GNOME Wayland partly unresponsive after lid was closed
Hi there,
Since one or two updates ago, when I had my laptop lid closed and reopen it, after logging into my account, clicking on a dock or launcher icon, or a settings item in the top right drop down menu (like “WiFi” or “Reboot”) has no effect at all. Also, applications that are already running are unresponsive. But I can still manipulate the windows.
I have ddterm on a hot key. That works lukily. And “sudo reboot now” works too, which has been my last resort when this error occured.
Thank you for any ideas on what might cause this!
  Kernel: 5.15.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=050516bb-1d30-407e-9d09-7a0656f48467 rw quiet
    cryptdevice=UUID=164273f9-500f-4b29-9c9e-3ed8759e8ff7:luks-164273f9-500f-4b29-9c9e-3ed8759e8ff7
    root=/dev/mapper/luks-164273f9-500f-4b29-9c9e-3ed8759e8ff7 apparmor=1
  Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Laptop System: LENOVO product: 20UES17D00 v: ThinkPad T14 Gen 1
  Mobo: LENOVO model: 20UES17D00 v: SDK0J40697 WIN
    serial: <superuser required> UEFI: LENOVO v: R1BET71W(1.40 )
    date: 04/05/2022
  ID-1: BAT0 charge: 25.2 Wh (48.9%) condition: 51.5/50.5 Wh (101.9%)
    volts: 11.5 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
    status: discharging cycles: 212
  RAM: total: 30.59 GiB used: 4.56 GiB (14.9%)
  RAM Report:
  Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1402 high: 1475 min/max: 1400/1700 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1475
    3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1395 11: 1397
    12: 1394 13: 1399 14: 1410 15: 1398 16: 1397 bogomips: 54317
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1
    process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0
    chip-ID: 1002:1636 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 2-2:2 chip-ID: 04f2:b6d0 class-ID: fe01 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
    compositor: gnome-shell driver: X: loaded: amdgpu
    unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
    display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x573d built: 2018 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Message: Wayland GBM/EGL data currently not available.
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.48-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 16.0 running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: down mac: <filter>
  IF-ID-1: br-94831ad9f0f3 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1 all]
  IF-ID-2: docker0 state: down mac: <filter>
  Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1 all]
  IF-ID-3: veth6b29924 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-4: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: luks-164273f9-500f-4b29-9c9e-3ed8759e8ff7 maj-min: 254:0
    type: LUKS dm: dm-0 size: 796.01 GiB
  Components:
  p-1: nvme0n1p4 maj-min: 259:4 size: 796.02 GiB
  Local Storage: total: 953.87 GiB used: 499.11 GiB (52.3%)
    model: PC SN730 SDBQNTY-1T00-1001 size: 953.87 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 11170101 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 796.01 GiB size: 782.45 GiB (98.30%)
    used: 499.08 GiB (63.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-164273f9-500f-4b29-9c9e-3ed8759e8ff7 label: N/A
    uuid: 050516bb-1d30-407e-9d09-7a0656f48467
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 31.6 MiB (12.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: 0A3D-CB6F
  ID-1: swap-1 type: file size: 64 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 156.61 GiB fs: bitlocker
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 1000 MiB fs: ntfs
    label: WinRE_DRV uuid: A4FC4150FC411E44
  Hub-1: 1-0:1 info: Full speed or root hub ports: 1 rev: 2.0 speed: 480 Mb/s
  Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 2-2:2 info: Chicony Integrated Camera type: Video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-3: 3-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-4: 4-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 5-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-6: 6-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 6-3:2 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Hub-7: 7-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Fan Speeds (RPM): fan-1: 0
  Processes: 398 Uptime: 1h 42m wakeups: 1 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
  Packages: 2098 pacman: 2036 lib: 435 flatpak: 62 Shell: fish v: 3.4.1
  running-in: gjs inxi: 3.3.19
