Gnuplot simple draw
Hi guys,
I am trying learn gnuplot
basic gnu tutorial
# set terminal pngcairo  transparent enhanced font "arial,10" fontscale 1.0 size 600, 400
# set output 'simple.1.png'
set key fixed left top vertical Right noreverse enhanced autotitle box lt black linewidth 1.000 dashtype solid
set samples 50, 50
set title "Simple Plots"
set title  font ",20" textcolor lt -1 norotate
set xrange [ * : * ] noreverse writeback
set x2range [ * : * ] noreverse writeback
set yrange [ * : * ] noreverse writeback
set y2range [ * : * ] noreverse writeback
set zrange [ * : * ] noreverse writeback
set cbrange [ * : * ] noreverse writeback
set rrange [ * : * ] noreverse writeback
NO_ANIMATION = 1
plot [-10:10] sin(x),atan(x),cos(atan(x))
I wrote a file above commands without extension called plot
(base) [max@max-dads2n gnuplot]$ ls
plot
(base) [max@max-dads2n gnuplot]$ gnuplot plot
qt.qpa.xcb: QXcbConnection: XCB error: 5 (BadAtom), sequence: 470, resource id: 0, major code: 20 (GetProperty), minor code: 0
Then a windowsy thing flashing and disappearing in a moment.
Why running qt and giving error?
Gnuplot should have plotting interface
Have you tried veusz?
https://veusz.github.io/
Thanks @zircon34, I solved with -p parameter
