X11 session didn’t work either. Here are the journal logs:
~ journalctl -b-1 -p5 --no-pager ✔
Jun 26 15:51:44 jacob-defaultstring kernel: Linux version 5.18.6-1-MANJARO (builduser@fv-az39-795) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT_DYNAMIC Wed Jun 22 14:16:20 UTC 2022
Jun 26 15:51:44 jacob-defaultstring kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=93f4f5ab-ac06-4a59-9232-5c1ffbc66061 rw quiet resume=UUID=550c15ed-2b7b-44ed-bfd0-b50697230d51 udev.log_priority=3 pci=nommconf
Jun 26 15:51:44 jacob-defaultstring kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64", will be passed to user space.
Jun 26 15:51:44 jacob-defaultstring kernel: random: crng init done
Jun 26 15:51:44 jacob-defaultstring kernel: x86/cpu: SGX disabled by BIOS.
Jun 26 15:51:44 jacob-defaultstring kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jun 26 15:51:44 jacob-defaultstring kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Jun 26 15:51:44 jacob-defaultstring kernel: #3
Jun 26 15:51:44 jacob-defaultstring kernel: audit: type=2000 audit(1656273101.016:1): state=initialized audit_enabled=0 res=1
Jun 26 15:51:44 jacob-defaultstring kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS0], AE_ALREADY_EXISTS (20211217/dswload2-326)
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20211217/psobject-220)
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS3], AE_ALREADY_EXISTS (20211217/dswload2-326)
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.MODS (20211217/dspkginit-438)
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI Error: AE_ERROR, Returned by Handler for [PCI_Config] (20211217/evregion-291)
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI Error: Aborting method \_SB.PCI0.RP09.PON due to previous error (AE_ERROR) (20211217/psparse-529)
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI Error: Aborting method \_SB.PCI0.RP09.PXP._ON due to previous error (AE_ERROR) (20211217/psparse-529)
Jun 26 15:51:44 jacob-defaultstring kernel: acpi PNP0A08:00: MMCONFIG is disabled, can't access extended PCI configuration space under this bridge.
Jun 26 15:51:44 jacob-defaultstring kernel: SCSI subsystem initialized
Jun 26 15:51:44 jacob-defaultstring kernel: VFS: Disk quotas dquot_6.6.0
Jun 26 15:51:44 jacob-defaultstring kernel: Initialise system trusted keyrings
Jun 26 15:51:44 jacob-defaultstring kernel: Key type blacklist registered
Jun 26 15:51:44 jacob-defaultstring kernel: Key type asymmetric registered
Jun 26 15:51:44 jacob-defaultstring kernel: Asymmetric key parser 'x509' registered
Jun 26 15:51:44 jacob-defaultstring kernel: ACPI: thermal: [Firmware Bug]: No valid trip found
Jun 26 15:51:44 jacob-defaultstring kernel: hpet_acpi_add: no address or irqs in _CRS
Jun 26 15:51:44 jacob-defaultstring kernel: Loading compiled-in X.509 certificates
Jun 26 15:51:44 jacob-defaultstring kernel: Loaded X.509 cert 'Build time autogenerated kernel key: c8773c1d3b09f152ce0bb40682fe739753842995'
Jun 26 15:51:44 jacob-defaultstring kernel: Key type ._fscrypt registered
Jun 26 15:51:44 jacob-defaultstring kernel: Key type .fscrypt registered
Jun 26 15:51:44 jacob-defaultstring kernel: Key type fscrypt-provisioning registered
Jun 26 15:51:44 jacob-defaultstring kernel: scsi 1:0:0:0: Direct-Access ATA TS512GMTS430S TBD1 PQ: 0 ANSI: 5
Jun 26 15:51:44 jacob-defaultstring kernel: sd 1:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
Jun 26 15:51:44 jacob-defaultstring kernel: sd 1:0:0:0: [sda] Write Protect is off
Jun 26 15:51:44 jacob-defaultstring kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 26 15:51:44 jacob-defaultstring kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Jun 26 15:51:44 jacob-defaultstring kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Jun 26 15:51:44 jacob-defaultstring kernel: usb: port power management may be unreliable
Jun 26 15:51:44 jacob-defaultstring kernel: audit: type=1130 audit(1656273104.417:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:44 jacob-defaultstring kernel: audit: type=1130 audit(1656273104.530:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:44 jacob-defaultstring kernel: audit: type=1130 audit(1656273104.690:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:44 jacob-defaultstring kernel: audit: type=1130 audit(1656273104.897:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-37F1\x2d66FB comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:44 jacob-defaultstring kernel: int3472-discrete INT3472:01: INT3472 seems to have no dependents.
