096 2013-10-16 [SC] [expires: 2025-01-01]
      169704C6FB490C6892C7F23C37E0AF1FDA48F373
uid           [marginal] Jerome Leclanche <jerome@leclan.ch>
uid           [  full  ] Jerome Leclanche <jleclanche@archlinux.org>
sub   rsa4096 2013-10-16 [E] [expires: 2025-01-01]
gpg: key EEEEE2EEEE2EEEEE: "Gaetan Bisson <gaetan@fenua.org>" 13 new signatures
gpg:         new signatures: 13
pub   ed25519 1998-03-24 [SCA]
      1A60DC44245D06FEF90623D6EEEEE2EEEE2EEEEE
uid           [  undef ] Gaetan Bisson <gaetan@fenua.org>
uid           [  undef ] Gaetan Bisson <bisson@gaati.org>
sub   cv25519 2017-08-27 [E]
gpg:              unchanged: 1
gpg: key 4E532176DBAD6F47: "Connor Behan <cbehan@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-10-25 [SC]
      25ACE777F62C5E5ACBF2C0474E532176DBAD6F47
uid           [  full  ] Connor Behan <cbehan@archlinux.org>
sub   cv25519 2021-10-25 [E]
gpg: error retrieving 'jakob.gruber@gmail.com' via WKD: No data
gpg: key 456C7A9B91B842AE: 1 duplicate signature removed
gpg: key 456C7A9B91B842AE: "Jakob Gruber <jakob.gruber@gmail.com>" 2 signatures cleaned
gpg: key FDC3040B92ACA748: "Robin Candau <antiz@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2023-01-25 [SC] [expires: 2026-01-24]
      262A58EC6C51F7EA395B2E2DFDC3040B92ACA748
uid           [  full  ] Robin Candau <antiz@archlinux.org>
sub   rsa4096 2023-01-25 [E] [expires: 2026-01-24]
gpg: error retrieving 'dan@master-key.archlinux.org' via WKD: No data
gpg: key A04F9397CDFD6BB0: 2 duplicate signatures removed
gpg: key A04F9397CDFD6BB0: "Dan McGee (Arch Linux Master Key) <dan@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
gpg: key 4DC95B6D7BE9892E: "David Runge (Arch Linux Master Key) <dvzrv@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-04-26 [SC]
      2AC0A42EFB0B5CBC7A0402ED4DC95B6D7BE9892E
uid           [  full  ] David Runge (Arch Linux Master Key) <dvzrv@master-key.archlinux.org>
sub   cv25519 2021-04-26 [E]
gpg: error retrieving 'massimiliano.torromeo@gmail.com' via WKD: No data
gpg: key 94DD2393DA2EE423: 1 duplicate signature removed
gpg: key 94DD2393DA2EE423: "Massimiliano Torromeo (Personal non-work identity) <massimiliano.torromeo@gmail.com>" revocation certificate added
gpg: key 94DD2393DA2EE423: "Massimiliano Torromeo (Personal non-work identity) <massimiliano.torromeo@gmail.com>" 1 new signature
gpg: key 94DD2393DA2EE423: "Massimiliano Torromeo (Personal non-work identity) <massimiliano.torromeo@gmail.com>" 2 signatures cleaned
gpg: depth: 1  valid:  21  signed:  94  trust: 0-, 0q, 0n, 21m, 0f, 0u
gpg: error retrieving 'lfleischer@lfos.de' via WKD: No data
gpg: key A91764759326B440: "Lukas Fleischer <lfleischer@lfos.de>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-10-12 [SC]
      2E36D8620221482FC45CB7F2A91764759326B440
uid           [marginal] Lukas Fleischer <lfleischer@lfos.de>
uid           [  full  ] Lukas Fleischer (Arch Linux) <lfleischer@archlinux.org>
uid           [marginal] Lukas Fleischer (calcurse) <lfleischer@calcurse.org>
sub   rsa4096 2011-10-12 [E]
gpg:              unchanged: 1
gpg: key 24E4CDB0013C2580: "Jaroslav Lichtblau <svetlemodry@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-10-23 [SC] [expires: 2024-08-17]
      38EDD1886756924E1224E49524E4CDB0013C2580
uid           [  full  ] Jaroslav Lichtblau <svetlemodry@archlinux.org>
uid           [marginal] Jaroslav Lichtblau (trusted user) <dragonlord@aur.archlinux.org>
