GNOME Shell crashes when NVIDIA GPU is detached for VFIO passthrough
I’ve been trying (with the help of ChatGPT) to figure out how to pass through an Nvidia T1200 on a QEMU/KVM Windows 11 Pro guest.
For hours. :slight_smile:
Fundamentally, even with hybrid graphics, gnome-shell seems to open the Nvidia device even if I’m not using prime-run. And attempting to detach the drive from the device in order to use it in the VM via VFIO crashes gnome-shell.
$ inxi -Fzay
  Kernel: 7.2.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    clocksource: tsc avail: acpi_pm parameters: initrd=\initramfs-7.2-x86_64.img
    root=UUID=9986c4bc-2e41-455d-8529-04562626346e rw rootfstype=ext4 quiet
    splash
  Desktop: GNOME v: 51.1 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 51.1.1 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 20Y30064US v: ThinkPad P1 Gen 4i
  Mobo: LENOVO model: 20Y30064US v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20Y3_BU_Think_FM_ThinkPad P1
    Gen 4i uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: N40ET54W (1.36 ) date: 08/19/2026
  ID-1: BAT0 charge: 59.8 Wh (78.9%) condition: 75.8/90.1 Wh (84.1%)
    volts: 15.72 min: 15.52 model: SMP 5B11B79217 type: Li-poly serial: <filter>
    charging: status: not charging control: start: 75% end: 80% cycles: 309
  System RAM: total: 64 GiB available: 62.51 GiB used: 3.52 GiB (5.6%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 32 GiB speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Team Group Inc part-no: TEAMGROUP-SD4-3200 serial: <filter>
  Device-2: Controller0-ChannelA-DIMM1 type: no module installed
  Device-3: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
  Device-4: Controller1-ChannelA-DIMM1 type: no module installed
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x58
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB
    desc: 8x1.2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
    bogomips: 73728
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
    pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
    sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA TU117GLM [T1200 Laptop GPU] vendor: Lenovo driver: nvidia
    v: 615.78.08 alternate: nouveau,nvidia_drm non-free: 550-6xx.xx+
    status: current (as of 2026-07) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-5,DP-6,HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:1fbc class-ID: 0300
  Device-3: IMC Networks Integrated RGB Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 13d3:5271
  Display: wayland server: X.org v: 1.21.1.25 with: Xwayland v: 24.1.14
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: LG Display 0x06aa built: 2020 res: 3840x2400
    dpi: 284 gamma: 1.2 chroma: red: x: 0.663 y: 0.329 green: x: 0.204 y: 0.718
    blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 3840x2400
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 26.2.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
    device-ID: 8086:9a60 memory: 61.05 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: gputop, intel_gpu_top, lsgpu,
    nvidia-settings, nvidia-smi x11: xprop,xrandr
  Device-1: Intel 500 Series Family HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:43c8
    class-ID: 0401
  Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10fa class-ID: 0403
  Device-3: Logitech Logitech Speaker Lapdesk N700
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 046d:0a1a class-ID: 0300
  API: ALSA v: k7.2.14-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.10 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlp9s0 state: up mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager, smbd, sshd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:5 chip-ID: 8087:0032
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.4
    lmp-v: 13 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 5.5 TiB used: 2.61 TiB (47.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6002T
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: SN13126 temp: 29.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 3.64 TiB block-size: physical: 512 B
    fw-rev: SN022788 temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 502.93 GiB size: 493.96 GiB (98.22%)
    used: 52.75 GiB (10.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: manjaro uuid: 9986c4bc-2e41-455d-8529-04562626346e
