Gnome Shell crashes frequently on Nvidia driver
Hello
Gnome Shell has been crashing randomly (as far as I can tell) since the 2023-06-04 update.
It actually crashed while I was installing the 2023-07-10 update & I had to reinstall Manjaro (cause that’s quicker).
I’m currently running Wayland cause it doesn’t crash, so that’s nice. But, VMWare can’t capture my input when running in Wayland & so I’d really like to go back to X11.
Any ideas?
inxi
  Kernel: 6.3.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/vmlinuz-6.3-x86_64
    root=UUID=e53b1874-f1d2-4e76-aab2-f57cc1e0f5b0 rw rootflags=subvol=@
    splash fbcon=nodefer apparmor=1 security=apparmor udev.log_priority=3
    resume=UUID=b20930b3-964a-41a9-9368-5a1a999cbd9f
    bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3603
    date: 03/20/2021
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 2248 high: 3120 min/max: 2200/4426 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2202 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 3120 10: 2200 11: 2199
    12: 2055 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 115243
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU104GL [Quadro RTX 4000] driver: nvidia v: 535.54.03
    alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-2
    empty: DP-1,DP-3,Unknown-1 bus-ID: 0a:00.0 chip-ID: 10de:1eb1
    class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: 0
  Monitor-1: DP-2 model: BenQ GW2283 serial: <filter> built: 2019
    res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
    diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: Quadro RTX 4000/PCIe/SSE2
    direct-render: Yes
  Device-1: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.3.12-1-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
  Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-3: vmnet2 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-4: vmnet3 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-5: vmnet4 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-6: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3
    chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 3.19 TiB used: 1.8 TiB (56.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA SSD
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFA12.9 temp: 44.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
    fw-rev: EDFM20.0 temp: 21.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
  ID-1: / raw-size: 89.41 GiB size: 89.41 GiB (100.00%) used: 41.75 GiB (46.7%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: /boot raw-size: 954 MiB size: 920.7 MiB (96.51%)
    used: 596.3 MiB (64.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /boot/efi raw-size: 244 MiB size: 240.2 MiB (98.46%)
    used: 274 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-4: /home raw-size: 826.03 GiB size: 826.03 GiB (100.00%)
    used: 380.44 GiB (46.1%) fs: f2fs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-5: /var/log raw-size: 89.41 GiB size: 89.41 GiB (100.00%)
    used: 41.75 GiB (46.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-1: swap-1 type: partition size: 14.9 GiB used: 256 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 48.9 C mobo: N/A
  Processes: 485 Uptime: 42m wakeups: 1 Memory: total: 32 GiB
  available: 31.26 GiB used: 7.27 GiB (23.3%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1220 libs: 369 tools: gnome-software,pamac,yay
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.28
journalctl
❯ journalctl -r --since "yesterday" --until "today" -p err -n 1 | fold -w 160
Jul 15 20:20:03 manjaro-ws systemd-coredump[17466]: Process 15828 (gnome-shell) of user 1000 dumped core.
                                                    Stack trace of thread 15828:
                                                    #0  0x00007fcbc669f26c n/a (libc.so.6 + 0x8926c)
                                                    #1  0x00007fcbc664fa08 raise (libc.so.6 + 0x39a08)
                                                    #2  0x000055e0814baf19 n/a (gnome-shell + 0x3f19)
                                                    #3  0x00007fcbc664fab0 n/a (libc.so.6 + 0x39ab0)
                                                    #4  0x00007fcbc6f40018 g_log_structured_array (libglib-2.0.so.0 + 0x61018)
                                                    #5  0x00007fcbc6f40313 g_log_default_handler (libglib-2.0.so.0 + 0x61313)
                                                    #6  0x00007fcbc6f411c5 g_logv (libglib-2.0.so.0 + 0x621c5)
                                                    #7  0x00007fcbc6f41494 g_log (libglib-2.0.so.0 + 0x62494)
                                                    #8  0x00007fcbc6917e47 n/a (libmutter-12.so.0 + 0x117e47)
                                                    #9  0x00007fcbc632968c _XError (libX11.so.6 + 0x4468c)
                                                    #10 0x00007fcbc6329798 n/a (libX11.so.6 + 0x44798)
                                                    #11 0x00007fcbc6329855 n/a (libX11.so.6 + 0x44855)
                                                    #12 0x00007fcbc63298ea _XEventsQueued (libX11.so.6 + 0x448ea)
                                                    #13 0x00007fcbc631c238 XPending (libX11.so.6 + 0x37238)
                                                    #14 0x00007fcbc6f3965b g_main_context_prepare (libglib-2.0.so.0 + 0x5a65b)
                                                    #15 0x00007fcbc6f96a96 n/a (libglib-2.0.so.0 + 0xb7a96)
                                                    #16 0x00007fcbc6f38fef g_main_loop_run (libglib-2.0.so.0 + 0x59fef)
                                                    #17 0x00007fcbc68cddcb meta_context_run_main_loop (libmutter-12.so.0 + 0xcddcb)
                                                    #18 0x000055e0814ba526 n/a (gnome-shell + 0x3526)
                                                    #19 0x00007fcbc6639850 n/a (libc.so.6 + 0x23850)
                                                    #20 0x00007fcbc663990a __libc_start_main (libc.so.6 + 0x2390a)
                                                    #21 0x000055e0814ba835 n/a (gnome-shell + 0x3835)
                                                    Stack trace of thread 15833:
                                                    #0  0x00007fcbc6713c0f __poll (libc.so.6 + 0xfdc0f)
                                                    #1  0x00007fcbc6f96c2f n/a (libglib-2.0.so.0 + 0xb7c2f)
                                                    #2  0x00007fcbc6f38fef g_main_loop_run (libglib-2.0.so.0 + 0x59fef)
                                                    #3  0x00007fcbc713a28c n/a (libgio-2.0.so.0 + 0x11028c)
                                                    #4  0x00007fcbc6f6bd75 n/a (libglib-2.0.so.0 + 0x8cd75)
                                                    #5  0x00007fcbc669d44b n/a (libc.so.6 + 0x8744b)
                                                    #6  0x00007fcbc6720e40 n/a (libc.so.6 + 0x10ae40)
                                                    Stack trace of thread 15830:
                                                    #0  0x00007fcbc67192ed syscall (libc.so.6 + 0x1032ed)
                                                    #1  0x00007fcbc6f8eca7 g_cond_wait (libglib-2.0.so.0 + 0xafca7)
                                                    #2  0x00007fcbc6f04144 n/a (libglib-2.0.so.0 + 0x25144)
                                                    #3  0x00007fcbc6f6e2fe n/a (libglib-2.0.so.0 + 0x8f2fe)
                                                    Stack trace of thread 15831:
                                                    #2  0x00007fcbc6f370e2 g_main_context_iteration (libglib-2.0.so.0 + 0x580e2)
                                                    #3  0x00007fcbc6f37132 n/a (libglib-2.0.so.0 + 0x58132)
                                                    Stack trace of thread 15845:
                                                    #0  0x00007fcbc6699f0e n/a (libc.so.6 + 0x83f0e)
                                                    #1  0x00007fcbc669c7a0 pthread_cond_wait (libc.so.6 + 0x867a0)
                                                    #2  0x00007fcbc559b591 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDur
ationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x159b591)
                                                    #3  0x00007fcbc559b492 n/a (libmozjs-102.so + 0x159b492)
                                                    #4  0x00007fcbc574d63e n/a (libmozjs-102.so + 0x174d63e)
                                                    Stack trace of thread 15844:
                                                    Stack trace of thread 15843:
                                                    Stack trace of thread 15834:
                                                    #3  0x00007fcbc27d9fde n/a (libdconfsettings.so + 0x5fde)
                                                    Stack trace of thread 15846:
                                                    Stack trace of thread 15848:
                                                    Stack trace of thread 15847:
                                                    Stack trace of thread 16261:
                                                    #1  0x00007fcb9c3ac8c7 n/a (libpulse.so.0 + 0x338c7)
                                                    #2  0x00007fcb9c39646c pa_mainloop_poll (libpulse.so.0 + 0x1d46c)
                                                    #3  0x00007fcb9c3a042c pa_mainloop_iterate (libpulse.so.0 + 0x2742c)
                                                    #4  0x00007fcb9c3a04e1 pa_mainloop_run (libpulse.so.0 + 0x274e1)
                                                    #5  0x00007fcb9c3b0c02 n/a (libpulse.so.0 + 0x37c02)
                                                    #6  0x00007fcb9c34dc67 n/a (libpulsecommon-16.1.so + 0x5bc67)
                                                    #7  0x00007fcbc669d44b n/a (libc.so.6 + 0x8744b)
                                                    #8  0x00007fcbc6720e40 n/a (libc.so.6 + 0x10ae40)
                                                    Stack trace of thread 15849:
                                                    Stack trace of thread 15850:
                                                    Stack trace of thread 17459:
                                                    #1  0x00007fcbc6f8f533 g_cond_wait_until (libglib-2.0.so.0 + 0xb0533)
                                                    #2  0x00007fcbc6f04115 n/a (libglib-2.0.so.0 + 0x25115)
                                                    #3  0x00007fcbc6f04277 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x25277)
                                                    #4  0x00007fcbc6f6ebee n/a (libglib-2.0.so.0 + 0x8fbee)
                                                    #5  0x00007fcbc6f6bd75 n/a (libglib-2.0.so.0 + 0x8cd75)
                                                    #6  0x00007fcbc669d44b n/a (libc.so.6 + 0x8744b)
                                                    #7  0x00007fcbc6720e40 n/a (libc.so.6 + 0x10ae40)
Xorg.0.log
[  7338.642] (--) Log file renamed from "/var/log/Xorg.pid-22238.log" to "/var/log/Xorg.0.log"
[  7338.643]
X.Org X Server 1.21.1.8
[  7338.643] Current Operating System: Linux manjaro-ws 6.3.12-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Jul  6 15:52:38 UTC 2023 x86_64
[  7338.643] Kernel command line: BOOT_IMAGE=/vmlinuz-6.3-x86_64 root=UUID=e53b1874-f1d2-4e76-aab2-f57cc1e0f5b0 rw rootflags=subvol=@ quiet splash fbcon=nodefer apparmor=1 security=apparmor udev.log_priority=3 resume=UUID=b20930b3-964a-41a9-9368-5a1a999cbd9f bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
[  7338.643]
[  7338.643] Current version of pixman: 0.42.2
[  7338.643] 	Before reporting problems, check http://wiki.x.org
[  7338.643] Markers: (--) probed, (**) from config file, (==) default setting,
[  7338.643] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 15 13:29:13 2023
[  7338.643] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  7338.643] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  7338.643] (==) ServerLayout "layout"
[  7338.643] (**) |-->Screen "Screen0" (0)
[  7338.643] (**) |   |-->Monitor "Monitor0"
[  7338.643] (**) |   |-->Device "Device0"
[  7338.643] (==) Automatically adding devices
[  7338.643] (==) Automatically enabling devices
[  7338.643] (==) Automatically adding GPU devices
[  7338.643] (==) Automatically binding GPU devices
[  7338.643] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  7338.643] (WW) The directory "/usr/share/fonts/misc" does not exist.