Jun 26 15:51:44 jacob-defaultstring kernel: int3472-discrete INT3472:02: INT3472 seems to have no dependents.
Jun 26 15:51:45 jacob-defaultstring kernel: ipu3_imgu: module is from the staging directory, the quality is unknown, you have been warned.
Jun 26 15:51:45 jacob-defaultstring kernel: audit: type=1130 audit(1656273105.010:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:45 jacob-defaultstring kernel: audit: type=1334 audit(1656273105.010:7): prog-id=12 op=LOAD
Jun 26 15:51:45 jacob-defaultstring kernel: audit: type=1127 audit(1656273105.020:8): pid=287 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:45 jacob-defaultstring kernel: audit: type=1130 audit(1656273105.023:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:45 jacob-defaultstring kernel: audit: type=1130 audit(1656273105.237:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:45 jacob-defaultstring kernel: Goodix-TS i2c-GDIX1002:00: supply AVDD28 not found, using dummy regulator
Jun 26 15:51:45 jacob-defaultstring kernel: Goodix-TS i2c-GDIX1002:00: supply VDDIO not found, using dummy regulator
Jun 26 15:51:45 jacob-defaultstring kernel: Goodix-TS i2c-GDIX1002:00: Error reading 1 bytes from 0x8140: -121
Jun 26 15:51:45 jacob-defaultstring polkitd[300]: Loading rules from directory /etc/polkit-1/rules.d
Jun 26 15:51:45 jacob-defaultstring polkitd[300]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 26 15:51:45 jacob-defaultstring kernel: Goodix-TS i2c-GDIX1002:00: I2C communication failure: -121
Jun 26 15:51:45 jacob-defaultstring polkitd[300]: Finished loading, compiling and executing 10 rules
Jun 26 15:51:45 jacob-defaultstring polkitd[300]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 26 15:51:45 jacob-defaultstring kernel: Goodix-TS: probe of i2c-GDIX1002:00 failed with error -121
Jun 26 15:51:45 jacob-defaultstring kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Jun 26 15:51:45 jacob-defaultstring kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Jun 26 15:51:46 jacob-defaultstring kernel: kauditd_printk_skb: 18 callbacks suppressed
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1130 audit(1656273106.677:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:46 jacob-defaultstring kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1100 audit(1656273106.790:30): pid=647 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_permit acct="jacob" exe="/usr/lib/gdm-session-worker" hostname=jacob-defaultstring addr=? terminal=/dev/tty1 res=success'
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1101 audit(1656273106.807:31): pid=647 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="jacob" exe="/usr/lib/gdm-session-worker" hostname=jacob-defaultstring addr=? terminal=/dev/tty1 res=success'
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1103 audit(1656273106.810:32): pid=647 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_permit acct="jacob" exe="/usr/lib/gdm-session-worker" hostname=jacob-defaultstring addr=? terminal=/dev/tty1 res=success'
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1130 audit(1656273106.853:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1006 audit(1656273106.863:34): pid=647 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1300 audit(1656273106.863:34): arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7ffddf32e630 a2=4 a3=7ffddf32e344 items=0 ppid=324 pid=647 auid=1000 uid=0 gid=1001 euid=0 suid=0 fsuid=0 egid=1001 sgid=1001 fsgid=1001 tty=(none) ses=1 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" key=(null)
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1327 audit(1656273106.863:34): proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D6175746F6C6F67696E5D
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1130 audit(1656273106.900:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:46 jacob-defaultstring kernel: audit: type=1130 audit(1656273106.907:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:46 jacob-defaultstring systemd[675]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[jacob] ruser=[<unknown>] rhost=[<unknown>]
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/auto:1: Assignment outside of section. Ignoring.
