Hello!
Last several months occasionally Gnome (gnome-shell specifically) crashes and goes into ‘On no something went wrong’ mode right after I hit Suspend function key on my laptop. Laptop still goes into suspend mode and I discover it next time I resume it.
This is my inxi output:
Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=65860e3a-6d6a-4b10-ae0c-7c134886f0f6 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3 intel_iommu=on
iommu=pt
Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Laptop System: Dream Machines product: NHx0DB,DE v: N/A
Mobo: Dream Machines model: NHx0DB,DE serial: <superuser required>
uuid: <superuser required> UEFI: INSYDE v: 1.07.11TDES date: 11/06/2020
ID-1: BAT0 charge: 45.8 Wh (100.0%) condition: 45.8/47.2 Wh (97.1%)
volts: 16.3 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: discharging
Info: model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 70421
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: CLEVO/KAPOK
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 5986:9102
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :1 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0xaf90 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 15.16 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 Ti driver: nvidia v: 550.107.02 device-ID: 10de:1f95
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD Graphics
(CML GT2) driver: mesa intel v: 24.1.6-arch1.1 device-ID: 8086:9bc4
surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 07:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0f1 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
Local Storage: total: 931.51 GiB used: 477.41 GiB (51.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 41.9 C
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
used: 477.41 GiB (51.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
System Temperatures: cpu: 51.0 C pch: 69.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 5.41 GiB (17.4%)
Processes: 434 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 2131 pm: pacman pkgs: 2089 libs: 567 tools: gnome-software,pamac
pm: flatpak pkgs: 40 pm: snap pkgs: 2 Compilers: clang: 18.1.8 gcc: 14.2.1
alt: 13 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.36
And this is what I found in journalctl around the time of crash (Down in logs there is a segfault of gnome-shell process):
Sep 12 23:45:07 laptop systemd-logind[2010]: Suspend key pressed short.
Sep 12 23:45:07 laptop gnome-shell[3341]: Window manager warning: Overwriting existing binding of keysym 61 with keysym 61 (keycode 26).
Sep 12 23:45:07 laptop systemd-logind[2010]: The system will suspend now!
Sep 12 23:45:07 laptop ModemManager[2148]: <msg> [sleep-monitor-systemd] system is about to suspend
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3458] manager: sleep: sleep requested (sleeping: no enabled: yes)
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3459] device (enp7s0f1): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', sys-iface-state: 'managed')
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3536] device (90:F0:52:01:84:EE): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', sys-iface-state: 'managed')
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3539] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', sys-iface-state: 'managed')
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3542] manager: NetworkManager state is now ASLEEP
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3546] device (wlp0s20f3): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3546] dhcp4 (wlp0s20f3): canceled DHCP transaction
