when I login with gnome,everything fine…
but when I login with gnome-xorg,I get error:“Oh no! something has gone wrong. A problem has occurred and the system can’t recover”
Then I have to logout and login again…and the error is again and again. I can recover from command : rm ~/.config/dconf/user
Now I have to login with gnome…I using Acer a515-56,and the system is updated(pamac update).
Anybody get the same to me? how I can fix this problem. thank you so much.
Hi, is there a specific reason why you need to log in with gnome-xorg?
example queries to find relevant info why gnome crashes after login:
Show log lines with gnome from the current booted session.
journalctl --boot | grep gnome
I need some applications of skype and obs,such as windows capture ,screen share etc. and only works under gnome-xorg.
run journalctl --boot | grep gnome ,and below:
10:02:32 gnome-session-b[758]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
10:02:32 gnome-session-b[758]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
10:02:32 gnome-session[758]: gnome-session-binary[758]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
10:02:32 gnome-session-binary[758]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
10:02:32 gnome-shell[768]: Running GNOME Shell (using mutter 44.4) as a Wayland display server
10:02:33 gnome-shell[768]: Device '/dev/dri/card0' prefers shadow buffer
10:02:33 gnome-shell[768]: Added device '/dev/dri/card0' (i915) using atomic mode setting.
10:02:33 gnome-shell[768]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
10:02:33 gnome-shell[768]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
10:02:33 gnome-shell[768]: Created gbm renderer for '/dev/dri/card0'
10:02:33 gnome-shell[768]: Boot VGA GPU /dev/dri/card0 selected as primary
10:02:33 gnome-shell[768]: Obtained a high priority EGL context
10:02:33 /usr/lib/gdm-wayland-session[757]: dbus-daemon[757]: [session uid=120 pid=757] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 gnome-shell[768]: Using public X11 display :1024, (using :1025 for managed services)
10:02:33 gnome-shell[768]: Using Wayland display name 'wayland-0'
10:02:33 gnome-shell[768]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
10:02:33 gnome-shell[768]: Will monitor session 1
10:02:33 dbus-daemon[614]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.20' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 /usr/lib/gdm-wayland-session[757]: dbus-daemon[757]: [session uid=120 pid=757] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 /usr/lib/gdm-wayland-session[757]: dbus-daemon[757]: [session uid=120 pid=757] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 dbus-daemon[614]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.20' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 dbus-daemon[614]: [system] Activating via systemd: service name='org.freedesktop.GeoClue2' unit='geoclue.service' requested by ':1.20' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 dbus-daemon[614]: [system] Activating via systemd: service name='net.hadess.PowerProfiles' unit='power-profiles-daemon.service' requested by ':1.20' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 polkitd[615]: Registered Authentication Agent for unix-session:1 (system bus name :1.20 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
10:02:33 /usr/lib/gdm-wayland-session[757]: dbus-daemon[757]: [session uid=120 pid=757] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 gnome-shell[768]: Extension appindicatorsupport@rgcjonas.gmail.com already installed in /usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com. /usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com will not be loaded
10:02:33 gnome-shell[768]: Extension apps-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/apps-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/apps-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension arcmenu@arcmenu.com already installed in /usr/share/gnome-shell/extensions/arcmenu@arcmenu.com. /usr/share/gnome-shell/extensions/arcmenu@arcmenu.com will not be loaded
10:02:33 gnome-shell[768]: Extension auto-move-windows@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/auto-move-windows@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/auto-move-windows@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension custom-accent-colors@demiskp already installed in /usr/share/gnome-shell/extensions/custom-accent-colors@demiskp. /usr/share/gnome-shell/extensions/custom-accent-colors@demiskp will not be loaded
10:02:33 gnome-shell[768]: Extension dash-to-dock@micxgx.gmail.com already installed in /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com. /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com will not be loaded
10:02:33 gnome-shell[768]: Extension dash-to-panel@jderose9.github.com already installed in /usr/share/gnome-shell/extensions/dash-to-panel@jderose9.github.com. /usr/share/gnome-shell/extensions/dash-to-panel@jderose9.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension drive-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension gnome-ui-tune@itstime.tech already installed in /usr/share/gnome-shell/extensions/gnome-ui-tune@itstime.tech. /usr/share/gnome-shell/extensions/gnome-ui-tune@itstime.tech will not be loaded
10:02:33 gnome-shell[768]: Extension gsconnect@andyholmes.github.io already installed in /usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io. /usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io will not be loaded
10:02:33 gnome-shell[768]: Extension gtk4-ding@smedius.gitlab.com already installed in /usr/share/gnome-shell/extensions/gtk4-ding@smedius.gitlab.com. /usr/share/gnome-shell/extensions/gtk4-ding@smedius.gitlab.com will not be loaded