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/org.gnome.SettingsDaemon.Housekeeping.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/org.gnome.SettingsDaemon.Smartcard.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/tracker-extract.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/org.gnome.SettingsDaemon.A11yKeyboard.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/tracker-miner-fs.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/org.gnome.SettingsDaemon.Wacom.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/tracker-miner-rss.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/tracker-miner-apps.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring systemd-xdg-autostart-generator[687]: /home/jacob/.config/autostart/org.gnome.SettingsDaemon.PrintNotifications.desktop: not generating unit, error parsing Exec= line: No such file or directory
Jun 26 15:51:47 jacob-defaultstring gdm-autologin][647]: gkr-pam: couldn't unlock the login keyring.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (--) Log file renamed from "/home/jacob/.local/share/xorg/Xorg.pid-702.log" to "/home/jacob/.local/share/xorg/Xorg.0.log"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: X.Org X Server 1.21.1.3
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: X Protocol Version 11, Revision 0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Current Operating System: Linux jacob-defaultstring 5.18.6-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Jun 22 14:16:20 UTC 2022 x86_64
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=93f4f5ab-ac06-4a59-9232-5c1ffbc66061 rw quiet resume=UUID=550c15ed-2b7b-44ed-bfd0-b50697230d51 udev.log_priority=3 pci=nommconf
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Current version of pixman: 0.40.0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Before reporting problems, check http://wiki.x.org
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: to make sure that you have the latest version.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Markers: (--) probed, (**) from config file, (==) default setting,
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (++) from command line, (!!) notice, (II) informational,
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Log file: "/home/jacob/.local/share/xorg/Xorg.0.log", Time: Sun Jun 26 15:51:47 2022
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) No Layout section. Using the first Screen section.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) No screen section available. Using defaults.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) |-->Screen "Default Screen Section" (0)
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) | |-->Monitor "<default monitor>"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) No monitor specified for screen "Default Screen Section".
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Using a default monitor configuration.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Automatically adding devices
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Automatically enabling devices
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Automatically adding GPU devices
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Automatically binding GPU devices
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) The directory "/usr/share/fonts/misc" does not exist.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Entry deleted from font path.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) FontPath set to:
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: /usr/share/fonts/TTF
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) ModulePath set to "/usr/lib/xorg/modules"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) The server relies on udev to provide the list of input devices.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: If no devices become available, reconfigure udev or disable AutoAddDevices.
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Module ABI versions:
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: X.Org ANSI C Emulation: 0.4
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: X.Org Video Driver: 25.2
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: X.Org XInput driver : 24.4
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: X.Org Server Extension : 10.0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (++) using VT number 2
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) xfree86: Adding drm device (/dev/dri/card0)
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (--) PCI:*(0@0:2:0) 8086:591e:8086:2212 rev 2, Mem @ 0xde000000/16777216, 0xc0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) LoadModule: "glx"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Module glx: vendor="X.Org Foundation"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: compiled for 1.21.1.3, module version = 1.0.0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: ABI class: X.Org Server Extension, version 10.0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Matched modesetting as autoconfigured driver 0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Matched fbdev as autoconfigured driver 1
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Matched vesa as autoconfigured driver 2
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) Assigned the driver to the xf86ConfigLayout
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) LoadModule: "modesetting"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Module modesetting: vendor="X.Org Foundation"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: compiled for 1.21.1.3, module version = 1.21.1
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: Module class: X.Org Video Driver
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: ABI class: X.Org Video Driver, version 25.2
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) LoadModule: "fbdev"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) Warning, couldn't open module fbdev
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) LoadModule: "vesa"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) Warning, couldn't open module vesa
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (EE) Failed to load module "vesa" (module does not exist, 0)
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): using drv /dev/dri/card0
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Creating default Display subsection in Screen section
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: "Default Screen Section" for depth/fbbpp 24/32
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): Depth 24, (==) framebuffer bpp 32
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): RGB weight 888
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): Default visual is TrueColor
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Loading sub module "glamoregl"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) LoadModule: "glamoregl"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Module glamoregl: vendor="X.Org Foundation"
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: compiled for 1.21.1.3, module version = 1.0.1
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: ABI class: X.Org ANSI C Emulation, version 0.4
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 615 (KBL GT2)
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): glamor initialized
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): VariableRefresh: disabled
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): AsyncFlipSecondaries: disabled
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output eDP-1 has no monitor section
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output HDMI-1 has no monitor section
Jun 26 15:51:47 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output DP-1 has no monitor section
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output HDMI-2 has no monitor section
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output DP-2 has no monitor section
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output HDMI-3 has no monitor section
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID for output eDP-1
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Manufacturer: LTM Model: 3937 Serial#: 17911
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Year: 2018 Week: 14
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID Version: 1.3
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Digital Display Input
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Max Image Size [cm]: horiz.: 13 vert.: 8
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Gamma: 2.20
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): No DPMS capabilities specified
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): First detailed timing is preferred mode
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): redX: 0.625 redY: 0.340 greenX: 0.280 greenY: 0.595
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): blueX: 0.155 blueY: 0.070 whiteX: 0.283 whiteY: 0.298
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Manufacturer's mask: 0
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Supported detailed timing:
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): clock: 65.7 MHz Image Size: 160 x 90 mm
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): h_active: 720 h_sync: 770 h_sync_end 790 h_blank_end 840 h_border: 0
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): v_active: 1280 v_sync: 1288 v_sync_end 1292 v_blanking: 1304 v_border: 0
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID (in hex):
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): 00ffffffffffff00328d3739f7450000
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): 0e1c0103800d08780a0dc9a057479827
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): 12484c00000001010101010101010101
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): 010101010101ac19d078200018503214
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): 8400a05a0000001e0000000000000000
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): 00000000000000000000000000000000
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): 00000000000000000000000000000056
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Printing probed modes for output eDP-1
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "720x1280"x60.0 65.72 720 770 790 840 1280 1288 1292 1304 +hsync +vsync (78.2 kHz eP)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID for output HDMI-1
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID for output DP-1
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID for output HDMI-2
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID for output DP-2
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID for output HDMI-3
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output eDP-1 connected
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output HDMI-1 disconnected
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output DP-1 disconnected
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output HDMI-2 disconnected
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output DP-2 disconnected
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output HDMI-3 disconnected
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Using exact sizes for initial modes
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Output eDP-1 using initial mode 720x1280 +0+0
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): DPI set to (96, 96)
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Loading sub module "fb"
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) LoadModule: "fb"
Jun 26 15:51:48 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Module "fb" already built-in
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): Backing store enabled
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): Silken mouse enabled
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (==) modeset(0): DPMS enabled
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): [DRI2] Setup complete
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): [DRI2] DRI driver: iris
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): [DRI2] VDPAU driver: va_gl
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension Generic Event Extension
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension SHAPE
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension MIT-SHM
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XInputExtension
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XTEST
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension BIG-REQUESTS
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension SYNC
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XKEYBOARD
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XC-MISC
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension SECURITY
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XFIXES
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension RENDER
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension RANDR
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension COMPOSITE
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension DAMAGE
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension MIT-SCREEN-SAVER
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension DOUBLE-BUFFER
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension RECORD
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension DPMS
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension Present
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension DRI3
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension X-Resource
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XVideo
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XVideo-MotionCompensation
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension GLX
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) AIGLX: Loaded and initialized iris
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) GLX: Initialized DRI2 GL provider for screen 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XFree86-VidModeExtension
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XFree86-DGA
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension XFree86-DRI
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Initializing extension DRI2
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Damage tracking initialized
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Setting screen physical size to 190 x 338
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Power Button (/dev/input/event3)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Power Button: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Power Button: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) LoadModule: "libinput"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Module libinput: vendor="X.Org Foundation"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: compiled for 1.21.1.3, module version = 1.2.1
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: Module class: X.Org XInput Driver
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: ABI class: X.Org XInput driver, version 24.4
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'Power Button'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 30 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Power Button: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event3"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event3 - Power Button: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event3 - Power Button: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event3 - Power Button: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "xkb_layout" "us"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Video Bus (/dev/input/event14)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Video Bus: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Video Bus: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Video Bus: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'Video Bus'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 33 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Video Bus: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event14"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event14 - Video Bus: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event14 - Video Bus: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event14 - Video Bus: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input15/event14"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) No input driver specified, ignoring this device.
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) This device may have been added with another device file.
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Power Button (/dev/input/event2)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 34 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event2"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event2 - Power Button: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event2 - Power Button: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event2 - Power Button: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Sleep Button: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'Sleep Button'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 35 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Sleep Button: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event1"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event1 - Sleep Button: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event1 - Sleep Button: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event1 - Sleep Button: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Mouse for Windows (/dev/input/event5)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: Applying InputClass "evdev pointer catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: Applying InputClass "libinput pointer catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for ' Mouse for Windows'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 36 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event5"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event5 - Mouse for Windows: is tagged by udev as: Mouse
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event5 - Mouse for Windows: device is a pointer
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event5 - Mouse for Windows: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:0079:18D6.0001/input/input5/event5"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device " Mouse for Windows" (type: MOUSE, id 10)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "AccelerationScheme" "none"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: (accel) selected scheme none/0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: (accel) acceleration factor: 2.000
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: (accel) acceleration threshold: 4
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Mouse for Windows (/dev/input/mouse0)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Mouse for Windows (/dev/input/event6)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Mouse for Windows: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 37 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event6"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event6 - Mouse for Windows: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event6 - Mouse for Windows: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event6 - Mouse for Windows: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:0079:18D6.0002/input/input6/event6"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device " Mouse for Windows" (type: KEYBOARD, id 11)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HK-ZYYK-US-A1-02-00 USB KEYBOARD (/dev/input/event7)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'HK-ZYYK-US-A1-02-00 USB KEYBOARD'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 38 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event7"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event7 - HK-ZYYK-US-A1-02-00 USB KEYBOARD: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event7 - HK-ZYYK-US-A1-02-00 USB KEYBOARD: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event7 - HK-ZYYK-US-A1-02-00 USB KEYBOARD: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:258A:6A99.0003/input/input7/event7"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "HK-ZYYK-US-A1-02-00 USB KEYBOARD" (type: KEYBOARD, id 12)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control (/dev/input/event10)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 39 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event10"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event10 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event10 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event10 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:258A:6A99.0004/input/input10/event10"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control" (type: KEYBOARD, id 13)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control (/dev/input/event11)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 40 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event11"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event11 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event11 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event11 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:258A:6A99.0004/input/input11/event11"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control" (type: KEYBOARD, id 14)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse (/dev/input/event8)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: Applying InputClass "evdev pointer catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: Applying InputClass "libinput pointer catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 41 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event8"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event8 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: is tagged by udev as: Mouse
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event8 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: device is a pointer
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event8 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:258A:6A99.0004/input/input8/event8"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse" (type: MOUSE, id 15)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: (accel) selected scheme none/0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: (accel) acceleration factor: 2.000
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: (accel) acceleration threshold: 4