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3547] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.3547] dhcp4 (wlp0s20f3): state changed no lease
Sep 12 23:45:07 laptop kernel: atkbd serio0: Unknown key released (translated set 2, code 0x6f on isa0060/serio0).
Sep 12 23:45:07 laptop kernel: atkbd serio0: Use 'setkeycodes 6f <keycode>' to make it known.
Sep 12 23:45:07 laptop gnome-shell[3341]: [x11gestures@joseexposito.github.io] Extension disabled
Sep 12 23:45:07 laptop gnome-shell[3341]: [x11gestures@joseexposito.github.io] Building entry point for GNOME Shell 46.4
Sep 12 23:45:07 laptop kernel: wlp0s20f3: deauthenticating from 08:7e:64:df:b3:38 by local choice (Reason: 3=DEAUTH_LEAVING)
Sep 12 23:45:07 laptop gnome-shell[3341]: [x11gestures@joseexposito.github.io] Connection with Touchégg daemon lost: null
Sep 12 23:45:07 laptop gnome-shell[3341]: [x11gestures@joseexposito.github.io] Connection manually closed, not reconnecting to the daemon
Sep 12 23:45:07 laptop wpa_supplicant[2199]: nl80211: send_event_marker failed: Source based routing not supported
Sep 12 23:45:07 laptop wpa_supplicant[2199]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=08:7e:64:df:b3:38 reason=3 locally_generated=1
Sep 12 23:45:07 laptop wpa_supplicant[2199]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.6076] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.6249] device (wlp0s20f3): set-hw-addr: set MAC address to 1A:91:EC:69:65:2A (scanning)
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.6320] device (wlp0s20f3): supplicant interface state: completed -> disconnected
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.6324] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', sys-iface-state: 'managed')
Sep 12 23:45:07 laptop NetworkManager[2004]: <info> [1726177507.6802] device (wlp0s20f3): set-hw-addr: reset MAC address to DC:41:A9:05:89:76 (unmanage)
Sep 12 23:45:07 laptop wpa_supplicant[2199]: wlp0s20f3: CTRL-EVENT-SCAN-FAILED ret=-100
Sep 12 23:45:07 laptop wpa_supplicant[2199]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all
Sep 12 23:45:07 laptop wpa_supplicant[2199]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
Sep 12 23:45:07 laptop wpa_supplicant[2199]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
Sep 12 23:45:08 laptop kernel: gnome-shell[3341]: segfault at 30 ip 00007fa3ccfaa7d0 sp 00007fffa442d5f0 error 4 in libst-14.so[7fa3ccf79000+70000] likely on CPU 5 (core 5, socket 0)
Sep 12 23:45:08 laptop kernel: Code: ad 20 ff ff ff 0f 84 e5 06 00 00 48 8b 85 68 ff ff ff 48 8b b5 30 ff ff ff 48 8b 80 28 01 00 00 4a 8b 1c 28 48 8b 03 48 8b 00 <48> 8b 38 ff 15 9f 31 06 00 85 c0 75 c3 4c 8b 63>
Sep 12 23:45:08 laptop systemd-coredump[51746]: Process 3341 (gnome-shell) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Sep 12 23:45:08 laptop systemd[1]: Created slice Slice /system/systemd-coredump.
Sep 12 23:45:08 laptop systemd[1]: Started Process Core Dump (PID 51746/UID 0).
Sep 12 23:45:08 laptop systemd[3196]: app-flatpak-org.qbittorrent.qBittorrent-24174.scope: Consumed 4min 41.321s CPU time, 12.5G memory peak.
Sep 12 23:45:10 laptop systemd-coredump[51747]: [🡕] Process 3341 (gnome-shell) of user 1000 dumped core.
Stack trace of thread 3341:
#0 0x00007fa3ccfaa7d0 st_theme_node_lookup_shadow (libst-14.so + 0x497d0)
#1 0x00007fa3ccfab25d st_theme_node_get_box_shadow (libst-14.so + 0x4a25d)
#2 0x00007fa3ccfae7c6 st_theme_node_get_paint_box (libst-14.so + 0x4d7c6)
