Hi there,
all open applications in a gnome session (example: browser + email + editor + file manager and so on) do not come back after a cycle of sleep/resume. What I experience:
- put the system on sleep
- I wake it up with mouse (or power button)
- I see a garbaged graphic screen (sort of old TV screen no signal noise)
- after a few sec gdm come up with “lock screen”
- I login, but session is lost
Suggestions/ideas how to solve it?
Thanks! ![]()
Here my inxi:
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: root=UUID=6847c1da-8688-4a03-a8cc-2378d1af3dbd rw quiet
splash udev.log_priority=3 initrd=\boot\initramfs-6.6-x86_64.img
Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Apple product: iMac12,1 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-942B5BF58194151B
Mobo: Apple model: Mac-942B5BF58194151B serial: <superuser required>
uuid: <superuser required> UEFI: Apple v: 87.0.0.0.0 date: 06/14/2019
Device-1: hid-10:9a:dd:91:c7:dc-battery model: rednose’s Keyboard
serial: N/A charge: N/A status: discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX
Anywhere 2S serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: discharging
System RAM: total: 4 GiB available: 3.81 GiB used: 2.57 GiB (67.4%)
Array-1: capacity: 16 GiB slots: 4 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: DIMM0 type: DDR3 detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: N/A width: N/A manufacturer: 0x02FE
part-no: 0x45424A3231554538424655302D444A2D4620 serial: <filter>
Device-2: DIMM0 type: DDR3 detail: synchronous size: 2 GiB
Device-3: DIMM1 type: no module installed
Device-4: DIMM1 type: no module installed
Info: model: Intel Core i5-2400S bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1600 min/max: 1600/3300 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 20009
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
driver: i915 v: kernel arch: Gen-6 code: Sandybridge process: Intel 32nm
built: 2011 ports: active: none empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0102 class-ID: 0380
Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: Apple driver: radeon v: kernel alternate: amdgpu arch: TeraScale-2
code: Evergreen process: TSMC 32-40nm built: 2009-15 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, VGA-2 bus-ID: 01:00.0
chip-ID: 1002:6741 class-ID: 0300
Device-3: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:3 chip-ID: 05ac:850b
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: modesetting,radeon
alternate: fbdev,vesa dri: r600,crocus gpu: radeon display-ID: 0
Monitor-1: eDP-1 model: Apple iMac built: 2010 res: 1920x1080 dpi: 103
gamma: 1.2 size: 475x267mm (18.7x10.51") diag: 545mm (21.5") ratio: 16:9
modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: intel crocus drv: amd r600 platforms: device: 0
drv: r600 device: 1 drv: crocus device: 2 drv: swrast gbm: drv: crocus
surfaceless: drv: r600 wayland: drv: r600 x11: drv: r600
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD TURKS (DRM 2.50.0 /
6.6.10-1-MANJARO LLVM 16.0.6) device-ID: 1002:6741 memory: 500 MiB
unified: no display-ID: :0.0
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
class-ID: 0403
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: Apple driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.1
chip-ID: 1002:aa90 class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
vendor: Apple AirPort Extreme driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
IF-ID-1: de-dus-wg-001 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> type: noprefixroute scope: global
IP v6: <filter> type: noprefixroute scope: global
Device-1: Apple Built-in Bluetooth 2.0+EDR HCI driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1.1:6
chip-ID: 05ac:8215 class-ID: fe01 serial: <filter>
Local Storage: total: 2.27 TiB used: 870.7 GiB (37.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AP2A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST2000LM003 HN-M201RAD
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400
serial: <filter> fw-rev: 1153 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRW GA32N rev: KE06
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 59.58 GiB size: 58.34 GiB (97.92%) used: 21.41 GiB (36.7%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: Manjaro
uuid: 6847c1da-8688-4a03-a8cc-2378d1af3dbd
ID-2: /boot/efi raw-size: 316.7 MiB size: 316.1 MiB (99.79%)
used: 13.9 MiB (4.4%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: BOOT EFI
uuid: E785-8807
ID-3: /mnt/iMac-home raw-size: 325.96 GiB size: 325.96 GiB (100.00%)
used: 246.37 GiB (75.6%) fs: hfsplus dev: /dev/sda2 maj-min: 8:2
label: Macintosh HD uuid: e3e72228-72b6-3548-ac52-91c2143992b6
ID-4: /run/media/rednose/MXlinux raw-size: 59.51 GiB
size: 58.28 GiB (97.92%) used: 15.91 GiB (27.3%) fs: ext4 dev: /dev/sda5
maj-min: 8:5 label: MXlinux uuid: dd8f79b6-fd8e-4102-a957-3b0d830d047e
ID-5: /run/media/rednose/Media raw-size: 653.28 GiB
size: 653.28 GiB (100.00%) used: 587.01 GiB (89.9%) fs: hfsplus
dev: /dev/sdb5 maj-min: 8:21 label: Media
uuid: 73a461b9-208e-3535-a90d-e024e11158d3
ID-1: swap-1 type: partition size: 19.23 GiB used: 2 MiB (0.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 9504eab5-5e87-4353-930e-ac9aa30fc1c8
ID-1: /dev/sda1 maj-min: 8:1 size: 200 MiB fs: vfat label: EFI
uuid: 2860-11F4
ID-2: /dev/sda3 maj-min: 8:3 size: 619.9 MiB fs: hfsplus
label: Recovery HD uuid: 9db3ecb9-8192-3e57-99bd-5a2711e45985
ID-3: /dev/sdb1 maj-min: 8:17 size: 200 MiB fs: vfat label: EFI
uuid: 67E3-17ED
ID-4: /dev/sdb2 maj-min: 8:18 size: 1.05 TiB fs: hfsplus label: Backup
uuid: 376c5d99-47a8-3623-b2ef-c499bac3e7a0
ID-5: /dev/sdb3 maj-min: 8:19 size: 59.6 GiB fs: ext4 label: old-linuxA
uuid: 125db090-52a2-4b2e-9e02-29da443ef894
ID-6: /dev/sdb4 maj-min: 8:20 size: 59.6 GiB fs: ext4 label: old-linuxB
uuid: e78c05ab-4fc6-4fee-8174-442a179958bb
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-3: 2-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 0424:2514 class-ID: 0900
Hub-4: 2-1.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 2-1.1.1:6 info: Apple Built-in Bluetooth 2.0+EDR HCI
type: bluetooth driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 05ac:8215
Device-2: 2-1.2:5 info: LaCie Rugged THB USB 3.0 type: mass storage
driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 059f:1075 class-ID: 0806 serial: <filter>
Device-3: 2-2:3 info: Apple FaceTime HD Camera (Built-in) type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05ac:850b class-ID: 0e02
serial: <filter>
Hub-5: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-6: 4-0:1 info: full speed or root hub ports: 8 rev: 2.0
Hub-7: 4-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
Device-1: 4-1.1:3 info: Apple Internal Memory Card Reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 05ac:8403 class-ID: 0806 serial: <filter>
Device-2: 4-1.2:4 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
Device-3: 4-1.4:5 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1199
Processes: 244 Power: uptime: 2h 34m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 1.51 GiB
daemons: upowerd,gsd-power Init: systemd v: 255 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1018 libs: 312 tools: gnome-software,pamac
Compilers: gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: terminator inxi: 3.3.32