  ID-2: /boot raw-size: 1.1 GiB size: 1.1 GiB (99.80%)
    used: 349.7 MiB (31.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: ESP uuid: 821D-AA87
  ID-3: /home raw-size: 205.08 GiB size: 200.8 GiB (97.91%)
    used: 78.53 GiB (39.1%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:8
    label: HOME uuid: 2fe6c8e5-6859-4a16-bc21-546bad6cf6bc
  ID-4: /media/tledford/DATA raw-size: 3.44 TiB size: 3.38 TiB (98.40%)
    used: 1.85 TiB (54.6%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:7
    label: DATA uuid: 9dd272fa-a832-4c81-8a58-b54217420f2c
  ID-5: /media/tledford/EXT4 raw-size: 927.86 GiB size: 912.2 GiB (98.31%)
    used: 653.2 GiB (71.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: EXT4 uuid: 2ba360e2-171e-412d-ac5a-d9f7a305b3a0
  ID-6: /media/tledford/dropbox raw-size: N/A size: 2.25 GiB
    used: 1.33 GiB (59.1%) fs: fuse.rclone remote: dropbox:
  ID-7: /media/tledford/gdrive raw-size: N/A size: 2 TiB
    used: 570.4 GiB (27.9%) fs: fuse.rclone remote: gdrive:
  ID-8: /media/tledford/onedrive raw-size: N/A size: 5 GiB
    used: 409.6 MiB (8.0%) fs: fuse.rclone remote: onedrive:
  ID-9: /media/tledford/sshfs/HTPC raw-size: N/A size: 475.38 GiB
    used: 148.34 GiB (31.2%) fs: fuse.sshfs remote: tledford@HTPC:/
  ID-10: /media/tledford/sshfs/mmusic raw-size: N/A size: 648.96 GiB
    used: 50.6 GiB (7.8%) fs: fuse.sshfs remote: tledford@mmusic:/
  ID-11: /media/tledford/sshfs/muswin11p raw-size: N/A size: 818.28 GiB
    used: 416.27 GiB (50.9%) fs: fuse.sshfs remote: tledford@muswin11p:/
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -1
    file: /swapfile
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 474.6 GiB fs: ntfs label: OS
    uuid: DEB01E51B01E308F
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 1.24 GiB fs: ntfs label: N/A
    uuid: 907CE7627CE74198
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 3-1:2 info: Logitech Logitech Speaker Lapdesk N700
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
  Device-2: 3-8:3 info: IMC Networks Integrated RGB Camera type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:5271 class-ID: 0e02 serial: <filter>
  Device-3: 3-9:4 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 06cb:00f9 class-ID: ff00 serial: <filter>
  Device-4: 3-14:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-4: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 47.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 2484 fan-2: 2310
  Packages: 2216 pm: pacman pkgs: 2192 libs: 471
    tools: gnome-software,pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 24
    1: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    2: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    4: https://mirrors.gigenet.com/manjaro/testing/$repo/$arch
    5: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    7: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    8: https://mirrors.ocf.berkeley.edu/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 388
  1: cpu: 7.7% command: jack_mixer started-by: python3 pid: 3433
    mem: 115.3 MiB (0.1%)
  2: cpu: 4.0% command: gnome-shell pid: 3224 mem: 441.4 MiB (0.6%)
  3: cpu: 1.3% command: pipewire pid: 3542 mem: 55.5 MiB (0.0%)
  4: cpu: 0.9% command: gedit pid: 40050 mem: 134.9 MiB (0.2%)
  5: cpu: 0.6% command: nvidia-smi pid: 23919 mem: 27.5 MiB (0.0%)
  Memory top: 5 of 388
  1: mem: 441.4 MiB (0.6%) command: gnome-shell pid: 3224 cpu: 4.0%
  2: mem: 159.3 MiB (0.2%) command: systemd-journald pid: 344 cpu: 0.0%
  3: mem: 152.4 MiB (0.2%) command: ptyxis pid: 3402 cpu: 0.5%
  4: mem: 134.9 MiB (0.2%) command: gedit pid: 40050 cpu: 0.9%
  5: mem: 115.3 MiB (0.1%) command: jack_mixer started-by: python3 pid: 3433
    cpu: 7.7%
  Processes: 388 Power: uptime: 2h 52m states: freeze,mem,disk suspend: s2idle
    image: 24.91 GiB services: gsd-power, power-profiles-daemon, upowerd
    Init: systemd v: 262 default: graphical tool: systemctl
  Compilers: clang: 23.1.4 gcc: 16.2.1 Shell: Bash v: 5.3.20
    running-in: ptyxis-agent inxi: 3.3.41
ChatGPT summary
I’m investigating dynamic GPU passthrough on a Lenovo ThinkPad P1 Gen 4 (Gen 4i), running Manjaro GNOME on Wayland.
Hardware and software
  • Intel Core i7-11800H with Intel UHD Graphics (Tiger Lake-H).
  • NVIDIA T1200 Laptop GPU.