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse (/dev/input/mouse1)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control (/dev/input/event9)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 42 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event9"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event9 - HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event9 - HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event9 - HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:258A:6A99.0004/input/input9/event9"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control" (type: KEYBOARD, id 16)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device Intel Virtual Buttons (/dev/input/event12)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Intel Virtual Buttons: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Intel Virtual Buttons: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Intel Virtual Buttons: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'Intel Virtual Buttons'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 43 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Intel Virtual Buttons: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event12"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event12 - Intel Virtual Buttons: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event12 - Intel Virtual Buttons: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event12 - Intel Virtual Buttons: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/INT33D6:00/input/input12/event12"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "Intel Virtual Buttons" (type: KEYBOARD, id 17)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event15)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event16)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event17)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event18)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event19)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event20)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event21)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 44 paused 0
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) AT Translated Set 2 keyboard: always reports core events
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "Device" "/dev/input/event4"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event4 - AT Translated Set 2 keyboard: device removed
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
Jun 26 15:51:49 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) config/udev: Adding input device PC Speaker (/dev/input/event13)
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file org.gnome.SettingsDaemon.Housekeeping.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file org.gnome.SettingsDaemon.PrintNotifications.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file org.gnome.SettingsDaemon.Smartcard.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file org.gnome.SettingsDaemon.Wacom.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file manjaro-tiling-settings.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file tracker-miner-rss.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file org.gnome.SettingsDaemon.A11yKeyboard.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file caffeine.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file tracker-miner-fs.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file tracker-miner-apps.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-session-binary[801]: WARNING: Could not parse desktop file tracker-extract.desktop or it references a not found TryExec binary
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-daemon[693]: The Secret Service was already initialized
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-daemon[810]: discover_other_daemon: 1
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-d[693]: The Secret Service was already initialized
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-secrets.desktop[810]: discover_other_daemon: 1
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-daemon[693]: The PKCS#11 component was already initialized
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-daemon[811]: discover_other_daemon: 1
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-d[693]: The PKCS#11 component was already initialized
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-daemon[812]: discover_other_daemon: 1
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-ssh.desktop[811]: discover_other_daemon: 1
Jun 26 15:51:50 jacob-defaultstring gnome-keyring-pkcs11.desktop[812]: discover_other_daemon: 1
Jun 26 15:51:51 jacob-defaultstring gnome-shell[816]: Running GNOME Shell (using mutter 42.2) as a X11 window and compositing manager
Jun 26 15:51:51 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID vendor "LTM", prod id 14647
Jun 26 15:51:51 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Printing DDC gathered Modelines:
Jun 26 15:51:51 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "720x1280"x0.0 65.72 720 770 790 840 1280 1288 1292 1304 +hsync +vsync (78.2 kHz eP)
Jun 26 15:51:52 jacob-defaultstring kernel: kauditd_printk_skb: 11 callbacks suppressed
Jun 26 15:51:52 jacob-defaultstring kernel: audit: type=1131 audit(1656273112.403:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:52 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Allocate new frame buffer 1280x720 stride
Jun 26 15:51:53 jacob-defaultstring gnome-shell[816]: ATK Bridge is disabled but a11y has already been enabled.
Jun 26 15:51:54 jacob-defaultstring gnome-shell[816]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
Jun 26 15:51:54 jacob-defaultstring gnome-shell[816]: Will monitor session 1
Jun 26 15:51:54 jacob-defaultstring org.gnome.Shell.CalendarServer[853]: /usr/lib/gnome-shell-calendar-server: error while loading shared libraries: libecal-2.0.so.1: cannot open shared object file: No such file or directory
Jun 26 15:51:54 jacob-defaultstring kernel: audit: type=1334 audit(1656273114.677:47): prog-id=20 op=LOAD
Jun 26 15:51:54 jacob-defaultstring kernel: audit: type=1334 audit(1656273114.677:48): prog-id=21 op=LOAD
Jun 26 15:51:54 jacob-defaultstring kernel: audit: type=1130 audit(1656273114.760:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=power-profiles-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:54 jacob-defaultstring kernel: audit: type=1130 audit(1656273114.807:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:54 jacob-defaultstring kernel: audit: type=1130 audit(1656273114.820:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:54 jacob-defaultstring kernel: audit: type=1131 audit(1656273114.833:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:54 jacob-defaultstring polkitd[300]: Registered Authentication Agent for unix-session:1 (system bus name :1.21 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 26 15:51:54 jacob-defaultstring gnome-shell[816]: Telepathy is not available, chat integration will be disabled.