#3 0x00007fa3ccfbc48f n/a (libst-14.so + 0x5b48f)
#4 0x00007fa3cd5503fd n/a (libmutter-clutter-14.so.0 + 0x3d3fd)
#5 0x00007fa3cd55085e clutter_actor_get_transformed_paint_volume (libmutter-clutter-14.so.0 + 0x3d85e)
#6 0x00007fa3ccfbc623 n/a (libst-14.so + 0x5b623)
#7 0x00007fa3cd5503fd n/a (libmutter-clutter-14.so.0 + 0x3d3fd)
#8 0x00007fa3cd55085e clutter_actor_get_transformed_paint_volume (libmutter-clutter-14.so.0 + 0x3d85e)
#9 0x00007fa3ccfbc623 n/a (libst-14.so + 0x5b623)
#10 0x00007fa3cd5503fd n/a (libmutter-clutter-14.so.0 + 0x3d3fd)
#11 0x00007fa3cd55085e clutter_actor_get_transformed_paint_volume (libmutter-clutter-14.so.0 + 0x3d85e)
#12 0x00007fa3ccfbc623 n/a (libst-14.so + 0x5b623)
#13 0x00007fa3ccfbbc76 n/a (libst-14.so + 0x5ac76)
#14 0x00007fa3cd5503fd n/a (libmutter-clutter-14.so.0 + 0x3d3fd)
#15 0x00007fa3cd55085e clutter_actor_get_transformed_paint_volume (libmutter-clutter-14.so.0 + 0x3d85e)
#16 0x00007fa3ccfbc623 n/a (libst-14.so + 0x5b623)
#17 0x00007fa3cd5503fd n/a (libmutter-clutter-14.so.0 + 0x3d3fd)
#18 0x00007fa3cd557138 n/a (libmutter-clutter-14.so.0 + 0x44138)
#19 0x00007fa3cd557116 n/a (libmutter-clutter-14.so.0 + 0x44116)
#20 0x00007fa3cd557116 n/a (libmutter-clutter-14.so.0 + 0x44116)
#21 0x00007fa3cd557116 n/a (libmutter-clutter-14.so.0 + 0x44116)
#22 0x00007fa3cd557116 n/a (libmutter-clutter-14.so.0 + 0x44116)
#23 0x00007fa3cd557116 n/a (libmutter-clutter-14.so.0 + 0x44116)
#24 0x00007fa3cd5b3d9d n/a (libmutter-clutter-14.so.0 + 0xa0d9d)
#25 0x00007fa3cd5b5a01 n/a (libmutter-clutter-14.so.0 + 0xa2a01)
#26 0x00007fa3cd575024 n/a (libmutter-clutter-14.so.0 + 0x62024)
#27 0x00007fa3cdd25ab9 n/a (libglib-2.0.so.0 + 0x5cab9)
#28 0x00007fa3cdd879e7 n/a (libglib-2.0.so.0 + 0xbe9e7)
#29 0x00007fa3cdd267b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
#30 0x00007fa3cd2ceeea meta_context_run_main_loop (libmutter-14.so.0 + 0xceeea)
#31 0x00007fa3cc67e596 n/a (libffi.so.8 + 0x7596)
#32 0x00007fa3cc67b00e n/a (libffi.so.8 + 0x400e)
#33 0x00007fa3cc67dbd3 ffi_call (libffi.so.8 + 0x6bd3)
#34 0x00007fa3cd67bfe1 n/a (libgjs.so.0 + 0x4bfe1)
#35 0x00007fa3cd67c688 n/a (libgjs.so.0 + 0x4c688)
#36 0x00007fa3cbaf7826 n/a (libmozjs-115.so + 0x12f7826)
#37 0x00007fa3cbd8c807 n/a (libmozjs-115.so + 0x158c807)
#38 0x00007fa3cb9933af n/a (libmozjs-115.so + 0x11933af)
#39 0x00007fa3cbea62a0 _ZN2JS4CallEP9JSContextNS_6HandleINS_5ValueEEES4_RKNS_16HandleValueArrayENS_13MutableHandleIS3_EE (libmozjs-115.so + 0x16a62a0)
#40 0x00007fa3cd6b2f02 n/a (libgjs.so.0 + 0x82f02)
#41 0x00007fa3cd6bb17f gjs_context_eval_module (libgjs.so.0 + 0x8b17f)
#42 0x00007fa3cd6bb481 gjs_context_eval_module_file (libgjs.so.0 + 0x8b481)
#43 0x000056289c86758c n/a (gnome-shell + 0x258c)
#44 0x00007fa3cd034e08 n/a (libc.so.6 + 0x25e08)
#45 0x00007fa3cd034ecc __libc_start_main (libc.so.6 + 0x25ecc)
#46 0x000056289c867a05 n/a (gnome-shell + 0x2a05)
Stack trace of thread 3354:
#0 0x00007fa3cd09fa19 n/a (libc.so.6 + 0x90a19)
#1 0x00007fa3cd0a2479 pthread_cond_wait (libc.so.6 + 0x93479)
#2 0x00007fa3cbb33b05 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-115.>
#3 0x00007fa3cbb33e43 n/a (libmozjs-115.so + 0x1333e43)
#4 0x00007fa3cbdf951e n/a (libmozjs-115.so + 0x15f951e)
#5 0x00007fa3cd0a339d n/a (libc.so.6 + 0x9439d)
#6 0x00007fa3cd12849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 3357:
Stack trace of thread 5493:
#0 0x00007fa3cd11a63d __poll (libc.so.6 + 0x10b63d)
#1 0x00007fa38c2cb9b7 n/a (libpulse.so.0 + 0x339b7)
#2 0x00007fa38c2b545c pa_mainloop_poll (libpulse.so.0 + 0x1d45c)
#3 0x00007fa38c2bf61c pa_mainloop_iterate (libpulse.so.0 + 0x2761c)
