Can't perform system update - dependencies problems?
Hello, I’m not that knowledgeable, I’m try to perform a system update, but I get stuck during installation from the konsole. I can usually update normally, don’t understand what’s happening now.
Any help is much appreciated. I’m pasting what’s happening during the install. It might provide clues for people that know more.
Thanks!
 core        146.8 KiB   367 KiB/s 00:00 [############################################################################] 100%
 extra        8.6 MiB  9.33 MiB/s 00:01 [############################################################################] 100%
 multilib        145.2 KiB  2.12 MiB/s 00:00 [############################################################################] 100%
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n] y
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n] y
warning: kpeoplevcard: local (0.1+r38.32d50a9-1) is newer than extra (0.1-2)
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n] y
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n] y
resolving dependencies...
:: installing kpeople5 (5.111.0-1) breaks dependency 'kpeople' required by kpeoplevcard
:: installing kcontacts5 (5.111.0-1) breaks dependency 'kcontacts' required by kpeoplevcard
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Hi @pao, and welcome!
:bangbang: Tip: :bangbang:
In the future, when posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
*phew*
What a mouth full…
Anyway, I’d solve it by uninstalling kpeoplevcard:
pamac remove kpeoplevcard
Doing the update:
pamac upgrade --no-aur
Reinstalling kpeoplevcard:
pamac install kpeoplevcard
And then rebuilding all AUR packages:
pamac upgrade --aur
Hope this helps!
Hi Mirdarthos!
Thanks for replying to fast. Appreciate your education. Let me put it to practice.
pamac remove kdsoap kirigami-addons kuserfeedback libqaccessibilityclient         1 ✘
Preparing...
Checking dependencies...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing kuserfeedback breaks dependency 'kuserfeedback' required by dolphin
- removing kirigami-addons breaks dependency 'kirigami-addons' required by kdeconnect
- removing kdsoap breaks dependency 'kdsoap' required by kdsoap-ws-discovery-client
- removing libqaccessibilityclient breaks dependency 'libqaccessibilityclient' required by kwin
Unfortunately, as you can see, your suggestion didn’t work for me.
Is there another way to sort this?
Thank you so much for your help.
Pao
The suggestion was just to remove the one package. Not these other 4.
You didnt follow the suggestion at all. :sweat_smile:
Then again, I dont think you should.
Instead:
sudo pacman -Syuu
Given that this was part of the update announcements from 11-06, I’m going to assume you will run into others as well.
Per usual check that thread and/or use the search button in the top right. :mag:
( Of course assuming you want these packages that is … I dont have it installed on my plasma :person_shrugging: )
Please read Announcements posts:
