This doesn’t seem to make any difference set to on or off. No applications ever are listed as gaining camera access. Used Cheese, Guvcviw and Zoom & the camera security setting seems unimplimented.
Fabby
25 March 2021 00:15
2
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
(especially the last section on “Upstream” and “Downstream”) and then file a bug here …
I can file a bug report with the best of them… do you think this IS a bug? Worth reporting?
Seems to be a point of discussion here…
