After the Manjaro update, I can’t stop the screen recorder Ctrl+Alt+Shift+R , and the color of the icon has also turned orange, and I even reset the duration to 30 seconds but it still happened.
thanks for your answers.
Hello @ammar_salahi
There is a problem with ffmpeg and libvpx, which also cause a problem with gnome screen recorder: [Solved] gnome screen recorder doesn't stop, produces blank file / Applications & Desktop Environments / Arch Linux Forums
https://bugs.archlinux.org/task/70182
https://bugs.archlinux.org/task/70184
I have the same problem, but never used this feature. No idea how to solve this here on stable branch. Maybe on testing or unstable branch it works again?
You should be able to kill it with:
killall gjs
If it’s fixed in Arch stable, it’s fixed in Manjaro unstable