  • Manjaro Linux, kernel 7.2.14-1-MANJARO.
  • GNOME Shell 51.1, running on Wayland.
  • NVIDIA driver 615.78.08.
  • Windows 11 Pro guest running under QEMU/KVM/libvirt.
What I’m trying to accomplish
I want to pass the NVIDIA T1200 and its associated audio function through to a Windows VM only while that VM is running. When the VM shuts down, the GPU should return to the NVIDIA driver so that I can use NVIDIA PRIME (prime-run) on the Linux host.
The Linux desktop must remain running on the Intel GPU throughout the VM startup and shutdown. I don’t need the NVIDIA GPU for display output in the guest; the VM uses Virtio video and SPICE.
The T1200 and its audio function are isolated together in IOMMU group 15, so there are no unrelated devices in the group.
What we’ve observed
The T1200 is normally bound to the NVIDIA driver (nvidia), and its audio function is bound to snd_hda_intel.
When attempting to start the VM with PCI passthrough, the journal recorded the following sequence at approximately 07:58:20:
VFIO - User Level meta-driver version: 0.3
[drm] [nvidia-drm] [GPU ID 0x00000100] Removing device
[drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
gnome-shell: Failed to reopen '/dev/dri/card0':
  Could not get device info for path /dev/dri/card0:
  No such file or directory
NVRM: Attempting to remove device 0000:01:00.0
  with non-zero usage count!
This suggests that GNOME Shell has an active relationship with the NVIDIA GPU when VFIO attempts to take it over. Detaching the GPU also causes GNOME Shell problems.
We do not yet know whether GNOME Shell is rendering on the NVIDIA GPU, merely enumerating it, or using it for some other graphics function.
What has already been tried
  • Libvirt PCI host devices configured with managed='yes'.
  • Experiments with managed='no' and external scripts to manage the GPU handoff.
  • Attempts to use libvirt QEMU hooks to unbind the NVIDIA devices and bind them to VFIO.
These experiments have produced unreliable results, including GPU handoff failures and libvirt service hangs. The hook scripts have since been disabled. I do not want to repeat these experiments until the underlying issue is better understood.
Questions for the Manjaro/GNOME community
  1. Is it normal for Mutter/GNOME Shell on Wayland to open the DRM device of a secondary NVIDIA GPU even when the Intel GPU drives the desktop?
  2. How can I determine precisely why GNOME Shell has the NVIDIA DRM device open, and what operations it performs through it?
  3. Is there a supported way to configure Mutter to ignore a particular GPU, such as the mutter-device-ignore udev tag?
  4. Could NVIDIA’s proprietary driver or its DRM/KMS integration cause GNOME Shell to retain a device reference that prevents clean GPU detachment?
  5. Is there a known way to make a secondary NVIDIA GPU available for dynamic VFIO passthrough without stopping GNOME Shell or disrupting the Intel-driven desktop?
My priority is to retain a fully functional Manjaro desktop and NVIDIA PRIME when the VM is off, while making the T1200 available exclusively to the Windows guest when the VM is running.
I’d particularly appreciate guidance from anyone familiar with Mutter’s multi-GPU handling and NVIDIA’s proprietary DRM implementation.
$ ls -l /dev/dri/by-path
total 0
lrwxrwxrwx 1 root root  8 Nov  8 08:51 pci-0000:00:02.0-card -> ../card1
lrwxrwxrwx 1 root root 13 Nov  8 08:51 pci-0000:00:02.0-render -> ../renderD128
lrwxrwxrwx 1 root root  8 Nov  8 08:51 pci-0000:01:00.0-card -> ../card0
lrwxrwxrwx 1 root root 13 Nov  8 08:51 pci-0000:01:00.0-render -> ../renderD129
NOTE: card0 is the Nvidia
$ ls -l /dev/dri
total 0
drwxr-xr-x  2 root root        120 Nov  8 08:51 by-path
crw-rw----+ 1 root video  226,   0 Nov  8 08:51 card0
crw-rw----+ 1 root video  226,   1 Nov  8 08:51 card1
crw-rw-rw-  1 root render 226, 128 Nov  8 08:51 renderD128
crw-rw-rw-  1 root render 226, 129 Nov  8 08:51 renderD129
Any insight appreciated!