[  7338.643] 	Entry deleted from font path.
[  7338.643] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[  7338.643] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[  7338.643] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[  7338.643] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  7338.643] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  7338.643] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  7338.643] (==) FontPath set to:
[  7338.643] (==) ModulePath set to "/usr/lib/xorg/modules"
[  7338.643] (**) Extension "COMPOSITE" is enabled
[  7338.643] (II) The server relies on udev to provide the list of input devices.
[  7338.643] (II) Module ABI versions:
[  7338.643] 	X.Org ANSI C Emulation: 0.4
[  7338.643] 	X.Org Video Driver: 25.2
[  7338.643] 	X.Org XInput driver : 24.4
[  7338.643] 	X.Org Server Extension : 10.0
[  7338.644] (++) using VT number 1
[  7338.644] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_311
[  7338.644] (II) xfree86: Adding drm device (/dev/dri/card0)
[  7338.644] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:0a:00.0/drm/card0
[  7338.645] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[  7338.646] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  7338.646] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  7338.648] (--) PCI:*(10@0:0:0) 10de:1eb1:10de:12a0 rev 161, Mem @ 0xfb000000/16777216, 0x7fe0000000/268435456, 0x7ff0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[  7338.648] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  7338.648] (II) LoadModule: "glx"
[  7338.648] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  7338.649] (II) Module glx: vendor="X.Org Foundation"
[  7338.649] 	compiled for 1.21.1.8, module version = 1.0.0
[  7338.649] 	ABI class: X.Org Server Extension, version 10.0
[  7338.649] (II) LoadModule: "nvidia"
[  7338.649] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  7338.649] (II) Module nvidia: vendor="NVIDIA Corporation"
[  7338.649] 	compiled for 1.6.99.901, module version = 1.0.0
[  7338.649] 	Module class: X.Org Video Driver
[  7338.649] (II) NVIDIA dlloader X Driver  535.54.03  Tue Jun  6 22:23:02 UTC 2023
[  7338.649] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  7338.649] (II) systemd-logind: releasing fd for 226:0
[  7338.649] (II) Loading sub module "fb"
[  7338.649] (II) LoadModule: "fb"
[  7338.649] (II) Module "fb" already built-in
[  7338.649] (II) Loading sub module "wfb"
[  7338.649] (II) LoadModule: "wfb"
[  7338.649] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  7338.649] (II) Module wfb: vendor="X.Org Foundation"
[  7338.649] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  7338.650] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[  7338.650] (==) NVIDIA(0): RGB weight 888
[  7338.650] (==) NVIDIA(0): Default visual is TrueColor
[  7338.650] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  7338.650] (**) Option "AllowNVIDIAGpuScreens"
[  7338.650] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  7338.650] (**) NVIDIA(0): Option "Stereo" "0"
[  7338.650] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-3"
[  7338.650] (**) NVIDIA(0): Option "SLI" "Off"
[  7338.650] (**) NVIDIA(0): Option "MultiGPU" "Off"
[  7338.650] (**) NVIDIA(0): Option "BaseMosaic" "off"
[  7338.650] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  7338.650] (**) NVIDIA(0): Stereo disabled by request
[  7338.650] (**) NVIDIA(0): NVIDIA SLI disabled.
[  7338.650] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[  7338.650] (**) NVIDIA(0): Option "MetaModes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
[  7338.650] (**) NVIDIA(0): Enabling 2D acceleration
[  7338.650] (II) Loading sub module "glxserver_nvidia"
[  7338.650] (II) LoadModule: "glxserver_nvidia"
[  7338.650] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[  7338.654] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  7338.654] 	compiled for 1.6.99.901, module version = 1.0.0
[  7338.654] 	Module class: X.Org Server Extension
[  7338.654] (II) NVIDIA GLX Module  535.54.03  Tue Jun  6 22:23:41 UTC 2023
[  7338.654] (II) NVIDIA: The X server supports PRIME Render Offload.
[  7339.327] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:10:0:0
[  7339.327] (--) NVIDIA(0):     DFP-0
[  7339.327] (--) NVIDIA(0):     DFP-1
[  7339.327] (--) NVIDIA(0):     DFP-2
[  7339.327] (--) NVIDIA(0):     DFP-3 (boot)
[  7339.327] (--) NVIDIA(0):     DFP-4
[  7339.327] (--) NVIDIA(0):     DFP-5
[  7339.327] (--) NVIDIA(0):     DFP-6
[  7339.328] (II) NVIDIA(0): NVIDIA GPU Quadro RTX 4000 (TU104GL-A) at PCI:10:0:0 (GPU-0)
[  7339.328] (--) NVIDIA(0): Memory: 8388608 kBytes
[  7339.328] (--) NVIDIA(0): VideoBIOS: 90.04.87.00.01
[  7339.328] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[  7339.328] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7339.328] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[  7339.328] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[  7339.328] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7339.328] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7339.328] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7339.328] (--) NVIDIA(GPU-0): DFP-2: disconnected
[  7339.328] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[  7339.328] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[  7339.421] (--) NVIDIA(GPU-0): BenQ GW2283 (DFP-3): connected
[  7339.421] (--) NVIDIA(GPU-0): BenQ GW2283 (DFP-3): Internal TMDS
[  7339.421] (--) NVIDIA(GPU-0): BenQ GW2283 (DFP-3): 300.0 MHz maximum pixel clock
[  7339.421] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7339.421] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[  7339.421] (--) NVIDIA(GPU-0): DFP-4: 2660.0 MHz maximum pixel clock
[  7339.421] (--) NVIDIA(GPU-0): DFP-5: disconnected
[  7339.421] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[  7339.421] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[  7339.421] (--) NVIDIA(GPU-0): DFP-6: disconnected
[  7339.421] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[  7339.421] (--) NVIDIA(GPU-0): DFP-6: 2660.0 MHz maximum pixel clock
[  7339.466] (II) NVIDIA(0): Validated MetaModes:
[  7339.466] (II) NVIDIA(0):     "nvidia-auto-select+0+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On}"
[  7339.466] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[  7339.510] (--) NVIDIA(0): DPI set to (101, 101); computed from "UseEdidDpi" X config
[  7339.510] (--) NVIDIA(0):     option
[  7339.510] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[  7339.510] (II) NVIDIA:     access.
