I try to update packages from the AUR using yay. I run yay -Syyu, it lists a bunch of software that needs to be updated, for some it says:
==> ERROR: One or more PGP-signatures couldn't be verified!
At the end of the process, I get this:
:: PGP-keys must be imported:
-> 13975A70E63C361C73AE69EF6EEB81F8981C74C7, needed by: gcc10 gcc8 gcc11 gcc9
-> CA262C6C83DE4D2FB28A332A3A6A4DB839EAA6D7, needed by: kipi-plugins libkipi
-> D81C0CB38EB725EF6691C385BB463350D6EF31EF, needed by: kipi-plugins libkipi
-> D8272EF51DA223E4D05B466989AB63D48277377A, needed by: imagemagick6
-> CB9387521E1EE0127DA804843FDBB55084CC5D84, needed by: phonon-qt4
-> F3691687D867B81B51CE07D9BBE43771487328A9, needed by: gcc10 gcc11 gcc9
-> 86CFFCA918CF3AF47147588051E8B148A9999C34, needed by: gcc10 gcc11 gcc9
-> D3A93CAD751C2AF4F8C7AD516C35B99309B5FA62, needed by: gcc10 gcc8 gcc11 gcc9
-> F23275E4BF10AFC1DF6914A6DBD2CE893E2D1C87, needed by: kipi-plugins libkipi
:: Import? [Y/n]
:: Import keys with gpg...
gpg: connecting dirmngr at '/run/user/1000/gnupg/S.dirmngr' failed: IPC "connect" call failed
gpg: Reception from keysercer failed: No Dirmngr
-> problem while importing keys
I have no idea why eg gcc8, gcc9, gcc10 and gcc11 appear there. I actually removed them running yay -R gccxx (xx= the number), and it reported a successful removal, but when I run yay -Syyu again, I get them in the list again. kipi-plugins is required by digikam, which is installed.
I ran through a number of steps (sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring, sudo pacman-key --init, sudo pacman-key --populate archlinux manjaro), provided by others who had trouble with gpg, but I guess this is simply a problem of outdated keys. Question is, why such packages are being updated without updating the key…
Maybe I am on a completely wrong track. I tried to install the keys individually with
gpg --search-keys --keyserver hkp://pool.sks-keyservers.net:80 D07BD8662C56CB291B316EB2F5675605C74E02CF
(the key is only an example), it didn’t work. I get always the same error message about dirmngr.
