Hi, i’m new to Manjaro and i’m dualbooting it with Windows (on separate drives), the install went as intended and everything seemed to be fine but while booting on Manjaro the loading dots seem to be offset with my screen and then leads to a black screen with a gray bar at the bottom, sometimes even loading the login screen but only showing a black screen after logging in. Trying to solve it at some point i changed the boot parameters from this:
BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
root=UUID=b29cde72-45ce-4663-bb0e-7b3275f86c67 rw quiet splash apparmor=1
to this:
root=UUID=b29cde72-45ce-4663-bb0e-7b3275f86c67 rw 3 splash apparmor=1
and then it booted without the gnome interface, i then logged in and used “startx” and the interface just started normally. sometimes it won’t start and i’ll have to shut the computer down manually, sometimes after using it thru “startx” when shutting down/rebooting the computer it results in GPU Error 0 going on endlessly and me having to shut the computer down manually too.
I’ll post my system info since it might be usefull:
“inxi -Fazv7” output:
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Avell High Performance product: Avell G1555 MUV / A62
v: Standard serial: <superuser required>
Mobo: Avell High Performance model: Avell G1555 MUV / A62 v: Standard
serial: <superuser required> UEFI: American Megatrends v: N.1.03
date: 08/19/2019
RAM: total: 15.48 GiB used: 2.48 GiB (16.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2600 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 2600 2: 2600 3: 2600 4: 2600 5: 2600 6: 2600
7: 2600 8: 2600 9: 2600 10: 2600 11: 2600 12: 2600 bogomips: 62431
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Tongfang Hongkong driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Tongfang Hongkong driver: nvidia v: 525.85.05
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0300
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5
chip-ID: 5986:9101 class-ID: 0e02
Display: server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x0747 built: 2017 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 19.41 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWL110
type: HDD rpm: 5400 serial: <filter> rev: 0A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: BIWIN model: SSD size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 9A0 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 19.41 GiB (2.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b29cde72-45ce-4663-bb0e-7b3275f86c67
used: 316 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 6A28-C6DA
ID-1: /dev/sdb1 maj-min: 8:17 size: 499 MiB fs: ntfs
label: Recupera\xc3\xa7\xc3\xa3o uuid: A460486160483C74
ID-2: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
uuid: C648-7B31
ID-3: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb4 maj-min: 8:20 size: 476.34 GiB fs: ntfs label: N/A
uuid: E026524E265225B6
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-6:3 info: Integrated Express ITE Device(8291)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:ce00 class-ID: 0300
Device-3: 1-12:4 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-4: 1-13:5 info: Acer HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9101
class-ID: 0e02
Device-5: 1-14:7 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 61.0 C pch: 65.0 C mobo: N/A
Processes: 300 Uptime: 10m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1302 libs: 319 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.24
“mhwd -l -li” output:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1f91) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
Thanks in advance and sorry if anything is wrong with the post, it’s my first time here.