[  7339.513] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  7339.513] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  7339.513] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  7339.513] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  7339.513] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  7339.513] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  7339.513] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  7339.513] (II) NVIDIA(0):     Config Options in the README.
[  7339.803] (II) NVIDIA(0): Setting mode "nvidia-auto-select+0+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On}"
[  7339.828] (==) NVIDIA(0): Disabling shared memory pixmaps
[  7339.828] (==) NVIDIA(0): Backing store enabled
[  7339.828] (==) NVIDIA(0): Silken mouse enabled
[  7339.828] (**) NVIDIA(0): DPMS enabled
[  7339.828] (WW) NVIDIA(0): Option "NoLogo" is not used
[  7339.828] (II) Loading sub module "dri2"
[  7339.828] (II) LoadModule: "dri2"
[  7339.828] (II) Module "dri2" already built-in
[  7339.828] (II) NVIDIA(0): [DRI2] Setup complete
[  7339.828] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[  7339.829] (II) Initializing extension Generic Event Extension
[  7339.829] (II) Initializing extension SHAPE
[  7339.829] (II) Initializing extension MIT-SHM
[  7339.829] (II) Initializing extension XInputExtension
[  7339.829] (II) Initializing extension XTEST
[  7339.829] (II) Initializing extension BIG-REQUESTS
[  7339.829] (II) Initializing extension SYNC
[  7339.829] (II) Initializing extension XKEYBOARD
[  7339.829] (II) Initializing extension XC-MISC
[  7339.829] (II) Initializing extension SECURITY
[  7339.829] (II) Initializing extension XFIXES
[  7339.829] (II) Initializing extension RENDER
[  7339.829] (II) Initializing extension RANDR
[  7339.829] (II) Initializing extension COMPOSITE
[  7339.829] (II) Initializing extension DAMAGE
[  7339.829] (II) Initializing extension MIT-SCREEN-SAVER
[  7339.829] (II) Initializing extension DOUBLE-BUFFER
[  7339.830] (II) Initializing extension RECORD
[  7339.830] (II) Initializing extension DPMS
[  7339.830] (II) Initializing extension Present
[  7339.830] (II) Initializing extension DRI3
[  7339.830] (II) Initializing extension X-Resource
[  7339.830] (II) Initializing extension XVideo
[  7339.830] (II) Initializing extension XVideo-MotionCompensation
[  7339.830] (II) Initializing extension GLX
[  7339.830] (II) Indirect GLX disabled.
[  7339.830] (II) GLX: Another vendor is already registered for screen 0
[  7339.830] (II) Initializing extension XFree86-VidModeExtension
[  7339.830] (II) Initializing extension XFree86-DGA
[  7339.830] (II) Initializing extension XFree86-DRI
[  7339.830] (II) Initializing extension DRI2
[  7339.830] (II) Initializing extension NV-GLX
[  7339.830] (II) Initializing extension NV-CONTROL
[  7339.830] (II) Initializing extension XINERAMA
[  7339.860] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  7339.860] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  7339.860] (**) Power Button: Applying InputClass "system-keyboard"
[  7339.860] (**) Power Button: Applying InputClass "Keyboard Defaults"
[  7339.860] (II) LoadModule: "libinput"
[  7339.860] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  7339.861] (II) Module libinput: vendor="X.Org Foundation"
[  7339.861] 	compiled for 1.21.1.8, module version = 1.3.0
[  7339.861] 	Module class: X.Org XInput Driver
[  7339.861] 	ABI class: X.Org XInput driver, version 24.4
[  7339.861] (II) Using input driver 'libinput' for 'Power Button'
[  7339.861] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 42 paused 0
[  7339.861] (**) Power Button: always reports core events
[  7339.861] (**) Option "Device" "/dev/input/event1"
[  7339.868] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  7339.868] (II) event1  - Power Button: device is a keyboard
[  7339.868] (II) event1  - Power Button: device removed
[  7339.868] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[  7339.868] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  7339.868] (**) Option "xkb_layout" "us"
[  7339.868] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.880] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  7339.880] (II) event1  - Power Button: device is a keyboard
[  7339.880] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  7339.880] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  7339.880] (**) Power Button: Applying InputClass "system-keyboard"
[  7339.880] (**) Power Button: Applying InputClass "Keyboard Defaults"
[  7339.880] (II) Using input driver 'libinput' for 'Power Button'
[  7339.881] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 45 paused 0
[  7339.881] (**) Power Button: always reports core events
[  7339.881] (**) Option "Device" "/dev/input/event0"
[  7339.881] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  7339.881] (II) event0  - Power Button: device is a keyboard
[  7339.881] (II) event0  - Power Button: device removed
[  7339.881] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  7339.881] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[  7339.881] (**) Option "xkb_layout" "us"
[  7339.881] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.882] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  7339.882] (II) event0  - Power Button: device is a keyboard
[  7339.882] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
[  7339.882] (II) No input driver specified, ignoring this device.
[  7339.882] (II) This device may have been added with another device file.
[  7339.883] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[  7339.883] (II) No input driver specified, ignoring this device.
[  7339.883] (II) This device may have been added with another device file.
[  7339.883] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[  7339.883] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event18)
[  7339.884] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event3)
[  7339.884] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[  7339.884] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[  7339.884] (**) Logitech USB Receiver: Applying InputClass "Keyboard Defaults"
[  7339.884] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[  7339.884] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 46 paused 0
[  7339.884] (**) Logitech USB Receiver: always reports core events
[  7339.884] (**) Option "Device" "/dev/input/event3"
[  7339.885] (II) event3  - Logitech USB Receiver: is tagged by udev as: Keyboard
[  7339.885] (II) event3  - Logitech USB Receiver: device is a keyboard
[  7339.885] (II) event3  - Logitech USB Receiver: device removed
[  7339.885] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.0/0003:046D:C548.0002/input/input3/event3"
[  7339.885] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 8)
[  7339.885] (**) Option "xkb_layout" "us"
[  7339.885] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.886] (II) event3  - Logitech USB Receiver: is tagged by udev as: Keyboard
[  7339.886] (II) event3  - Logitech USB Receiver: device is a keyboard
[  7339.887] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/event4)
[  7339.887] (**) Logitech USB Receiver Mouse: Applying InputClass "libinput pointer catchall"
[  7339.887] (II) Using input driver 'libinput' for 'Logitech USB Receiver Mouse'
[  7339.887] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 47 paused 0
[  7339.887] (**) Logitech USB Receiver Mouse: always reports core events
[  7339.887] (**) Option "Device" "/dev/input/event4"
[  7339.888] (II) event4  - Logitech USB Receiver Mouse: is tagged by udev as: Mouse
[  7339.888] (II) event4  - Logitech USB Receiver Mouse: device is a pointer
[  7339.888] (II) event4  - Logitech USB Receiver Mouse: device removed
[  7339.888] (II) libinput: Logitech USB Receiver Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[  7339.888] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.1/0003:046D:C548.0003/input/input4/event4"
[  7339.888] (II) XINPUT: Adding extended input device "Logitech USB Receiver Mouse" (type: MOUSE, id 9)
[  7339.888] (**) Option "AccelerationScheme" "none"
[  7339.888] (**) Logitech USB Receiver Mouse: (accel) selected scheme none/0
[  7339.888] (**) Logitech USB Receiver Mouse: (accel) acceleration factor: 2.000
[  7339.888] (**) Logitech USB Receiver Mouse: (accel) acceleration threshold: 4
[  7339.889] (II) event4  - Logitech USB Receiver Mouse: is tagged by udev as: Mouse
[  7339.889] (II) event4  - Logitech USB Receiver Mouse: device is a pointer
[  7339.889] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/mouse0)
[  7339.890] (II) No input driver specified, ignoring this device.
[  7339.890] (II) This device may have been added with another device file.
