Yesterday I tried to install the AUR package mullvad-browser-bin. However, it fails, due to a missing public pgp key.
==> Verifying source file signatures with gpg...
mullvad-browser-linux64-12.0.7_ALL.tar.xz ... FAILED (unknown public key E53D989A9E2D47BF)
==> ERROR: One or more PGP signatures could not be verified!
When I try to add the key in the terminal, I get this failure :
gpg --recv-keys E53D989A9E2D47BF  ✔
gpg: keyserver receive failed: No data
I think the topic has been up and around several times - did you search the forum? Of course if you didn’t know about keyserver - then the keyword is not obviouis
It could be one of the old forum - my gpg.conf has a comment - I think it is around the tihe time of the poison attempts.
###+++--- GPGConf ---+++### tor 27 jun 2019 14:09:36 CEST
# GPGConf edited this configuration file.
# It will disable options before this marked block, but it will
# never change anything below these lines.
I searched, but not with those exact keywords, and anyway I wasn’t sure what to consider ; I didn’t see the same error (“No data”) in the results and I didn’t know how it worked, if there was a logic to understand what key server to try, and I had even more general doubts.
It is not obvious what to look for - I remember I spent quite some time to locate working key servers - I like your desire to understand the background it is admirable - many just come for the easy solution.