10:02:33 gnome-shell[768]: Extension launch-new-instance@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/launch-new-instance@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/launch-new-instance@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension legacyschemeautoswitcher@joshimukul29.gmail.com already installed in /usr/share/gnome-shell/extensions/legacyschemeautoswitcher@joshimukul29.gmail.com. /usr/share/gnome-shell/extensions/legacyschemeautoswitcher@joshimukul29.gmail.com will not be loaded
10:02:33 gnome-shell[768]: Extension material-shell@papyelgringo already installed in /usr/share/gnome-shell/extensions/material-shell@papyelgringo. /usr/share/gnome-shell/extensions/material-shell@papyelgringo will not be loaded
10:02:33 gnome-shell[768]: Extension native-window-placement@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/native-window-placement@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/native-window-placement@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension pamac-updates@manjaro.org already installed in /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org. /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org will not be loaded
10:02:33 gnome-shell[768]: Extension places-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/places-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/places-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension user-theme@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension window-list@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/window-list@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/window-list@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension windowsNavigator@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/windowsNavigator@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/windowsNavigator@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension workspace-indicator@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:33 gnome-shell[768]: Extension x11gestures@joseexposito.github.io already installed in /usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io. /usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io will not be loaded
10:02:33 /usr/lib/gdm-wayland-session[757]: dbus-daemon[757]: [session uid=120 pid=757] Successfully activated service 'org.gnome.Shell.Notifications'
10:02:33 /usr/lib/gdm-wayland-session[804]: dbus-daemon[804]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 dbus-daemon[614]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service' requested by ':1.20' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:33 org.gnome.Shell.desktop[768]: Window manager warning: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/1052e73f1751c73585169586655285712100000007580000.ms”: No such file or directory
10:02:33 gnome-shell[768]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
10:02:33 NetworkManager[622]: <info> [1695866553.9932] agent-manager: agent[2017cf83a655976f,:1.20/org.gnome.Shell.NetworkAgent/120]: agent registered
10:02:34 /usr/lib/gdm-wayland-session[757]: dbus-daemon[757]: [session uid=120 pid=757] Activating service name='org.gnome.ScreenSaver' requested by ':1.12' (uid=120 pid=890 comm="/usr/lib/gsd-usb-protection")
10:02:34 /usr/lib/gdm-wayland-session[757]: dbus-daemon[757]: [session uid=120 pid=757] Successfully activated service 'org.gnome.ScreenSaver'
10:02:34 dbus-daemon[614]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.20' (uid=120 pid=768 comm="/usr/bin/gnome-shell")
10:02:34 org.gnome.Shell.desktop[1147]: The XKEYBOARD keymap compiler (xkbcomp) reports:
10:02:34 org.gnome.Shell.desktop[1147]: > Warning: Unsupported maximum keycode 708, clipping.
10:02:34 org.gnome.Shell.desktop[1147]: > X11 cannot support keycodes above 255.
10:02:34 org.gnome.Shell.desktop[1147]: Errors from xkbcomp are not fatal to the X server
10:02:34 gnome-session-binary[758]: Entering running state
10:02:34 gnome-shell[768]: Registering session with GDM
10:02:47 gnome-keyring-daemon[1320]: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
10:02:47 systemd[1304]: Created slice Slice /app/gnome-session-manager.
10:02:47 systemd[1304]: Starting GNOME Session Manager (session: gnome)...
10:02:47 gnome-session[1393]: gnome-session-binary[1393]: WARNING: Desktop file /home/pop/.config/autostart/manjaro-starter.desktop for application manjaro-starter.desktop could not be parsed or references a missing TryExec binary
10:02:47 gnome-session[1393]: gnome-session-binary[1393]: WARNING: Desktop file /home/pop/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
10:02:47 gnome-session-binary[1393]: WARNING: Desktop file /home/pop/.config/autostart/manjaro-starter.desktop for application manjaro-starter.desktop could not be parsed or references a missing TryExec binary
10:02:47 gnome-session-binary[1393]: WARNING: Desktop file /home/pop/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
10:02:47 gnome-keyring-daemon[1320]: The PKCS#11 component was already initialized
10:02:47 gnome-keyring-d[1320]: The PKCS#11 component was already initialized
10:02:47 gnome-keyring-daemon[1413]: discover_other_daemon: 1
10:02:47 gnome-keyring-pkcs11.desktop[1413]: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
10:02:47 systemd[1304]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1405.scope: Couldn't move process 1405 to requested cgroup '/user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-gnome\x2dkeyring\x2dpkcs11-1405.scope': No such process
10:02:47 systemd[1304]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1405.scope: Failed to add PIDs to scope's control group: No such process
10:02:47 systemd[1304]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1405.scope: Failed with result 'resources'.
10:02:47 systemd[1304]: Failed to start Application launched by gnome-session-binary.