#4 0x00007fa38c2bf6d1 pa_mainloop_run (libpulse.so.0 + 0x276d1)
#5 0x00007fa38c2cfbf2 n/a (libpulse.so.0 + 0x37bf2)
#6 0x00007fa38c26d2b7 n/a (libpulsecommon-17.0.so + 0x5c2b7)
#7 0x00007fa3cd0a339d n/a (libc.so.6 + 0x9439d)
#8 0x00007fa3cd12849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 51741:
#0 0x00007fa3cd1261fd syscall (libc.so.6 + 0x1171fd)
#1 0x00007fa3cdd81367 g_cond_wait_until (libglib-2.0.so.0 + 0xb8367)
#2 0x00007fa3cdcee8d5 n/a (libglib-2.0.so.0 + 0x258d5)
#3 0x00007fa3cdd5b27b n/a (libglib-2.0.so.0 + 0x9227b)
#4 0x00007fa3cdd55266 n/a (libglib-2.0.so.0 + 0x8c266)
Stack trace of thread 3362:
#2 0x00007fa3a5ca3eee n/a (iris_dri.so + 0xa3eee)
#3 0x00007fa3a5c80ecc n/a (iris_dri.so + 0x80ecc)
#4 0x00007fa3a5ca3e1d n/a (iris_dri.so + 0xa3e1d)
Stack trace of thread 3352:
Stack trace of thread 3345:
#1 0x00007fa3cdd80a10 g_cond_wait (libglib-2.0.so.0 + 0xb7a10)
#2 0x00007fa3cdcee90c n/a (libglib-2.0.so.0 + 0x2590c)
#3 0x00007fa3cdd5a6b7 n/a (libglib-2.0.so.0 + 0x916b7)
Stack trace of thread 3351:
Stack trace of thread 3358:
Stack trace of thread 3359:
Stack trace of thread 3353:
Stack trace of thread 3350:
Stack trace of thread 3348:
#1 0x00007fa3cdd8792d n/a (libglib-2.0.so.0 + 0xbe92d)
#2 0x00007fa3cdd267b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
#3 0x00007fa3cd945574 n/a (libgio-2.0.so.0 + 0x112574)
Stack trace of thread 3346:
#2 0x00007fa3cdd24fc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
#3 0x00007fa3cdd2501a n/a (libglib-2.0.so.0 + 0x5c01a)
Stack trace of thread 3349:
#3 0x00007fa3c826a2fe n/a (libdconfsettings.so + 0x62fe)
Stack trace of thread 3364:
#3 0x00007fa3cdcee97d g_async_queue_pop (libglib-2.0.so.0 + 0x2597d)
#4 0x00007fa3ca7015fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
#5 0x00007fa3cdd55266 n/a (libglib-2.0.so.0 + 0x8c266)
#6 0x00007fa3cd0a339d n/a (libc.so.6 + 0x9439d)
#7 0x00007fa3cd12849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 3363:
Stack trace of thread 3356:
Stack trace of thread 3355:
Sep 12 23:45:10 laptop systemd[1]: systemd-coredump@0-51746-0.service: Deactivated successfully.
Sep 12 23:45:10 laptop systemd[1]: systemd-coredump@0-51746-0.service: Consumed 2.223s CPU time, 864.7M memory peak.
Sep 12 23:45:10 laptop systemd[1]: Starting TUXEDO Control Center Service (sleep/resume)...
Sep 12 23:45:10 laptop systemd[3196]: org.gnome.Shell@x11.service: Main process exited, code=dumped, status=11/SEGV
Sep 12 23:45:10 laptop systemd[3196]: org.gnome.Shell@x11.service: Failed with result 'core-dump'.
Sep 12 23:45:10 laptop systemd[3196]: org.gnome.Shell@x11.service: Triggering OnFailure= dependencies.
Sep 12 23:45:10 laptop systemd[3196]: org.gnome.Shell@x11.service: Consumed 9min 58.901s CPU time, 1G memory peak.
Sep 12 23:45:10 laptop systemd[3196]: org.gnome.Shell@x11.service: Scheduled restart job, restart counter is at 1.
Sep 12 23:45:10 laptop systemd[3196]: Started GNOME Session Failed lockdown screen (user).
Sep 12 23:45:10 laptop systemd[3196]: Reached target GNOME Session Failed.
Sep 12 23:45:10 laptop systemd[3196]: Disable GNOME Shell extensions after failure was skipped because of an unmet condition check (ConditionPathExists=/run/user/1000/gnome-shell-disable-extensions).
Sep 12 23:45:10 laptop systemd[3196]: Starting GNOME Shell on X11...
Sep 12 23:45:10 laptop systemd[1]: Stopping TUXEDO Control Center Service...
Sep 12 23:45:10 laptop gnome-shell[51771]: Running GNOME Shell (using mutter 46.4) as a X11 window and compositing manager
Sep 12 23:45:10 laptop tccd[51772]: Stopping daemon..
