Hi.
Just updated some gnome extensions, and the search on the activities overview is now broken.
Just displays “searching…”
Don’ t know what happened in the forum, because i lost my registration and some posts don’ t exist anymore?
Turn off extentions .see if that helps ( might need reboot) if that fix it then add one extentions at a time to find out which one is the problem… 99% of the time it extension that cause problem…
normally it dash to dock or Arc menu … i try them 1st if you have installed
You were right. I disabled first one, still same. Then the other, still same. Restarted, search was working. Enabled both, one by one, restarded and all is working now.
Thank you
glad i could help …