Jun 26 15:51:54 jacob-defaultstring geoclue[878]: Failed to connect to avahi service: Daemon not running
Jun 26 15:51:54 jacob-defaultstring kernel: audit: type=1130 audit(1656273114.867:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:54 jacob-defaultstring udisksd[904]: udisks daemon version 2.9.4 starting
Jun 26 15:51:55 jacob-defaultstring pulseaudio[868]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jun 26 15:51:55 jacob-defaultstring pulseaudio[868]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
Jun 26 15:51:55 jacob-defaultstring kernel: audit: type=1130 audit(1656273115.497:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:55 jacob-defaultstring udisksd[904]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 26 15:51:55 jacob-defaultstring kernel: audit: type=1131 audit(1656273115.620:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:51:55 jacob-defaultstring goa-daemon[934]: goa-daemon version 3.44.0 starting
Jun 26 15:51:55 jacob-defaultstring gnome-shell[816]: GameMode extension initialized
Jun 26 15:51:55 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID vendor "LTM", prod id 14647
Jun 26 15:51:55 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Printing DDC gathered Modelines:
Jun 26 15:51:55 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "720x1280"x0.0 65.72 720 770 790 840 1280 1288 1292 1304 +hsync +vsync (78.2 kHz eP)
Jun 26 15:51:56 jacob-defaultstring gnome-shell[816]: Error loading calendars: Error calling StartServiceByName for org.gnome.Shell.CalendarServer: Process org.gnome.Shell.CalendarServer exited with status 127
Jun 26 15:51:56 jacob-defaultstring udisksd[904]: Mounted /dev/mmcblk0p1 at /run/media/jacob/1 TB Micro SD on behalf of uid 1000
Jun 26 15:51:56 jacob-defaultstring gnome-session-binary[801]: Entering running state
Jun 26 15:51:57 jacob-defaultstring touchegg.desktop[1085]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Jun 26 15:51:57 jacob-defaultstring touchegg.desktop[1085]: Reconnecting in 5 seconds...
Jun 26 15:51:57 jacob-defaultstring systemd[675]: app-gnome-ciopfs-1092.scope: Failed to add PIDs to scope's control group: No such process
Jun 26 15:51:57 jacob-defaultstring systemd[675]: app-gnome-ciopfs-1092.scope: Failed with result 'resources'.
Jun 26 15:51:57 jacob-defaultstring systemd[675]: Failed to start Application launched by gnome-session-binary.
Jun 26 15:51:57 jacob-defaultstring gnome-session-binary[801]: GnomeDesktop-WARNING: Could not create transient scope for PID 1086: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1086 does not exist.
Jun 26 15:51:57 jacob-defaultstring gnome-session-binary[801]: GnomeDesktop-WARNING: Could not create transient scope for PID 1109: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1109 does not exist.
Jun 26 15:51:57 jacob-defaultstring gnome-session-binary[801]: GnomeDesktop-WARNING: Could not create transient scope for PID 1123: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1123 does not exist.
Jun 26 15:51:57 jacob-defaultstring gsd-usb-protect[1018]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Jun 26 15:51:57 jacob-defaultstring gnome-shell[816]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Jun 26 15:51:57 jacob-defaultstring gsd-media-keys[984]: Failed to grab accelerator for keybinding settings:playback-repeat
Jun 26 15:51:57 jacob-defaultstring gsd-media-keys[984]: Failed to grab accelerator for keybinding settings:rotate-video-lock
Jun 26 15:51:57 jacob-defaultstring gsd-media-keys[984]: Failed to grab accelerator for keybinding settings:hibernate
Jun 26 15:51:57 jacob-defaultstring gsd-media-keys[984]: Failed to grab accelerator for keybinding settings:playback-random
Jun 26 15:51:57 jacob-defaultstring systemd[675]: GNOME session X11 services is inactive.
Jun 26 15:51:57 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): EDID vendor "LTM", prod id 14647
Jun 26 15:51:57 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Printing DDC gathered Modelines:
Jun 26 15:51:57 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) modeset(0): Modeline "720x1280"x0.0 65.72 720 770 790 840 1280 1288 1292 1304 +hsync +vsync (78.2 kHz eP)
Jun 26 15:51:59 jacob-defaultstring gnome-shell[816]: GNOME Shell started at Sun Jun 26 2022 15:51:55 GMT-0400 (Eastern Daylight Time)
Jun 26 15:51:59 jacob-defaultstring gnome-shell[816]: Registering session with GDM
Jun 26 15:52:02 jacob-defaultstring touchegg.desktop[1085]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Jun 26 15:52:02 jacob-defaultstring touchegg.desktop[1085]: Reconnecting in 5 seconds...
