Recently I have noticed that even though the userid is populated on websites previously saved through Google Chrome, the passwords do not populate.
I have gone into the Browser settings to verify things are set properly, and I believe they are.
I have also verified that my UN’s and PW’s do exist in my google account. (*I can manually access them.)
If I open the Google Browser in a Windows 10 work machine, the passwords populate as expected, and as happened previously, but not on Manjaro.
I do recall on a recent (not the latest) stable update, that KDE Wallet or Gnome Keyring was coming up and bothering me on each launch of the browser to get UN’s and PW’s. It is possible that I tried to fix that and reconfigured something incorrectly somewhere, but I cannot find whatever it is.
Can someone please help me to correct this behavior, or even better, to help me get back to the previous behavior, (which I consider a default experience within the browser) ?
Thanx in advance.
PS. I attempted to use the inxi as preformated text, from the terminal, but it does nto look like it is formatted as seen on the terminal! Not sure why. Sorry!
inxi:
$ inxi --admin --verbosity=7 --filter --no-host
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=3d96d0d8-ce6c-403c-bf6a-f35f7bcfd655 rw quiet apparmor=1
security=apparmor resume=UUID=e0b067e4-e8a9-493e-a687-61168dcc472f udev.log_priority=3
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: SABERTOOTH 990FX R2.0 v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 2901 date: 05/04/2016
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech K800 serial: <filter> charge: 70% (should be ignored) rechargeable: yes
status: Discharging
Memory: RAM: total: 15.53 GiB used: 8.38 GiB (54.0%)
CPU: Info: 8-Core model: AMD FX-9370 bits: 64 type: MCP arch: Bulldozer family: 15 (21) model-id: 2 stepping: N/A
microcode: 6000852 L2 cache: 2048 KiB bogomips: 76316
Speed: 2309 MHz min/max: N/A Core speeds (MHz): 1: 2309 2: 1959 3: 3341 4: 3725 5: 3667 6: 3554 7: 3972 8: 2722
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov cmp_legacy constant_tsc cpb cpuid
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht hw_pstate
ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save
nx osvw pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse pse36 rdtscp
rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale
vmcb_clean vme vmmcall wdt xop xsave
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Pitcairn XT [Radeon HD 7870 GHz Edition] vendor: XFX Pine driver: radeon
v: kernel alternate: amdgpu bus ID: 07:00.0 chip ID: 1002:6818
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: radeon FAILED: ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 70 size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
Monitor-2: DisplayPort-1 res: 1920x1080 dpi: 70 size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.8.18-1-MANJARO LLVM 10.0.1) v: 4.5 Mesa 20.2.1 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1002:4383
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] vendor: XFX Pine
driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 1002:aab0
Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus ID: 5-2:2 chip ID: 046d:082d
serial: <filter>
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8 series driver: r8169 v: kernel
port: b000 bus ID: 0a:00.0 chip ID: 10ec:8168
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 931.51 GiB used: 439.14 GiB (47.1%)
ID-1: /dev/sda vendor: Smart Modular Tech. model: SHGS31-1000GS-2 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0Q00 scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 W rev: HL05 dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 911.48 GiB size: 896.17 GiB (98.32%) used: 439.10 GiB (49.0%) fs: ext4 dev: /dev/sda3 label: N/A
uuid: 3d96d0d8-ce6c-403c-bf6a-f35f7bcfd655
ID-2: /boot/efi raw size: 512.0 MiB size: 511.0 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1
label: N/A uuid: 493E-3CA7
ID-3: /run/timeshift/backup raw size: 911.48 GiB size: <superuser/root required> used: <superuser/root required>
fs: ext4 dev: /dev/sda3 label: N/A uuid: 3d96d0d8-ce6c-403c-bf6a-f35f7bcfd655
ID-4: /var/TestRooFolder raw size: N/A size: 8.48 TiB used: 68.11 GiB (0.8%) fs: nfs4
remote: 10.0.0.172:/TestRootFolder label: N/A uuid: N/A
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 19.53 GiB used: 38.2 MiB (0.2%) priority: -2 dev: /dev/sda2 label: N/A
uuid: e0b067e4-e8a9-493e-a687-61168dcc472f
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 2-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 4-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 5-2:2 info: Logitech HD Pro Webcam C920 type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4
rev: 2.0 speed: 480 Mb/s chip ID: 046d:082d serial: <filter>
Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 9-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 11-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 12-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Hub: 13-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Device-1: 13-4:2 info: Corsair Controller for Corsair Link type: <vendor specific> driver: cp210x interfaces: 1
rev: 1.1 speed: 12 Mb/s chip ID: 1b1c:1c00 serial: <filter>
Sensors: System Temperatures: cpu: 38.1 C mobo: N/A gpu: radeon temp: 41.0 C
Info: Processes: 346 Uptime: 20h 06m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1476 pacman: 1455 lib: 395
flatpak: 12 snap: 9 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
