Hi, I’m trying to install gnome-tweaks. I tried using sudo pacman install gnome-tweaks and it installed the 1.13 MiB file. But when I ran the gnome-tweaks command, this pops up:
WARNING : Error getting shell mode
CRITICAL: Error getting shell version
WARNING : Shell not installed or running
WARNING : Shell not running
NoneType: None
File "/usr/lib/python3.8/site-packages/gtweak/app.py", line 29, in do_activate
self.win = Window(self, model)
File "/usr/lib/python3.8/site-packages/gtweak/tweakview.py", line 58, in __init__
self._model.load_tweaks(self)
File "/usr/lib/python3.8/site-packages/gtweak/tweakmodel.py", line 107, in load_tweaks
mods = __import__("gtweak.tweaks", globals(), locals(), tweak_files, 0)
File "/usr/lib/python3.8/site-packages/gtweak/tweaks/tweak_group_workspaces.py", line 170, in <module>
sw = StaticWorkspaceTweak(size_group=sg, loaded=_shell_loaded)
File "/usr/lib/python3.8/site-packages/gtweak/tweaks/tweak_group_workspaces.py", line 46, in __init__
self.check1.set_visible(self.settings[self.key_name])
TypeError: 'GSettingsFakeSetting' object is not subscriptable
I also tried downloading the gnome-tweaks-git using the git URL. I was able to clone it, but when I ran makepkg -si in the terminal, this happens:
==> ERROR: Cannot find the fakeroot binary.
==> ERROR: Cannot find the strip binary required for object file stripping.
By the way, I’m using virtualbox for running Manjaro.
Please help me out. Thanks!!
Is gnome-tweaks not supposed to be run on xfse? I’m completely new to Linux. If I’m not supposed to use it, can you suggest an app for tweaking on xfse?
