Hi,
Gnome Sound Recorder 40.0-1 does not work. The mic is detected and works fine.
Define “does not work”. It works for me.
It works here also… latest Gnome unstable
The generated file (flac, mp3, vorbis) is empty, with no audible sound!
I use XFCE
Yes, I did it
Problem solved!
I selected “show All Streams” in audio mixer and then record from…
Thanks