[  7339.890] (II) config/udev: Adding input device Logitech USB Receiver Consumer Control (/dev/input/event5)
[  7339.890] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7339.890] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[  7339.890] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[  7339.890] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[  7339.891] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 48 paused 0
[  7339.891] (**) Logitech USB Receiver Consumer Control: always reports core events
[  7339.891] (**) Option "Device" "/dev/input/event5"
[  7339.891] (II) event5  - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[  7339.891] (II) event5  - Logitech USB Receiver Consumer Control: device is a keyboard
[  7339.891] (II) event5  - Logitech USB Receiver Consumer Control: device removed
[  7339.891] (II) libinput: Logitech USB Receiver Consumer Control: needs a virtual subdevice
[  7339.891] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.1/0003:046D:C548.0003/input/input5/event5"
[  7339.891] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: MOUSE, id 10)
[  7339.892] (**) Option "AccelerationScheme" "none"
[  7339.892] (**) Logitech USB Receiver Consumer Control: (accel) selected scheme none/0
[  7339.892] (**) Logitech USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[  7339.892] (**) Logitech USB Receiver Consumer Control: (accel) acceleration threshold: 4
[  7339.892] (II) event5  - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[  7339.892] (II) event5  - Logitech USB Receiver Consumer Control: device is a keyboard
[  7339.893] (II) config/udev: Adding input device Logitech USB Receiver System Control (/dev/input/event7)
[  7339.893] (**) Logitech USB Receiver System Control: Applying InputClass "libinput keyboard catchall"
[  7339.893] (**) Logitech USB Receiver System Control: Applying InputClass "system-keyboard"
[  7339.893] (**) Logitech USB Receiver System Control: Applying InputClass "Keyboard Defaults"
[  7339.893] (II) Using input driver 'libinput' for 'Logitech USB Receiver System Control'
[  7339.893] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 49 paused 0
[  7339.893] (**) Logitech USB Receiver System Control: always reports core events
[  7339.893] (**) Option "Device" "/dev/input/event7"
[  7339.894] (II) event7  - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[  7339.894] (II) event7  - Logitech USB Receiver System Control: device is a keyboard
[  7339.894] (II) event7  - Logitech USB Receiver System Control: device removed
[  7339.894] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.1/0003:046D:C548.0003/input/input6/event7"
[  7339.894] (II) XINPUT: Adding extended input device "Logitech USB Receiver System Control" (type: KEYBOARD, id 11)
[  7339.894] (**) Option "xkb_layout" "us"
[  7339.894] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.895] (II) event7  - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[  7339.895] (II) event7  - Logitech USB Receiver System Control: device is a keyboard
[  7339.896] (II) config/udev: Adding input device Logitech G304 (/dev/input/event8)
[  7339.896] (**) Logitech G304: Applying InputClass "libinput pointer catchall"
[  7339.896] (**) Logitech G304: Applying InputClass "libinput keyboard catchall"
[  7339.896] (**) Logitech G304: Applying InputClass "system-keyboard"
[  7339.896] (**) Logitech G304: Applying InputClass "Keyboard Defaults"
[  7339.896] (II) Using input driver 'libinput' for 'Logitech G304'
[  7339.896] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 50 paused 0
[  7339.896] (**) Logitech G304: always reports core events
[  7339.896] (**) Option "Device" "/dev/input/event8"
[  7339.897] (II) event8  - Logitech G304: is tagged by udev as: Keyboard Mouse
[  7339.897] (II) event8  - Logitech G304: device is a pointer
[  7339.897] (II) event8  - Logitech G304: device is a keyboard
[  7339.897] (II) event8  - Logitech G304: device removed
[  7339.897] (II) libinput: Logitech G304: Step value 0 was provided, libinput Fallback acceleration function is used.
[  7339.897] (II) libinput: Logitech G304: needs a virtual subdevice
[  7339.897] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-2/7-2:1.2/0003:046D:C53F.0007/0003:046D:4074.000D/input/input35/event8"
[  7339.897] (II) XINPUT: Adding extended input device "Logitech G304" (type: MOUSE, id 12)
[  7339.897] (**) Option "AccelerationScheme" "none"
[  7339.898] (**) Logitech G304: (accel) selected scheme none/0
[  7339.898] (**) Logitech G304: (accel) acceleration factor: 2.000
[  7339.898] (**) Logitech G304: (accel) acceleration threshold: 4
[  7339.898] (II) event8  - Logitech G304: is tagged by udev as: Keyboard Mouse
[  7339.898] (II) event8  - Logitech G304: device is a pointer
[  7339.898] (II) event8  - Logitech G304: device is a keyboard
[  7339.899] (II) config/udev: Adding input device Logitech G304 (/dev/input/mouse1)
[  7339.899] (**) Logitech G304: Applying InputClass "system-keyboard"
[  7339.899] (**) Logitech G304: Applying InputClass "Keyboard Defaults"
[  7339.899] (II) No input driver specified, ignoring this device.
[  7339.899] (II) This device may have been added with another device file.
[  7339.899] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard (/dev/input/event23)
[  7339.899] (**) HOLTEK USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[  7339.899] (**) HOLTEK USB-HID Keyboard: Applying InputClass "system-keyboard"
[  7339.899] (**) HOLTEK USB-HID Keyboard: Applying InputClass "Keyboard Defaults"
[  7339.899] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard'
[  7339.900] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 51 paused 0
[  7339.900] (**) HOLTEK USB-HID Keyboard: always reports core events
[  7339.900] (**) Option "Device" "/dev/input/event23"
[  7339.901] (II) event23 - HOLTEK USB-HID Keyboard: is tagged by udev as: Keyboard
[  7339.901] (II) event23 - HOLTEK USB-HID Keyboard: device is a keyboard
[  7339.901] (II) event23 - HOLTEK USB-HID Keyboard: device removed
[  7339.901] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-3/7-3:1.0/0003:04D9:A131.0009/input/input24/event23"
[  7339.901] (II) XINPUT: Adding extended input device "HOLTEK USB-HID Keyboard" (type: KEYBOARD, id 13)
[  7339.901] (**) Option "xkb_layout" "us"
[  7339.901] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.902] (II) event23 - HOLTEK USB-HID Keyboard: is tagged by udev as: Keyboard
[  7339.902] (II) event23 - HOLTEK USB-HID Keyboard: device is a keyboard
[  7339.902] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard Mouse (/dev/input/event24)
[  7339.902] (**) HOLTEK USB-HID Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[  7339.902] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard Mouse'
[  7339.903] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 52 paused 0
[  7339.903] (**) HOLTEK USB-HID Keyboard Mouse: always reports core events
[  7339.903] (**) Option "Device" "/dev/input/event24"
[  7339.904] (II) event24 - HOLTEK USB-HID Keyboard Mouse: is tagged by udev as: Mouse
[  7339.904] (II) event24 - HOLTEK USB-HID Keyboard Mouse: device is a pointer
[  7339.904] (II) event24 - HOLTEK USB-HID Keyboard Mouse: device removed
[  7339.904] (II) libinput: HOLTEK USB-HID Keyboard Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[  7339.904] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-3/7-3:1.2/0003:04D9:A131.000A/input/input25/event24"
[  7339.904] (II) XINPUT: Adding extended input device "HOLTEK USB-HID Keyboard Mouse" (type: MOUSE, id 14)
[  7339.904] (**) Option "AccelerationScheme" "none"
[  7339.904] (**) HOLTEK USB-HID Keyboard Mouse: (accel) selected scheme none/0
[  7339.904] (**) HOLTEK USB-HID Keyboard Mouse: (accel) acceleration factor: 2.000
[  7339.904] (**) HOLTEK USB-HID Keyboard Mouse: (accel) acceleration threshold: 4
[  7339.905] (II) event24 - HOLTEK USB-HID Keyboard Mouse: is tagged by udev as: Mouse
[  7339.905] (II) event24 - HOLTEK USB-HID Keyboard Mouse: device is a pointer
[  7339.905] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard Mouse (/dev/input/mouse2)
[  7339.905] (II) No input driver specified, ignoring this device.
[  7339.905] (II) This device may have been added with another device file.