uid           [marginal] Jaroslav Lichtblau <dragonlord@aur.archlinux.org>
sub   rsa4096 2011-10-23 [E] [expires: 2024-08-17]
gpg: error retrieving 'atsutane@freethoughts.de' via WKD: General error
gpg: error reading key: General error
gpg: error retrieving 't.toepper@gmx.de' via WKD: No data
gpg: key 39E4F17F295AFBF4: "Thorsten Töpper <atsutane@freethoughts.de>" 6 signatures cleaned
gpg:     signatures cleaned: 6
gpg: key 46F633CBB0EB4BF2: "Filipe Laíns (FFY00) <lains@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2018-04-18 [SC] [expires: 2027-04-21]
      3DCE51D60930EBA47858BA4146F633CBB0EB4BF2
uid           [  full  ] Filipe Laíns (FFY00) <lains@archlinux.org>
uid           [marginal] Filipe Laíns (FFY00) <filipe.lains@gmail.com>
uid           [marginal] Filipe Laíns (FFY00) <lains@aurorafoss.org>
uid           [ unknown] Filipe Laíns (FFY00) <lains@riseup.net>
sub   rsa4096 2019-10-13 [A] [expires: 2027-04-21]
sub   rsa4096 2022-10-18 [S] [expires: 2027-10-17]
sub   rsa4096 2018-07-27 [S] [expires: 2027-04-21]
sub   rsa4096 2018-04-18 [E] [expires: 2027-04-21]
sub   rsa4096 2018-07-27 [E] [expires: 2027-04-21]
gpg: error retrieving 'sergej@p5n.pp.ru' via WKD: No data
gpg: error retrieving 'arch@sergej.pp.ru' via WKD: No data
gpg: error retrieving 'ml@sergej.pp.ru' via WKD: No data
gpg: error retrieving 'pupykin.s@gmail.com' via WKD: No data
gpg: key 65C110C1EA433FC7: 1 duplicate signature removed
gpg: key 65C110C1EA433FC7: "Sergej Pupykin <sergej@p5n.pp.ru>" 5 signatures cleaned
gpg:     signatures cleaned: 5
gpg: key 76A5EF9054449A5C: "Pierre Schmitz <pierre@archlinux.org>" not changed
gpg: key 7F2D434B9741E8AC: "Pierre Schmitz <pierre@archlinux.de>" not changed
gpg: Total number processed: 2
gpg:              unchanged: 2
pub   ed25519 2022-10-31 [SC] [expires: 2037-10-27]
      3E80CA1A8B89F69CBA57D98A76A5EF9054449A5C
uid           [  full  ] Pierre Schmitz <pierre@archlinux.org>
uid           [ unknown] Pierre Schmitz <pierre@archlinux.de>
sub   ed25519 2022-10-31 [A] [expires: 2037-10-27]
sub   cv25519 2022-10-31 [E] [expires: 2037-10-27]
gpg: error retrieving 'danielbermond@gmail.com' via WKD: No data
gpg: key 019A7474297D8577: "Daniel Bermond <danielbermond@gmail.com>" not changed
gpg: key E85B8683EB48BC95: "Daniel Bermond <dbermond@archlinux.org>" not changed
gpg:              unchanged: 2
pub   rsa2048 2016-06-27 [SC]
      3FFA6AB7B69AAE6CCA263DDE019A7474297D8577
uid           [marginal] Daniel Bermond <danielbermond@gmail.com>
uid           [ unknown] Daniel Bermond <dbermond@archlinux.org>
sub   rsa2048 2016-06-27 [E]
gpg: error retrieving 'public@dicebot.lv' via WKD: No name
gpg: error reading key: No name
gpg: key 761FAD69BA06C6A9: 1 duplicate signature removed
gpg: key 761FAD69BA06C6A9: "Dicebot <public@dicebot.lv>" 2 signatures cleaned
gpg: error retrieving 'angvp@archlinux.org' via WKD: No data
gpg: key 42A1DB15EC133BAD: 1 duplicate signature removed
gpg: key 42A1DB15EC133BAD: "Angel Velásquez <angvp@archlinux.org>" 2 signatures cleaned
gpg: error retrieving 'muflone@vbsimple.net' via WKD: No data
gpg: key 930B82BFC2BDA011: "Fabio Castelli (Muflone) (VBSimple) <muflone@vbsimple.net>" not changed
gpg: key E642299183ED727E: "Fabio Castelli (Muflone) (Primary) <muflone@muflone.com>" not changed
gpg:              unchanged: 2
pub   rsa4096 2022-05-01 [SCE] [expires: 2023-12-18]
