GNOME Shell Extensions missing and wrong terminal font
I did a reboot after an update today and noticed a couple of odd things:
  1. The rygel seems to run noticeable at startup and it also hogs one CPU for the duration. (This is not really annoying since after a minute or so it is done, just something peculiar :thinking: )
  2. My terminal’s font was broken:
  3. When I wanted to change the terminal’s font again I also noticed the absence of the extensions tab in Tweaks:
I’m wondering now how I can get the normal shell back, as far as I can remember I have not changed anything from Manjaro GNOME’s default settings and when connecting via ssh the fonts are rendered appropriately, so it should not be a p10k issue.
Any help would be appreciated!
Edit: The shell theme says none, so this might provide some help. But what is the default one?
What font do you have set in your terminal? ttf-meslo-nerd-font-powerlevel10k is recommended, however you can use any nerd font.
There is a standalone Extensions application that’s part of GNOME Shell. It’s only been around since GNOME 3.36. :wink:
Default means it’s using Adwaita.
Thanks, this seems to have been the main issue. Apparently it gut uninstalled for some weird reason and I missed it in the preferences (None was selected)
Any idea what rygel is up to though?
Please create a separate topic with more details.
