Governor always back to schedutil
I’m trying to set the CPU governor to performance in KDE, the problem is that it never survives reboots. always back to schedutil after i reboot
terminal :
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
schedutil
schedutil
schedutil
schedutil
edit (as root) /etc/tlp.conf
sudo nano /etc/tlp.conf
or
sudo your favorite text editor /etc/tlp.conf
save and reboot
check by running:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Additionally to what @jrichard326 said, have look at this page: Processor — TLP 1.4 documentation
Thanks alot bro
CPU_SCALING_GOVERNOR_ON_AC=powersave
CPU_SCALING_GOVERNOR_ON_BAT=powersave
i changed lines to performance & its worked
thanks bro you helped me too
i found
& change them to performance