10:02:47 gnome-keyring-daemon[1320]: The Secret Service was already initialized
10:02:47 gnome-keyring-daemon[1417]: discover_other_daemon: 1
10:02:47 gnome-keyring-ssh.desktop[1417]: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
10:02:47 gnome-keyring-ssh.desktop[1417]: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
10:02:47 gnome-keyring-d[1320]: The Secret Service was already initialized
10:02:47 gnome-keyring-daemon[1418]: discover_other_daemon: 1
10:02:47 gnome-keyring-secrets.desktop[1418]: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
10:02:47 gnome-keyring-secrets.desktop[1418]: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
10:02:47 systemd[1304]: Started Application launched by gnome-session-binary.
10:02:47 systemd[1304]: Started GNOME Session Manager (session: gnome).
10:02:48 systemd[1304]: org.gnome.Shell@x11.service: Skipped due to 'exec-condition'.
10:02:48 gnome-shell[1427]: Running GNOME Shell (using mutter 44.4) as a Wayland display server
10:02:48 gnome-shell[1427]: Device '/dev/dri/card0' prefers shadow buffer
10:02:48 gnome-shell[1427]: Added device '/dev/dri/card0' (i915) using atomic mode setting.
10:02:48 gnome-shell[1427]: Created gbm renderer for '/dev/dri/card0'
10:02:48 gnome-shell[1427]: Boot VGA GPU /dev/dri/card0 selected as primary
10:02:48 gnome-shell[1427]: Obtained a high priority EGL context
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.18' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 gnome-shell[1427]: Using public X11 display :0, (using :1 for managed services)
10:02:48 gnome-shell[1427]: Using Wayland display name 'wayland-0'
10:02:48 gnome-shell[1427]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
10:02:48 gnome-shell[1427]: Will monitor session 3
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating service name='org.gnome.Shell.Screencast' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.freedesktop.impl.portal.PermissionStore' unit='xdg-permission-store.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating service name='org.gnome.Shell.CalendarServer' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gnome.evolution.dataserver.Sources5' unit='evolution-source-registry.service' requested by ':1.21' (uid=1000 pid=1550 comm="/usr/lib/gnome-shell-calendar-server")
10:02:48 polkitd[615]: Registered Authentication Agent for unix-session:3 (system bus name :1.66 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
10:02:48 gnome-shell[1427]: Telepathy is not available, chat integration will be disabled.
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating service name='org.gnome.OnlineAccounts' requested by ':1.23' (uid=1000 pid=1561 comm="/usr/lib/evolution-source-registry")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.evolution.dataserver.Sources5'
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gnome.evolution.dataserver.Calendar8' unit='evolution-calendar-factory.service' requested by ':1.21' (uid=1000 pid=1550 comm="/usr/lib/gnome-shell-calendar-server")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.Shell.CalendarServer'
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating service name='org.gnome.Identity' requested by ':1.26' (uid=1000 pid=1579 comm="/usr/lib/goa-daemon")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.OnlineAccounts'
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.Identity'
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.evolution.dataserver.Calendar8'
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gnome.evolution.dataserver.AddressBook10' unit='evolution-addressbook-factory.service' requested by ':1.25' (uid=1000 pid=1590 comm="/usr/lib/evolution-calendar-factory")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.evolution.dataserver.AddressBook10'
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating service name='org.gnome.Shell.Notifications' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:48 gnome-shell[1427]: Extension user-theme@gnome-shell-extensions.gcampax.github.com already installed in /home/pop/.local/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com will not be loaded
10:02:48 gnome-shell[1427]: loading user theme: /home/pop/.themes/WhiteSur-Dark-blue/gnome-shell/gnome-shell.css
10:02:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.Shell.Notifications'
10:02:49 gnome-shell[1427]: Some code accessed the property 'SecondaryMonitorDisplay' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
10:02:49 gnome-shell[1427]: Some code accessed the property 'ThumbnailsBox' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
10:02:49 gnome-shell[1427]: [x11gestures@joseexposito.github.io] Extension enabled
10:02:49 gnome-shell[1427]: [x11gestures@joseexposito.github.io] This extension is only for X11
10:02:49 at-spi-bus-launcher[1532]: dbus-daemon[1532]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:02:49 systemd[1304]: org.gnome.SettingsDaemon.XSettings.service: Job org.gnome.SettingsDaemon.XSettings.service/start failed with result 'dependency'.
10:02:49 systemd[1304]: gnome-session-x11-services-ready.target: Job gnome-session-x11-services-ready.target/verify-active failed with result 'dependency'.
10:02:49 systemd[1304]: Reached target GNOME Session (session: gnome).
10:02:49 systemd[1304]: Started Application launched by gnome-session-binary.