      42DFAFB7C03B2E4E7BBDBA69930B82BFC2BDA011
uid           [ unknown] Fabio Castelli (Muflone) (VBSimple) <muflone@vbsimple.net>
uid           [  full  ] Fabio Castelli (Muflone) (Arch Linux) <muflone@archlinux.org>
uid           [ unknown] Fabio Castelli (Muflone) (Primary) <muflone@muflone.com>
sub   rsa4096 2022-05-01 [A] [expires: 2023-12-18]
gpg: error retrieving 'ionut@master-key.archlinux.org' via WKD: No data
gpg: key 7EFD567D4C7EA887: 3 duplicate signatures removed
gpg: key 7EFD567D4C7EA887: 1 signature not checked due to a missing key
gpg: key 7EFD567D4C7EA887: "Ionut Biru (Arch Linux Master Key) <ionut@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
gpg: error retrieving 'oudomphe@phare.normalesup.org' via WKD: No data
gpg: key 206CBC892D1493D2: "Rémy Oudompheng <oudomphe@phare.normalesup.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-02-16 [SC]
      44EA62ACDBC81B6A0D1FD267206CBC892D1493D2
uid           [marginal] Rémy Oudompheng <oudomphe@phare.normalesup.org>
uid           [  full  ] Rémy Oudompheng <remy@archlinux.org>
sub   rsa4096 2011-02-16 [E]
gpg: key 3FDDD575826C5C30: "Chih-Hsuan Yen <yan12125@archlinux.org>" not changed
gpg: key 56EC201BFC794362: "Chih-Hsuan Yen <yan12125@archlinux.org>" not changed
gpg:              unchanged: 2
pub   dsa3072 2016-04-05 [SC] [revoked: 2022-12-10]
      481C4474AF1572165AE4C6AF3FDDD575826C5C30
uid           [ revoked] Chih-Hsuan Yen <yan12125@archlinux.org>
uid           [ revoked] Chih-Hsuan Yen <d06922023@ntu.edu.tw>
uid           [ revoked] Chih-Hsuan Yen <yan12125@gmail.com>
uid           [ revoked] Chih-Hsuan Yen <yan12125@macports.org>
uid           [ revoked] Chih-Hsuan Yen <yan16037741@hotmail.com.tw>
uid           [ revoked] Yen Chi Hsuan <yan12125@gmail.com>
gpg: error retrieving 'd@falconindy.com' via WKD: No name
gpg: error retrieving 'dreisner@archlinux.org' via WKD: No data
gpg: key 1EB2638FF56C0C53: 3 duplicate signatures removed
gpg: key 1EB2638FF56C0C53: 2 signatures not checked due to missing keys
gpg: key 1EB2638FF56C0C53: 2 signatures reordered
gpg: key 1EB2638FF56C0C53: "Dave Reisner <d@falconindy.com>" 4 signatures cleaned
gpg: error retrieving 'keenerd@gmail.com' via WKD: No data
gpg: key 396E3E25BAB142C1: 1 duplicate signature removed
gpg: key 396E3E25BAB142C1: "Kyle Keen <keenerd@archlinux.org>" 1 new user ID
gpg: key 396E3E25BAB142C1: "Kyle Keen <keenerd@archlinux.org>" 1 new signature
gpg: key 396E3E25BAB142C1: "Kyle Keen <keenerd@archlinux.org>" 2 signatures cleaned
gpg: error retrieving 'xyne@archlinux.ca' via WKD: General error
gpg: key 5CED81B7C2E5C0D2: 1 duplicate signature removed
gpg: key 5CED81B7C2E5C0D2: "Xyne. <xyne@archlinux.ca>" 3 signatures cleaned
gpg:     signatures cleaned: 3
gpg: key 7F2D434B9741E8AC: "Pierre Schmitz <pierre@archlinux.de>" 4 new signatures
gpg:         new signatures: 4
gpg: can't open '/etc/pacman.d/gnupg/pubring.gpg'
gpg: keydb_search(first) failed: No such file or directory
gpg: keydb_search failed: No such file or directory
gpg: error retrieving 'pierre@archlinux.de' via WKD: No such file or directory
gpg: error reading key: No such file or directory
gpg: checking the trustdb
gpg: public key of ultimately trusted key 8FC75A8A55E9C22E not found
gpg: key 76A5EF9054449A5C: public key "Pierre Schmitz <pierre@archlinux.org>" imported
gpg: key 7F2D434B9741E8AC: public key "Pierre Schmitz <pierre@archlinux.org>" imported
