oneno
18 June 2021 00:03
1
gnumeric (1.12.50) displays the following error after attempting to launch python console from within gnumeric:
gnumeric
E Unable to open module file "/usr/local/lib/gnumeric/1.12.50/plugins/python-loader/python_loader".
E /usr/local/lib/gnumeric/1.12.50/plugins/python-loader/python_loader.so: undefined symbol: forkpty
This issue was posted as a bug here .
This is suspected to be a compilation issue:
Specifically, “undefined symbol: forkpty”. The use of forkpty is not in Gnumeric.
Someone from the distribution is going to have to look at that.
Don’t have the problem with version 1.12.46
This issue is a continuation of Gnumeric-python plugin
Looking at the output for ./configure, make, and make install, there is no symbol for “forkpty”.
oneno
19 June 2021 14:57
2
Here is a similar issue and preliminary solution.
ldd provides the following linker information on ```
$ ldd /usr/local/lib/gnumeric/1.12.50/plugins/python-loader/python_loader.so
linux-vdso.so.1 (0x00007ffe25985000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x00007fa85469c000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00007fa854567000)
libm.so.6 => /usr/lib/libm.so.6 (0x00007fa854423000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007fa854257000)
libffi.so.7 => /usr/lib/libffi.so.7 (0x00007fa85424b000)
libpcre.so.1 => /usr/lib/libpcre.so.1 (0x00007fa8541d9000)
libpthread.so.0 => /usr/lib/libpthread.so.0 (0x00007fa8541b6000)
/usr/lib64/ld-linux-x86-64.so.2 (0x00007fa854ae3000)
The undefined symbol: forkpty
is a result of python_loader.so
not being linked to /lib64/libutil.so.1
Can verify starting gnumeric like this …
$ LD_PRELOAD=/lib64/libutil.so.1 gnumeric
Can now launch python console from gnumeric.
oneno:
The gnumeric
extra repo package does not install any files there. How did you install it?
oneno
19 June 2021 15:39
4
Compiled it locally after downloading source .
Can you reproduce the issue with the repo package?
oneno
19 June 2021 15:41
6
Confirmed.
After installing gnumeric from repo, then launching gnumeric and try to launch python console, get:
$ gnumeric
E Unable to open module file "/usr/lib/gnumeric/1.12.49/plugins/python-loader/python_loader".
E /usr/lib/gnumeric/1.12.49/plugins/python-loader/python_loader.so: undefined symbol: forkpty
If launch gnumeric with
then able to launch python console.
Using the version from repo:
$ LD_PRELOAD=/lib64/libutil.so.1 gnumeric --version
gnumeric version '1.12.49'
datadir := '/usr/share/gnumeric/1.12.49'
libdir := '/usr/lib/gnumeric/1.12.49'
oneno
20 June 2021 18:23
7
For comparision with gnumeric 1.12.46 (last working version without problems)…
$ gnumeric --version
gnumeric version '1.12.46'
datadir := '/usr/share/gnumeric/1.12.46'
libdir := '/usr/lib/gnumeric/1.12.46
$ ldd /usr/lib/gnumeric/1.12.46/plugins/python-loader/python_loader.so
linux-vdso.so.1 (0x00007ffea6bdc000)
libpython2.7.so.1.0 => /usr/lib/libpython2.7.so.1.0 (0x00007f9ad77b0000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x00007f9ad7750000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00007f9ad7618000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007f9ad7448000)
libpthread.so.0 => /usr/lib/libpthread.so.0 (0x00007f9ad7420000)
libdl.so.2 => /usr/lib/libdl.so.2 (0x00007f9ad7418000)
libutil.so.1 => /usr/lib/libutil.so.1 (0x00007f9ad7410000)
libm.so.6 => /usr/lib/libm.so.6 (0x00007f9ad72c8000)
libffi.so.7 => /usr/lib/libffi.so.7 (0x00007f9ad72b8000)
libpcre.so.1 => /usr/lib/libpcre.so.1 (0x00007f9ad7240000)
/usr/lib64/ld-linux-x86-64.so.2 (0x00007f9ad7a00000)
Yes, gnumeric-1.12.47 onwards started python 3.x support
oneno
20 June 2021 18:35
8
The developers of gnumeric have identified this issue as a linking problem with python-loader plugin.
oneno
7 February 2022 05:38
9
This remains an issue with gnumeric 1.12.51:
$ gnumeric
E Unable to open module file "/usr/lib/gnumeric/1.12.51/plugins/python-loader/python_loader".
E /usr/lib/gnumeric/1.12.51/plugins/python-loader/python_loader.so: undefined symbol: forkpty
Have reported it with gnome bug .
oneno:
Add LD_PRELOAD=/usr/lib/libutil.so.1
in /etc/environment
as root. For some reason this doesn’t work if added in .profile
instead. This seems the only way to run python console right now.
oneno
8 February 2022 00:34
11
Also have to reboot and then it works.