[  7339.906] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard System Control (/dev/input/event25)
[  7339.906] (**) HOLTEK USB-HID Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[  7339.906] (**) HOLTEK USB-HID Keyboard System Control: Applying InputClass "system-keyboard"
[  7339.906] (**) HOLTEK USB-HID Keyboard System Control: Applying InputClass "Keyboard Defaults"
[  7339.906] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard System Control'
[  7339.906] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 53 paused 0
[  7339.906] (**) HOLTEK USB-HID Keyboard System Control: always reports core events
[  7339.906] (**) Option "Device" "/dev/input/event25"
[  7339.907] (II) event25 - HOLTEK USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[  7339.907] (II) event25 - HOLTEK USB-HID Keyboard System Control: device is a keyboard
[  7339.907] (II) event25 - HOLTEK USB-HID Keyboard System Control: device removed
[  7339.907] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-3/7-3:1.2/0003:04D9:A131.000A/input/input26/event25"
[  7339.907] (II) XINPUT: Adding extended input device "HOLTEK USB-HID Keyboard System Control" (type: KEYBOARD, id 15)
[  7339.907] (**) Option "xkb_layout" "us"
[  7339.907] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.908] (II) event25 - HOLTEK USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[  7339.908] (II) event25 - HOLTEK USB-HID Keyboard System Control: device is a keyboard
[  7339.909] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard Consumer Control (/dev/input/event26)
[  7339.909] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7339.909] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  7339.909] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[  7339.909] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard Consumer Control'
[  7339.909] (II) systemd-logind: got fd for /dev/input/event26 13:90 fd 54 paused 0
[  7339.909] (**) HOLTEK USB-HID Keyboard Consumer Control: always reports core events
[  7339.909] (**) Option "Device" "/dev/input/event26"
[  7339.910] (II) event26 - HOLTEK USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[  7339.910] (II) event26 - HOLTEK USB-HID Keyboard Consumer Control: device is a keyboard
[  7339.910] (II) event26 - HOLTEK USB-HID Keyboard Consumer Control: device removed
[  7339.910] (II) libinput: HOLTEK USB-HID Keyboard Consumer Control: needs a virtual subdevice
[  7339.910] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-3/7-3:1.2/0003:04D9:A131.000A/input/input27/event26"
[  7339.910] (II) XINPUT: Adding extended input device "HOLTEK USB-HID Keyboard Consumer Control" (type: MOUSE, id 16)
[  7339.910] (**) Option "AccelerationScheme" "none"
[  7339.910] (**) HOLTEK USB-HID Keyboard Consumer Control: (accel) selected scheme none/0
[  7339.910] (**) HOLTEK USB-HID Keyboard Consumer Control: (accel) acceleration factor: 2.000
[  7339.910] (**) HOLTEK USB-HID Keyboard Consumer Control: (accel) acceleration threshold: 4
[  7339.911] (II) event26 - HOLTEK USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[  7339.911] (II) event26 - HOLTEK USB-HID Keyboard Consumer Control: device is a keyboard
[  7339.911] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard (/dev/input/event27)
[  7339.911] (II) No input driver specified, ignoring this device.
[  7339.911] (II) This device may have been added with another device file.
[  7339.912] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard (/dev/input/event28)
[  7339.912] (**) HOLTEK USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[  7339.912] (**) HOLTEK USB-HID Keyboard: Applying InputClass "system-keyboard"
[  7339.912] (**) HOLTEK USB-HID Keyboard: Applying InputClass "Keyboard Defaults"
[  7339.912] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard'
[  7339.912] (II) systemd-logind: got fd for /dev/input/event28 13:92 fd 55 paused 0
[  7339.912] (**) HOLTEK USB-HID Keyboard: always reports core events
[  7339.913] (**) Option "Device" "/dev/input/event28"
[  7339.913] (II) event28 - HOLTEK USB-HID Keyboard: is tagged by udev as: Keyboard
[  7339.913] (II) event28 - HOLTEK USB-HID Keyboard: device is a keyboard
[  7339.913] (II) event28 - HOLTEK USB-HID Keyboard: device removed
[  7339.913] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-3/7-3:1.2/0003:04D9:A131.000A/input/input29/event28"
[  7339.913] (II) XINPUT: Adding extended input device "HOLTEK USB-HID Keyboard" (type: KEYBOARD, id 17)
[  7339.913] (**) Option "xkb_layout" "us"
[  7339.913] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.914] (II) event28 - HOLTEK USB-HID Keyboard: is tagged by udev as: Keyboard
[  7339.914] (II) event28 - HOLTEK USB-HID Keyboard: device is a keyboard
[  7339.915] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event12)
[  7339.915] (II) No input driver specified, ignoring this device.
[  7339.915] (II) This device may have been added with another device file.
[  7339.915] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event15)
[  7339.915] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event17)
[  7339.915] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event19)
[  7339.915] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event20)
[  7339.916] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event21)
[  7339.916] (II) No input driver specified, ignoring this device.
[  7339.916] (II) This device may have been added with another device file.
[  7339.916] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event22)
[  7339.916] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event6)
[  7339.916] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  7339.916] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[  7339.916] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[  7339.916] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[  7339.917] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 56 paused 0
[  7339.917] (**) Eee PC WMI hotkeys: always reports core events
[  7339.917] (**) Option "Device" "/dev/input/event6"
[  7339.917] (II) event6  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  7339.917] (II) event6  - Eee PC WMI hotkeys: device is a keyboard
[  7339.917] (II) event6  - Eee PC WMI hotkeys: device removed
[  7339.917] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input7/event6"
[  7339.917] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 18)
[  7339.917] (**) Option "xkb_layout" "us"
[  7339.917] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.918] (II) event6  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  7339.918] (II) event6  - Eee PC WMI hotkeys: device is a keyboard
[  7339.918] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[  7339.918] (II) No input driver specified, ignoring this device.
[  7339.918] (II) This device may have been added with another device file.
[  7339.921] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7339.921] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[  7339.921] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[  7339.921] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[  7339.921] (II) systemd-logind: returning pre-existing fd for /dev/input/event5 13:69
[  7339.921] (**) Logitech USB Receiver Consumer Control: always reports core events
[  7339.921] (**) Option "Device" "/dev/input/event5"
[  7339.921] (II) libinput: Logitech USB Receiver Consumer Control: is a virtual subdevice
[  7339.921] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.1/0003:046D:C548.0003/input/input5/event5"
[  7339.921] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: KEYBOARD, id 19)
[  7339.921] (**) Option "xkb_layout" "us"
[  7339.921] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7339.921] (**) Logitech G304: Applying InputClass "libinput pointer catchall"
[  7339.921] (**) Logitech G304: Applying InputClass "libinput keyboard catchall"
[  7339.921] (**) Logitech G304: Applying InputClass "system-keyboard"
[  7339.921] (**) Logitech G304: Applying InputClass "Keyboard Defaults"
[  7339.921] (II) Using input driver 'libinput' for 'Logitech G304'
[  7339.921] (II) systemd-logind: returning pre-existing fd for /dev/input/event8 13:72
[  7339.921] (**) Logitech G304: always reports core events
[  7339.921] (**) Option "Device" "/dev/input/event8"
[  7339.921] (II) libinput: Logitech G304: is a virtual subdevice
[  7339.921] (II) libinput: Logitech G304: Step value 0 was provided, libinput Fallback acceleration function is used.
[  7339.921] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-2/7-2:1.2/0003:046D:C53F.0007/0003:046D:4074.000D/input/input35/event8"
[  7339.921] (II) XINPUT: Adding extended input device "Logitech G304" (type: KEYBOARD, id 20)
[  7339.922] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  7339.922] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  7339.922] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[  7339.922] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard Consumer Control'
[  7339.922] (II) systemd-logind: returning pre-existing fd for /dev/input/event26 13:90
[  7339.922] (**) HOLTEK USB-HID Keyboard Consumer Control: always reports core events
[  7339.922] (**) Option "Device" "/dev/input/event26"
[  7339.922] (II) libinput: HOLTEK USB-HID Keyboard Consumer Control: is a virtual subdevice
[  7339.922] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-3/7-3:1.2/0003:04D9:A131.000A/input/input27/event26"
[  7339.922] (II) XINPUT: Adding extended input device "HOLTEK USB-HID Keyboard Consumer Control" (type: KEYBOARD, id 21)
[  7339.922] (**) Option "xkb_layout" "us"
[  7339.922] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[  7340.057] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7340.057] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[  7340.057] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[  7340.057] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7340.057] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7340.057] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7340.057] (--) NVIDIA(GPU-0): DFP-2: disconnected
[  7340.057] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[  7340.057] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[  7340.150] (--) NVIDIA(GPU-0): BenQ GW2283 (DFP-3): connected
[  7340.150] (--) NVIDIA(GPU-0): BenQ GW2283 (DFP-3): Internal TMDS
[  7340.150] (--) NVIDIA(GPU-0): BenQ GW2283 (DFP-3): 300.0 MHz maximum pixel clock
[  7340.150] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  7340.150] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[  7340.150] (--) NVIDIA(GPU-0): DFP-4: 2660.0 MHz maximum pixel clock
[  7340.150] (--) NVIDIA(GPU-0): DFP-5: disconnected
[  7340.150] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[  7340.150] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[  7340.150] (--) NVIDIA(GPU-0): DFP-6: disconnected
[  7340.150] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[  7340.150] (--) NVIDIA(GPU-0): DFP-6: 2660.0 MHz maximum pixel clock
[  7342.965] (**) Option "fd" "42"
[  7342.966] (II) event1  - Power Button: device removed
[  7342.966] (**) Option "fd" "45"
[  7342.966] (II) event0  - Power Button: device removed
[  7342.966] (**) Option "fd" "46"
[  7342.966] (II) event3  - Logitech USB Receiver: device removed
[  7342.966] (**) Option "fd" "47"
[  7342.966] (II) event4  - Logitech USB Receiver Mouse: device removed
[  7342.966] (**) Option "fd" "48"
[  7342.966] (**) Option "fd" "49"
[  7342.966] (II) event7  - Logitech USB Receiver System Control: device removed
[  7342.966] (**) Option "fd" "50"
[  7342.967] (**) Option "fd" "51"
[  7342.967] (II) event23 - HOLTEK USB-HID Keyboard: device removed
[  7342.967] (**) Option "fd" "52"
[  7342.967] (II) event24 - HOLTEK USB-HID Keyboard Mouse: device removed
[  7342.967] (**) Option "fd" "53"
[  7342.967] (II) event25 - HOLTEK USB-HID Keyboard System Control: device removed
[  7342.967] (**) Option "fd" "54"
[  7342.967] (**) Option "fd" "55"
[  7342.967] (II) event28 - HOLTEK USB-HID Keyboard: device removed
[  7342.967] (**) Option "fd" "56"
[  7342.967] (II) event6  - Eee PC WMI hotkeys: device removed
[  7342.967] (**) Option "fd" "48"
[  7342.967] (II) event5  - Logitech USB Receiver Consumer Control: device removed
[  7342.968] (**) Option "fd" "50"
[  7342.968] (II) event8  - Logitech G304: device removed
[  7342.968] (**) Option "fd" "54"
[  7342.968] (II) event26 - HOLTEK USB-HID Keyboard Consumer Control: device removed
[  7343.186] (II) systemd-logind: got pause for 13:68
[  7343.186] (II) systemd-logind: got pause for 13:92
[  7343.186] (II) systemd-logind: got pause for 13:89
[  7343.186] (II) systemd-logind: got pause for 13:72
[  7343.186] (II) systemd-logind: got pause for 13:65
[  7343.186] (II) systemd-logind: got pause for 13:87
[  7343.186] (II) systemd-logind: got pause for 13:64
[  7343.186] (II) systemd-logind: got pause for 13:67
[  7343.186] (II) systemd-logind: got pause for 13:90
[  7343.186] (II) systemd-logind: got pause for 13:88
[  7343.186] (II) systemd-logind: got pause for 13:70
[  7343.186] (II) systemd-logind: got pause for 13:69
[  7343.186] (II) systemd-logind: got pause for 13:71
[  8024.565] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/mouse0)
[  8024.576] (II) No input driver specified, ignoring this device.