10:02:49 NetworkManager[622]: <info> [1695866569.2367] agent-manager: agent[b2c6ee83713656e1,:1.66/org.gnome.Shell.NetworkAgent/1000]: agent registered
10:02:49 gnome-session-binary[1393]: Entering running state
10:02:49 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating service name='org.gnome.ScreenSaver' requested by ':1.47' (uid=1000 pid=1721 comm="/usr/lib/gsd-usb-protection")
10:02:49 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.ScreenSaver'
10:02:49 gnome-shell[1427]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
10:02:49 systemd[1304]: Reached target GNOME Wayland Session (session: gnome).
10:02:50 gnome-shell[2029]: The XKEYBOARD keymap compiler (xkbcomp) reports:
10:02:50 gnome-shell[2029]: > Warning: Unsupported maximum keycode 708, clipping.
10:02:50 gnome-shell[2029]: > X11 cannot support keycodes above 255.
10:02:50 gnome-shell[2029]: Errors from xkbcomp are not fatal to the X server
10:02:50 gnome-shell[1427]: Ignoring length property that isn't a number at line 2861, col 24
10:02:50 gnome-shell[1427]: GNOME Shell started at Thu Sep 28 2023 10:02:48 GMT+0800 (Taipei Standard Time)
10:02:50 gnome-shell[1427]: Registering session with GDM
10:02:50 gsd-housekeepin[1008]: Error releasing name org.gnome.SettingsDaemon.Housekeeping: The connection is closed
10:03:07 gnome-shell[1427]: Could not create transient scope for PID 2207: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2207 does not exist.
10:03:09 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gnome' unit='xdg-desktop-portal-gnome.service' requested by ':1.87' (uid=1000 pid=2255 comm="/usr/lib/xdg-desktop-portal")
10:03:09 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
10:03:12 gnome-keyring-daemon[1320]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
10:03:12 gnome-keyring-d[1320]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
10:03:12 gnome-shell[1427]: Error connecting to the screencast service
10:03:15 gnome-keyring-daemon[1320]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
10:03:15 gnome-keyring-d[1320]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
10:03:18 gnome-shell[1427]: updates_checker.vala:71: check updates
10:03:22 gnome-shell[1427]: updates_checker.vala:101: 0 updates found
10:03:48 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.15' (uid=1000 pid=1427 comm="/usr/bin/gnome-shell")
10:04:47 dbus-daemon[1327]: [session uid=1000 pid=1327] Failed to activate service 'org.gnome.Shell.Screencast': timed out (service_start_timeout=120000ms)
10:04:49 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating service name='org.gnome.DejaDup' requested by ':1.53' (uid=1000 pid=1806 comm="/usr/lib/deja-dup/deja-dup-monitor")
10:04:49 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.DejaDup'
10:07:50 gnome-shell[1427]: Ignoring length property that isn't a number at line 2861, col 24
10:07:53 gnome-shell[1427]: Ignoring length property that isn't a number at line 2861, col 24
10:08:03 systemd[1304]: Started Application launched by gnome-shell.
10:08:03 gnome-keyring-daemon[1320]: asked to register item /org/freedesktop/secrets/collection/login/3, but it's already registered
10:08:03 gnome-keyring-d[1320]: asked to register item /org/freedesktop/secrets/collection/login/3, but it's already registered
10:08:43 dbus-daemon[1327]: [session uid=1000 pid=1327] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.115' (uid=1000 pid=3271 comm="/usr/bin/gnome-terminal")
10:08:43 systemd[1304]: Created slice Slice /app/org.gnome.Terminal.
10:08:43 dbus-daemon[1327]: [session uid=1000 pid=1327] Successfully activated service 'org.gnome.Terminal'
10:08:43 systemd[1304]: Started VTE child process 3299 launched by gnome-terminal-server process 3279.
thank you.
Create a new user and login with the new user. Same issue?
I tried…new user with administrator,the issue still there…other user,worked fine.
I have a similar problem with Xorg login, with slight differences. Now I only use Wayland (Gnome) login with Manjaro Gnome, not Xorg.
Post on similar problem is here
Another user also had something similar that he reported on the linked thread.
I just enable Wayland in /etc/gdm/custom.conf,and reboot.
login with gnome-xorg ,the issue won’t appear again,test for about 30 minutes.
but when I open nautilus and delete files,the oh no! appear again.
Anyway,thank you so much, bearcat.
when I copy (Ctrl +C) something, and paste (ctrl+v) into gedit, the oh no! must appear.
You probably should not be logging into the Xorg session. Use the Wayland session, which is just called Gnome, I believe.
Error messages shown in the other thread say Xorg-server is crashing. Downgrading that didn’t fix the problem, so it is something else. In the meantime, Wayland works fine for me.
Thank you very much. I fix the problem of windows capture now . but share screen of skype still not luck.
So I have to use skype web to solve the issue of sharing screen . and the sound problem still there.
