I looked to pinned post and it’s awesome but not work for me ;(
I try to install dropbox by yay, console say:
:: PGP keys need importing:
-> 1C61A2656FB57B7E4DE0F4C1FC918B335044912E, required by: dropbox
==> Import? [Y/n]
:: Importing keys with gpg...
gpg: keyserver receive failed: General error
problem importing keys
By useful tips on pinned post I was looking for 1C61A2656FB57B7E4DE0F4C1FC918B335044912E and I found it inside keys.openpgp.org. I opened this page and paste this string, after that got information that it was found!
After that I use this command:
Clicking the link wil let you download the key, select your donwload folder. Open a terminal and cd to your downloads folder then type gpg --import rpm-public-key.asc
The only thing I changed was the keyserver, seems like hkp://pool.sks-keyservers.net is more reliable than keys.openpgp.org. I’m glad it worked for you!