[  8024.576] (II) This device may have been added with another device file.
[  8024.576] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard Mouse (/dev/input/mouse2)
[  8024.594] (II) This device may have been added with another device file.
[  8024.595] (II) config/udev: Adding input device Logitech G304 (/dev/input/mouse1)
[  8024.595] (**) Logitech G304: Applying InputClass "system-keyboard"
[  8024.595] (**) Logitech G304: Applying InputClass "Keyboard Defaults"
[  8024.595] (II) No input driver specified, ignoring this device.
[  8024.595] (II) This device may have been added with another device file.
[  8024.595] (II) config/udev: removing device Power Button
[  8024.596] (II) UnloadModule: "libinput"
[  8024.596] (II) systemd-logind: releasing fd for 13:65
[  8024.626] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  8024.626] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  8024.626] (**) Power Button: Applying InputClass "system-keyboard"
[  8024.626] (**) Power Button: Applying InputClass "Keyboard Defaults"
[  8024.626] (II) Using input driver 'libinput' for 'Power Button'
[  8024.629] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 29 paused 1
[  8024.629] (II) systemd-logind: releasing fd for 13:65
[  8024.679] (II) config/udev: removing device Power Button
[  8024.679] (II) UnloadModule: "libinput"
[  8024.679] (II) systemd-logind: releasing fd for 13:64
[  8024.716] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  8024.716] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  8024.716] (**) Power Button: Applying InputClass "system-keyboard"
[  8024.716] (**) Power Button: Applying InputClass "Keyboard Defaults"
[  8024.716] (II) Using input driver 'libinput' for 'Power Button'
[  8024.716] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 29 paused 1
[  8024.716] (II) systemd-logind: releasing fd for 13:64
[  8024.755] (II) config/udev: removing device Eee PC WMI hotkeys
[  8024.756] (II) UnloadModule: "libinput"
[  8024.756] (II) systemd-logind: releasing fd for 13:70
[  8024.836] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event6)
[  8024.836] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  8024.836] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[  8024.836] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[  8024.836] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[  8024.836] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 29 paused 1
[  8024.836] (II) systemd-logind: releasing fd for 13:70
[  8024.902] (II) config/udev: removing device Logitech USB Receiver Consumer Control
[  8024.902] (II) UnloadModule: "libinput"
[  8024.902] (II) systemd-logind: not releasing fd for 13:69, still in use
[  8024.903] (II) UnloadModule: "libinput"
[  8024.903] (II) systemd-logind: releasing fd for 13:69
[  8024.923] (II) config/udev: Adding input device Logitech USB Receiver Consumer Control (/dev/input/event5)
[  8024.923] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[  8024.923] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[  8024.923] (**) Logitech USB Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[  8024.923] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[  8024.923] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 29 paused 1
[  8024.923] (II) systemd-logind: releasing fd for 13:69
[  8024.959] (II) config/udev: removing device Logitech USB Receiver System Control
[  8024.959] (II) UnloadModule: "libinput"
[  8024.959] (II) systemd-logind: releasing fd for 13:71
[  8024.989] (II) config/udev: Adding input device Logitech USB Receiver System Control (/dev/input/event7)
[  8024.990] (**) Logitech USB Receiver System Control: Applying InputClass "libinput keyboard catchall"
[  8024.990] (**) Logitech USB Receiver System Control: Applying InputClass "system-keyboard"
[  8024.990] (**) Logitech USB Receiver System Control: Applying InputClass "Keyboard Defaults"
[  8024.990] (II) Using input driver 'libinput' for 'Logitech USB Receiver System Control'
[  8024.990] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 29 paused 1
[  8024.990] (II) systemd-logind: releasing fd for 13:71
[  8025.009] (II) config/udev: removing device HOLTEK USB-HID Keyboard Mouse
[  8025.010] (II) UnloadModule: "libinput"
[  8025.010] (II) systemd-logind: releasing fd for 13:88
[  8025.056] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard Mouse (/dev/input/event24)
[  8025.056] (**) HOLTEK USB-HID Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[  8025.056] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard Mouse'
[  8025.056] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 29 paused 1
[  8025.056] (II) systemd-logind: releasing fd for 13:88
[  8025.129] (II) config/udev: removing device Logitech USB Receiver Mouse
[  8025.130] (II) UnloadModule: "libinput"
[  8025.130] (II) systemd-logind: releasing fd for 13:68
[  8025.203] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/event4)
[  8025.203] (**) Logitech USB Receiver Mouse: Applying InputClass "libinput pointer catchall"
[  8025.203] (II) Using input driver 'libinput' for 'Logitech USB Receiver Mouse'
[  8025.204] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 29 paused 1
[  8025.204] (II) systemd-logind: releasing fd for 13:68
[  8025.265] (II) config/udev: removing device HOLTEK USB-HID Keyboard
[  8025.266] (II) UnloadModule: "libinput"
[  8025.266] (II) systemd-logind: releasing fd for 13:92
[  8025.319] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard (/dev/input/event28)
[  8025.319] (**) HOLTEK USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[  8025.319] (**) HOLTEK USB-HID Keyboard: Applying InputClass "system-keyboard"
[  8025.319] (**) HOLTEK USB-HID Keyboard: Applying InputClass "Keyboard Defaults"
[  8025.319] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard'
[  8025.320] (II) systemd-logind: got fd for /dev/input/event28 13:92 fd 29 paused 1
[  8025.320] (II) systemd-logind: releasing fd for 13:92
[  8025.366] (II) config/udev: removing device Logitech USB Receiver
[  8025.366] (II) UnloadModule: "libinput"
[  8025.366] (II) systemd-logind: releasing fd for 13:67
[  8025.410] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event3)
[  8025.410] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[  8025.410] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[  8025.410] (**) Logitech USB Receiver: Applying InputClass "Keyboard Defaults"
[  8025.410] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[  8025.410] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 29 paused 1
[  8025.410] (II) systemd-logind: releasing fd for 13:67
[  8025.452] (II) config/udev: removing device HOLTEK USB-HID Keyboard System Control
[  8025.452] (II) UnloadModule: "libinput"
[  8025.452] (II) systemd-logind: releasing fd for 13:89
[  8025.503] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard System Control (/dev/input/event25)
[  8025.503] (**) HOLTEK USB-HID Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[  8025.503] (**) HOLTEK USB-HID Keyboard System Control: Applying InputClass "system-keyboard"
[  8025.503] (**) HOLTEK USB-HID Keyboard System Control: Applying InputClass "Keyboard Defaults"
[  8025.503] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard System Control'
[  8025.503] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 29 paused 1
[  8025.503] (II) systemd-logind: releasing fd for 13:89
[  8025.552] (II) config/udev: removing device HOLTEK USB-HID Keyboard
[  8025.552] (II) UnloadModule: "libinput"
[  8025.552] (II) systemd-logind: releasing fd for 13:87
[  8025.596] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard (/dev/input/event23)
[  8025.596] (**) HOLTEK USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[  8025.596] (**) HOLTEK USB-HID Keyboard: Applying InputClass "system-keyboard"
[  8025.596] (**) HOLTEK USB-HID Keyboard: Applying InputClass "Keyboard Defaults"
[  8025.596] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard'
[  8025.596] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 29 paused 1
[  8025.596] (II) systemd-logind: releasing fd for 13:87
[  8025.646] (II) config/udev: removing device HOLTEK USB-HID Keyboard Consumer Control
[  8025.646] (II) UnloadModule: "libinput"
[  8025.646] (II) systemd-logind: not releasing fd for 13:90, still in use
[  8025.646] (II) systemd-logind: releasing fd for 13:90
[  8025.686] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard Consumer Control (/dev/input/event26)
[  8025.686] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  8025.686] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  8025.686] (**) HOLTEK USB-HID Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[  8025.686] (II) Using input driver 'libinput' for 'HOLTEK USB-HID Keyboard Consumer Control'
[  8025.687] (II) systemd-logind: got fd for /dev/input/event26 13:90 fd 29 paused 1
[  8025.687] (II) systemd-logind: releasing fd for 13:90
[  8025.722] (II) config/udev: removing device Logitech G304
[  8025.722] (II) UnloadModule: "libinput"
[  8025.722] (II) systemd-logind: not releasing fd for 13:72, still in use
[  8025.723] (II) UnloadModule: "libinput"
[  8025.723] (II) systemd-logind: releasing fd for 13:72
[  8025.756] (II) config/udev: Adding input device Logitech G304 (/dev/input/event8)
[  8025.756] (**) Logitech G304: Applying InputClass "libinput pointer catchall"
[  8025.756] (**) Logitech G304: Applying InputClass "libinput keyboard catchall"
[  8025.756] (**) Logitech G304: Applying InputClass "system-keyboard"
[  8025.756] (**) Logitech G304: Applying InputClass "Keyboard Defaults"
[  8025.756] (II) Using input driver 'libinput' for 'Logitech G304'
[  8025.757] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 29 paused 1
[  8025.757] (II) systemd-logind: releasing fd for 13:72
[  8025.799] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event12)
[  8025.799] (II) No input driver specified, ignoring this device.