Jun 26 15:52:07 jacob-defaultstring touchegg.desktop[1085]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Jun 26 15:52:07 jacob-defaultstring touchegg.desktop[1085]: Reconnecting in 5 seconds...
Jun 26 15:52:12 jacob-defaultstring touchegg.desktop[1085]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Jun 26 15:52:12 jacob-defaultstring touchegg.desktop[1085]: Reconnecting in 5 seconds...
Jun 26 15:52:14 jacob-defaultstring gnome-shell[816]: endSessionDialog: No XDG_SESSION_ID, fetched from logind: 1
Jun 26 15:52:15 jacob-defaultstring systemd-logind[302]: System is rebooting.
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "30"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event3 - Power Button: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "33"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event14 - Video Bus: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "34"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event2 - Power Button: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "35"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event1 - Sleep Button: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "36"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event5 - Mouse for Windows: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "37"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event6 - Mouse for Windows: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "38"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event7 - HK-ZYYK-US-A1-02-00 USB KEYBOARD: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "39"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event10 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "40"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event11 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "41"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event8 - HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "42"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event9 - HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "43"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event12 - Intel Virtual Buttons: device removed
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (**) Option "fd" "44"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) event4 - AT Translated Set 2 keyboard: device removed
Jun 26 15:52:15 jacob-defaultstring ibus-daemon[975]: GChildWatchSource: Exit status of a child process was requested but ECHILD was received by waitpid(). See the documentation of g_child_watch_source_new() for possible causes.
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) UnloadModule: "libinput"
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:68
Jun 26 15:52:15 jacob-defaultstring kernel: kauditd_printk_skb: 5 callbacks suppressed
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.633:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.633:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.636:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=power-profiles-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.636:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.640:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.640:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.643:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.643:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring udisksd[904]: udisks daemon version 2.9.4 exiting
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.646:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring kernel: audit: type=1131 audit(1656273135.646:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 26 15:52:15 jacob-defaultstring polkitd[300]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.21, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jun 26 15:52:15 jacob-defaultstring systemd[675]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Jun 26 15:52:15 jacob-defaultstring systemd[675]: xdg-permission-store.service: Failed with result 'exit-code'.
Jun 26 15:52:15 jacob-defaultstring pulseaudio[868]: Lost I/O connection in module "module-gsettings"
Jun 26 15:52:15 jacob-defaultstring gdm[324]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Jun 26 15:52:15 jacob-defaultstring systemd[1]: gdm.service: Main process exited, code=exited, status=1/FAILURE
Jun 26 15:52:15 jacob-defaultstring systemd[1]: gdm.service: Failed with result 'exit-code'.
Jun 26 15:52:15 jacob-defaultstring systemd[1]: gdm.service: Failed to enqueue OnFailure= job, ignoring: Unit plymouth-quit.service not found.
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:76
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:73
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:72
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:75
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:74
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:71
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:70
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:69
Jun 26 15:52:15 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:65
Jun 26 15:52:16 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) UnloadModule: "libinput"
Jun 26 15:52:16 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:66
Jun 26 15:52:16 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:78
Jun 26 15:52:16 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) systemd-logind: releasing fd for 13:67
Jun 26 15:52:16 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
Jun 26 15:52:16 jacob-defaultstring /usr/lib/gdm-x-session[702]: (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
Jun 26 15:52:16 jacob-defaultstring /usr/lib/gdm-x-session[702]: (II) Server terminated successfully (0). Closing log file.
Jun 26 15:52:16 jacob-defaultstring systemd[677]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[jacob] ruser=[<unknown>] rhost=[<unknown>]
Jun 26 15:52:16 jacob-defaultstring NetworkManager[317]: <warn> [1656273136.2370] dispatcher: (9) failed: Refusing activation, D-Bus is shutting down.
Jun 26 15:52:17 jacob-defaultstring systemd[1]: Shutting down.
Jun 26 15:52:17 jacob-defaultstring kernel: watchdog: watchdog0: watchdog did not stop!