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (WW) EDID timing clock 353.80 exceeds claimed max 345MHz, fixing
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) modeset(0): EDID vendor "AUO", prod id 44944
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) modeset(0): Using hsync ranges from config file
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) modeset(0): Using vrefresh ranges from config file
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) modeset(0): Printing DDC gathered Modelines:
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) modeset(0): Modeline "1920x1080"x0.0 353.80 1920 2028 2076 2080 1080 1083 1088 1180 -hsync -vsync (170.1 kHz eP)
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) modeset(0): Modeline "1920x1080"x0.0 143.00 1920 2028 2076 2080 1080 1083 1088 1142 -hsync -vsync (68.8 kHz e)
Sep 12 23:45:11 laptop tccd[2013]: SIGINT - Exiting
Sep 12 23:45:11 laptop tccd[2013]: DisplayBacklightWorker: Refused to save display brightness 0 from intel_backlight
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Sep 12 23:45:11 laptop firefox.desktop[5578]: [GFX1-]: Detect DeviceReset DeviceResetReason::FORCED_RESET DeviceResetDetectPlace::WR_SIMULATE in Parent process
Sep 12 23:45:11 laptop tccd[51772]: Daemon is stopped
Sep 12 23:45:11 laptop systemd[1]: tccd.service: Deactivated successfully.
Sep 12 23:45:11 laptop systemd[1]: Stopped TUXEDO Control Center Service.
Sep 12 23:45:11 laptop systemd[1]: tccd.service: Consumed 4min 18.241s CPU time, 142.6M memory peak.
Sep 12 23:45:11 laptop systemd[1]: Finished TUXEDO Control Center Service (sleep/resume).
Sep 12 23:45:11 laptop systemd[1]: Reached target Sleep.
Sep 12 23:45:11 laptop systemd[1]: Starting System Suspend...
Sep 12 23:45:11 laptop systemd-sleep[51831]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
Sep 12 23:45:11 laptop systemd-sleep[51831]: This is not recommended, and might result in unexpected behavior, particularly
Sep 12 23:45:11 laptop systemd-sleep[51831]: in suspend-then-hibernate operations or setups with encrypted home directories.
Sep 12 23:45:11 laptop systemd-sleep[51831]: Performing sleep operation 'suspend'...
Sep 12 23:45:11 laptop kernel: PM: suspend entry (deep)
Sep 12 23:45:11 laptop kernel: Filesystems sync: 0.058 seconds
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "46"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event3 - Power Button: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "49"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event4 - Video Bus: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "50"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event0 - Power Button: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "51"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event1 - Sleep Button: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "52"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "53"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event13 - ELAN0412:00 04F3:3162 Mouse: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "54"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event14 - ELAN0412:00 04F3:3162 Touchpad: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "55"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event6 - Intel HID events: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "56"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event5 - AT Translated Set 2 keyboard: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "57"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event20 - ETPS/2 Elantech Touchpad: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (**) Option "fd" "58"
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event7 - TUXEDO Keyboard: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) event21 - Logitech B330/M330/M3: device removed
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) AIGLX: Suspending AIGLX clients for VT switch
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:70
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:68
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:78
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:64
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:65
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:77
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:85
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:84
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:67
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:69
Sep 12 23:45:11 laptop /usr/lib/gdm-x-session[3234]: (II) systemd-logind: got pause for 13:71
Sep 12 23:45:11 laptop kernel: rfkill: input handler enabled
Sep 13 05:40:32 laptop kernel: Freezing user space processes
Sep 13 05:40:32 laptop kernel: Freezing user space processes completed (elapsed 0.003 seconds)
Sep 13 05:40:32 laptop kernel: OOM killer disabled.
Sep 13 05:40:32 laptop kernel: Freezing remaining freezable tasks
Sep 13 05:40:32 laptop kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Sep 13 05:40:32 laptop kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Suspend triggers ‘Screen Lockup’ so it could be related to Bug #2069559 “gnome-shell crashed with SIGSEGV in st_theme_node_...” : Bugs : gnome-shell package : Ubuntu but as far as I remember I’ve never encountered this bug on screen lockup due to timeout.
As launchpad page says extensions could be to blame but my list is pretty small and preinstalled by default as far I remember:
- AppIndicator and KStatusNotifierItem Support
- Dash to Dock
- Gnome 4x UI Improvements
- Pamac updates notifier
- X11 Gestures (one I actually installed)
Is this a known/solvable issue?