[  8025.799] (II) This device may have been added with another device file.
[  8025.799] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event21)
[  8025.800] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[  8025.800] (II) No input driver specified, ignoring this device.
[  8025.800] (II) This device may have been added with another device file.
[  8025.800] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[  8025.800] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
[  8025.801] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event15)
[  8025.801] (II) No input driver specified, ignoring this device.
[  8025.801] (II) This device may have been added with another device file.
[  8025.801] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event17)
[  8025.801] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event18)
[  8025.801] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event19)
[  8025.802] (II) config/udev: Adding input device HOLTEK USB-HID Keyboard (/dev/input/event27)
[  8025.802] (II) No input driver specified, ignoring this device.
[  8025.802] (II) This device may have been added with another device file.
[  8025.802] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event22)
[  8025.803] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event20)
[  8025.803] (II) No input driver specified, ignoring this device.
[  8025.803] (II) This device may have been added with another device file.
[  8025.803] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[  8091.269] (II) NVIDIA(GPU-0): Deleting GPU-0
[  8091.269] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[  8091.269] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[  8092.820] (II) Server terminated successfully (0). Closing log file.
Hello @frost19k :wink:
Well it runs Wayland, not Xorg. That would be Xorg:
 Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell v: 44.1 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: virtio_gpu gpu: virtio-pci display-ID: :0
    screens: 1
and it is known that Wayland and Nvidia is not stable.
Apologies, I wasn’t clear.
I was running Xorg. I would prefer to run Xorg. But I have switched over to Wayland for the time being because Wayland isn’t crashing. Wayland is actually proving to be more stable on Nvidia than Xorg!
The journalctl output is from when I was on Xorg.
Well actually Gnome-Shell crashed and not X. Are you sure the Xorg.0.log is current? At least there is no crash visible.
To my knowledge, Gnome doesn’t write any Xorg log in /var/log, but writes it into ~/.local/share/xorg/, since gnome-shell runs as user. GDM writes it into the journal, since it runs as root.
Please share this:
journalctl --boot 0 --grep "\([A-Z]{2}\)"
cat ~/.local/share/xorg/Xorg.0.log
Oh! :sweat_smile:
I modified the journalctl command you asked for, since the current boot hasn’t crashed & so there’s nothing in there…
❯ journalctl --boot 0 --grep "\([A-Z]{2}\)"
Jul 16 08:57:53 manjaro-ws NetworkManager[740]: <info>  [1689478073.1209] device (wlp5s0): driver supports Access Point (AP) mode
Links to gist (I exceeded the character limit here) :yum:
Journal from previous boot.
Journal from boot before previous.
Xorg log from ~/.local/share.
P.S. Heading out for a bit. I’ll check your response when I get home in the evening.
No problem, but as you see also. X has zero problems. There are no problems either in gdm or in gnome-shell.
So the issue must be something specific related to the gnome-shell. An extension or modification? You would know it better. To exclude that, disable all extensions and use a clean new account for testing.
About that a short note: Xorg handles inputs indirectly, through the server, but on wayland programs which capture input devices cannot ask the server like on xorg, they need direct access. You could try to add yourself to the input group. That helped with virt-manager and ShadowPC at least. Maybe that helps you also? :man_shrugging:
sudo usermod -aG input $USER
# re-login
And maybe also:
echo 'KERNEL=="uinput", MODE="0660", GROUP="input"' | sudo tee /etc/udev/rules.d/65-uinput.rules
reboot
I’m going to join in here because I think we might have much the same problem. I’m running Manjaro Cinnamon with all updates. I was just using the built in Intel video, but when I switch the KVM over to one of the other machines for a few hours, I would come back and the monitors would be dead. [F4] would get me to the one line boot screen about checking disk, but could not get to any terminal that would issue a login prompt. Could not use [F1] to get back to desktop either.
This is an I7-gen6 so I thought maybe the onboard video was going bad. Stuck in an NVidia card. Been having the exact same problem for months. I notice it more because I’m in a VM on a Windows machine working on RedDiamond and it can be a day or two before I come back. Sometimes this happens within half an hour.
I have swapped out cables and tried everything. If I have the KVM set to this machine, I can leave for the evening/weekend, come back, wiggle the mouse, and have the monitors leap to life. I have even swapped the video card with another machine running Manjaro using the same NVidia card and not having problems. In defense of that machine though, I’m not toggling over with its KVM because the project using the other machine is currently over.
Is there a log file somewhere (that will survive reboot) that can be checked to see why the monitors went away?
It’s like the power settings detect idle, test for presence of a monitor, don’t find it, and kill the desktop. The monitors aren’t shut down obviously because I can rotate to the initial boot line.
While we have vastly different symptoms, I think we have the same problem.
I want nothing to do with Wayland.
So I turned off all of my extensions, as advised & then I noticed that the functionality provided by gnome-shell-extension-bluetooth-quick-connect has been added to Gnome!!! I suspect this extension is the issue. I haven’t had a crash yet, so fingers crossed.
Wrt. VMWare on Wayland - Manjaro already put me in the input group. So that wasn’t the issue.
About the udev rule, should the string be more like 'KERNEL=="uinput", MODE="0660", GROUP="input"'? In yours the quote isn’t terminated…
You are right, I forgot it. Corrected above. :wink:
Well, it is good that there is an issue, but preferable would be seeing what happens before it crashes… :slight_smile: So what causes the crash?
See this:
I have Firefox running with two tabs. One’s this forum & the other is Reddit. I also have a terminal running with btop. That’s about it from the user side (at least when the last crash occured).
Crashes seem to be more frequent when the GPU load is high-ish. Watching videos on YouTube or running VMs makes it crash multiple times.