gpg:               imported: 2
uid           [ unknown] Pierre Schmitz <pierre@archlinux.org>
gpg: key 7F2D434B9741E8AC: 1 duplicate signature removed
gpg: key 7F2D434B9741E8AC: 4 signatures not checked due to missing keys
gpg: key 7F2D434B9741E8AC: "Pierre Schmitz <pierre@archlinux.de>" 1 new user ID
gpg: key 7F2D434B9741E8AC: "Pierre Schmitz <pierre@archlinux.de>" 1 new signature
gpg: key 7F2D434B9741E8AC: "Pierre Schmitz <pierre@archlinux.de>" 3 signatures cleaned
==> ERROR: Could not update key: 7F2D434B9741E8AC
I tried to test in my KVM, but no issue. :man_shrugging:
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/3E2A5ED4B4691CA684C62EC7F1CCE03270499482.rev'
gpg: Done
 core is up to date
 extra is up to date
Packages (3) archlinux-keyring-20230320-1  gnupg-2.2.41-1  manjaro-keyring-20230318-1
:: Proceed with installation? [Y/n] y
(3/3) checking keys in keyring        [----------------------------------------------------------------------------------------------------------] 100%
(3/3) checking package integrity        [----------------------------------------------------------------------------------------------------------] 100%
(3/3) loading package files        [----------------------------------------------------------------------------------------------------------] 100%
(3/3) checking for file conflicts        [----------------------------------------------------------------------------------------------------------] 100%
(3/3) checking available disk space        [----------------------------------------------------------------------------------------------------------] 100%
(1/3) reinstalling gnupg        [----------------------------------------------------------------------------------------------------------] 100%
(2/3) reinstalling archlinux-keyring        [----------------------------------------------------------------------------------------------------------] 100%
(3/3) reinstalling manjaro-keyring        [----------------------------------------------------------------------------------------------------------] 100%
  -> Locally signed 2 keys.
  -> Disabled 8 keys.
(1/4) Reloading system manager configuration...
(2/4) Arming ConditionNeedsUpdate...
(3/4) Refreshing PackageKit...
(4/4) Updating the info directory file...
$ sudo pacman -Syyu
 core        163,5 KiB   163 KiB/s 00:01 [----------------------------------------------------------------------------------------------------------] 100%
 extra        1863,5 KiB  1138 KiB/s 00:02 [----------------------------------------------------------------------------------------------------------] 100%
 community        7,6 MiB  2,39 MiB/s 00:03 [----------------------------------------------------------------------------------------------------------] 100%
 multilib        167,6 KiB   157 KiB/s 00:01 [----------------------------------------------------------------------------------------------------------] 100%
 there is nothing to do
Try to run $ sudo pacman -Fyy
I seriously do not understand why that did work…
I’ll check my other system once I get to it.
Big thanks man!
EDIT: Also worked on my other machines.
I think one part of the error might have been the mirror-list which after running sudo pacman-mirrors --fasttrack 10 contained at some point only one entry. After resolving that this seems to be fine now.
