This is a strange and not something I can reproduce other than to say it has happened more than a few times. Periodically the text on the top toolbar and menus will disappear. Things work and I can get it to reappear if I go into Tweaks and change the font hinting. Doesn’t seem to matter what I change the hinting to, as long as it changes the text will reappear. I have not seen this on my other machines, so probably something local but thought I would ask.
More curious than anything. Am I alone in this?
Thanks.
Also not sure if I ran the right inxi config to be helpful.
inxi -Fxzc0
Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: GNOME v: 42.5 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4801
date: 03/02/2022
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 3432 high: 4442 min/max: 1400/4464 boost: enabled cores:
1: 3553 2: 3553 3: 4442 4: 3553 5: 3552 6: 3551 7: 3476 8: 2923 9: 3086
10: 2395 11: 3553 12: 3553 bogomips: 93457
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
v: 520.56.06 arch: Pascal bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4 driver: N/A
resolution: 1: 3840x2160~60Hz 2: 2560x1440~60Hz 3: 1920x1080~60Hz
4: 2560x1440~60Hz
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce GTX
1080/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0b:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0b:00.6
Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.55 TiB used: 2.56 TiB (56.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB temp: 32.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
ID-3: /dev/sdb vendor: Seagate model: ST3000DM008-2DM166 size: 2.73 TiB
ID-4: /dev/sdc vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-1: / size: 457.09 GiB used: 384.18 GiB (84.0%) fs: ext4 dev: /dev/dm-0
mapped: luks-c488fe94-681e-4021-9148-950dc8316c7b
ID-2: /boot/efi size: 299.4 MiB used: 444 KiB (0.1%) fs: vfat
dev: /dev/sdc1
System Temperatures: cpu: 46.6 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 413 Uptime: 8d 21h 25m Memory: 30.7 GiB used: 22.45 GiB (73.1%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2058
Shell: Bash v: 5.1.16 inxi: 3.3.23
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