System Services
  accounts-daemon.service        loaded active running Accounts Service
  acpid.service        loaded active running ACPI event daemon
  bluetooth.service        loaded active running Bluetooth service
  bolt.service        loaded active running Thunderbolt system service
  colord.service        loaded active running Manage, Install and Generate Color Profiles
  dbus.service        loaded active running D-Bus System Message Bus
  docker.service        loaded active running Docker Application Container Engine
  gdm.service        loaded active running GNOME Display Manager
  geoclue.service        loaded active running Location Lookup Service
  kmod-static-nodes.service        loaded active exited  Create List of Static Device Nodes
  lvm2-monitor.service        loaded active exited  Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
  NetworkManager-wait-online.service                                                        loaded active exited  Network Manager Wait Online
  NetworkManager.service        loaded active running Network Manager
  polkit.service        loaded active running Authorization Manager
  power-profiles-daemon.service                                                             loaded active running Power Profiles daemon
  rtkit-daemon.service        loaded active running RealtimeKit Scheduling Policy Service
  systemd-binfmt.service        loaded active exited  Set Up Additional Binary Formats
  systemd-fsck@dev-disk-by\x2duuid-1b6abc10\x2de095\x2d4be6\x2d94e4\x2db928bb8af032.service loaded active exited  File System Check on /dev/disk/by-uuid/1b6abc10-e095-4be6-94e4-b928bb8af032
  systemd-fsck@dev-disk-by\x2duuid-354bced9\x2d3fe8\x2d446c\x2dab4f\x2d280cd69f5e71.service loaded active exited  File System Check on /dev/disk/by-uuid/354bced9-3fe8-446c-ab4f-280cd69f5e71
  systemd-fsck@dev-disk-by\x2duuid-440ca7ab\x2d4a34\x2d4116\x2d870a\x2dc3412882c19b.service loaded active exited  File System Check on /dev/disk/by-uuid/440ca7ab-4a34-4116-870a-c3412882c19b
  systemd-fsck@dev-disk-by\x2duuid-445358e3\x2d6f37\x2d4096\x2d9c85\x2d43f37f4fd7e9.service loaded active exited  File System Check on /dev/disk/by-uuid/445358e3-6f37-4096-9c85-43f37f4fd7e9
  systemd-fsck@dev-disk-by\x2duuid-9619\x2dD24E.service                                     loaded active exited  File System Check on /dev/disk/by-uuid/9619-D24E
  systemd-fsck@dev-disk-by\x2duuid-cfc61f4b\x2df937\x2d4513\x2db491\x2de958ae39d86a.service loaded active exited  File System Check on /dev/disk/by-uuid/cfc61f4b-f937-4513-b491-e958ae39d86a
  systemd-journal-flush.service                                                             loaded active exited  Flush Journal to Persistent Storage
  systemd-journald.service        loaded active running Journal Service
  systemd-logind.service        loaded active running User Login Management
  systemd-modules-load.service                                                              loaded active exited  Load Kernel Modules
  systemd-random-seed.service                                                               loaded active exited  Load/Save OS Random Seed
  systemd-remount-fs.service        loaded active exited  Remount Root and Kernel File Systems
  systemd-sysctl.service        loaded active exited  Apply Kernel Variables
  systemd-timesyncd.service        loaded active running Network Time Synchronization
  systemd-tmpfiles-setup-dev.service                                                        loaded active exited  Create Static Device Nodes in /dev
  systemd-tmpfiles-setup.service                                                            loaded active exited  Create Volatile Files and Directories
  systemd-udev-trigger.service                                                              loaded active exited  Coldplug All udev Devices
  systemd-udevd.service        loaded active running Rule-based Manager for Device Events and Files
  systemd-update-utmp.service                                                               loaded active exited  Record System Boot/Shutdown in UTMP
  systemd-user-sessions.service                                                             loaded active exited  Permit User Sessions
  udisks2.service        loaded active running Disk Manager
  upower.service        loaded active running Daemon for power management
  user-runtime-dir@1000.service                                                             loaded active exited  User Runtime Directory /run/user/1000
  user@1000.service        loaded active running User Manager for UID 1000
  vmware-networks.service        loaded active running VMware Networks
  vmware-usbarbitrator.service                                                              loaded active running VMware USB Arbitrator
  wpa_supplicant.service        loaded active running WPA supplicant
User services
  at-spi-dbus-bus.service                             loaded active running Accessibility services bus
  dbus.service                                        loaded active running D-Bus User Message Bus
  dconf.service                                       loaded active running User preferences database
  evolution-addressbook-factory.service               loaded active running Evolution address book service
  evolution-calendar-factory.service                  loaded active running Evolution calendar service
  evolution-source-registry.service                   loaded active running Evolution source registry
  gnome-keyring-daemon.service                        loaded active running GNOME Keyring daemon
  gnome-session-manager@gnome.service                 loaded active running GNOME Session Manager (session: gnome)
  gnome-session-monitor.service                       loaded active running Monitor Session leader for GNOME Session
  gnome-terminal-server.service                       loaded active running GNOME Terminal Server
  gpg-agent.service                                   loaded active running GnuPG cryptographic agent and passphrase cache
  gvfs-daemon.service                                 loaded active running Virtual filesystem service
  gvfs-metadata.service                               loaded active running Virtual filesystem metadata service
  gvfs-udisks2-volume-monitor.service                 loaded active running Virtual filesystem service - disk device monitor
  obex.service                                        loaded active running Bluetooth OBEX service
  org.freedesktop.IBus.session.GNOME.service          loaded active running IBus Daemon for GNOME
  org.gnome.SettingsDaemon.A11ySettings.service       loaded active running GNOME accessibility service
  org.gnome.SettingsDaemon.Color.service              loaded active running GNOME color management service
  org.gnome.SettingsDaemon.Datetime.service           loaded active running GNOME date & time service
  org.gnome.SettingsDaemon.Housekeeping.service       loaded active running GNOME maintenance of expirable data service
  org.gnome.SettingsDaemon.Keyboard.service           loaded active running GNOME keyboard configuration service
  org.gnome.SettingsDaemon.MediaKeys.service          loaded active running GNOME keyboard shortcuts service
  org.gnome.SettingsDaemon.Power.service              loaded active running GNOME power management service
  org.gnome.SettingsDaemon.PrintNotifications.service loaded active running GNOME printer notifications service
  org.gnome.SettingsDaemon.Rfkill.service             loaded active running GNOME RFKill support service
  org.gnome.SettingsDaemon.ScreensaverProxy.service   loaded active running GNOME FreeDesktop screensaver service
  org.gnome.SettingsDaemon.Sharing.service            loaded active running GNOME file sharing service
  org.gnome.SettingsDaemon.Smartcard.service          loaded active running GNOME smartcard service
  org.gnome.SettingsDaemon.Sound.service              loaded active running GNOME sound sample caching service
  org.gnome.SettingsDaemon.UsbProtection.service      loaded active running GNOME USB protection service
  org.gnome.SettingsDaemon.Wacom.service              loaded active running GNOME Wacom tablet support service
  org.gnome.SettingsDaemon.XSettings.service          loaded active running GNOME XSettings service
  org.gnome.Shell@x11.service                         loaded active running GNOME Shell on X11
  pipewire-pulse.service                              loaded active running PipeWire PulseAudio
  pipewire.service                                    loaded active running PipeWire Multimedia Service
  surfsharkd.service                                  loaded active running Surfshark Daemon
  syncthing.service                                   loaded active running Syncthing - Open Source Continuous File Synchronization
  tracker-miner-fs-3.service                          loaded active running Tracker file system data miner
  wireplumber.service                                 loaded active running Multimedia Service Session Manager
  xdg-desktop-portal-gnome.service                    loaded active running Portal service (GNOME implementation)
  xdg-desktop-portal-gtk.service                      loaded active running Portal service (GTK/GNOME implementation)
  xdg-desktop-portal.service                          loaded active running Portal service
  xdg-document-portal.service                         loaded active running flatpak document portal service
  xdg-permission-store.service                        loaded active running sandboxed app permission store
/etc/X11/mhwd.d/nvidia.conf
❯ cat /etc/X11/mhwd.d/nvidia.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 535.54.03
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "BenQ GW2283"
    HorizSync       30.0 - 83.0
    VertRefresh     50.0 - 76.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "Quadro RTX 4000"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-3"
    Option         "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
/etc/modprobe.d/nvidia.conf
options nvidia-drm modeset=1
options nvidia NVreg_EnableBacklightHandler=0
options nvidia NVreg_PreserveVideoMemoryAllocations=1
options nvidia NVreg_RestrictProfilingToAdminUsers=0
options nvidia NVreg_TemporaryFilePath=/var/tmp
See this:
Are you referring to this lne The error was 'BadMatch (invalid parameter attributes)'.?
I’m really sorry, but I don’t know what to make of that :yum:
In simple words: A program sends an unknown request code to the xserver which let it crash immediately. A request could such like “Create Window” or “Copy to clipboard”, but in your case it is unknown.
As you see here OPCode 128-255 are reserved for extensions of xorg and are non-standardized (every driver can do its own stuff here). Now you should know which extension commonly use 147, it could be also one of the nvidia extensions.
It’s caffeine that’s causing the crash. Specifically disabling caffeine (once activated).
My current solution is to simply not use caffeine, so if anyone has a better solution I’m all ears.
I suggest the Caffeine GNOME Shell extension.
