For quite some time now I can’t open gnome-tweaks. When I launch it from the app launcher nothing happens. When I start it from the terminal this is the output:
File "/usr/lib/python3.9/site-packages/gtweak/app.py", line 51, in do_activate
self.win = Window(self, model)
File "/usr/lib/python3.9/site-packages/gtweak/tweakview.py", line 58, in __init__
self._model.load_tweaks(self)
File "/usr/lib/python3.9/site-packages/gtweak/tweakmodel.py", line 107, in load_tweaks
mods = __import__("gtweak.tweaks", globals(), locals(), tweak_files, 0)
File "/usr/lib/python3.9/site-packages/gtweak/tweaks/tweak_group_startup.py", line 352, in <module>
AutostartListBoxTweakGroup(),
File "/usr/lib/python3.9/site-packages/gtweak/tweaks/tweak_group_startup.py", line 295, in __init__
if not AutostartFile(df).is_start_at_login_enabled():
File "/usr/lib/python3.9/site-packages/gtweak/utils.py", line 193, in is_start_at_login_enabled
return open(self._user_autostart_file).read().find("X-GNOME-Autostart-enabled=false") == -1
File "/usr/lib/python3.9/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe2 in position 156: invalid continuation byte
Language: English
Formats (Region): US
