A new spam appeared in my journal log. It starts exactly after one hour of the boot time and repeats every hour. I didn’t remember what change I did recently. I don’t have a cron work repeating or don’t know any program I set to work every hour.
How can I determine what calls the warning? What info I need?
Network manager script dispatcher service
part of the logs may be irrelevant because it repeats every half an hour and just coincides every hour with gnome-keyring-daemon
warning.
journalctl -b:
Nis 22 02:36:38 ceres-pc gnome-keyring-daemon[567]: asked to register item /org/freedesktop/secrets/collection/Default_5fkeyring/4, but it's already registered
Nis 22 02:36:39 ceres-pc NetworkManager[391]: <info> [1619048199.7714] dhcp4 (wlp2s0): state changed extended -> extended, address=192.168.1.39
Nis 22 02:36:39 ceres-pc dbus-daemon[390]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=391 comm="/usr/bin/NetworkManager --no-daemon ")
Nis 22 02:36:39 ceres-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
Nis 22 02:36:39 ceres-pc dbus-daemon[390]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nis 22 02:36:39 ceres-pc systemd[1]: Started Network Manager Script Dispatcher Service.
Nis 22 02:36:49 ceres-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Nis 22 19:36:39 ceres-pc gnome-keyring-daemon[567]: asked to register item /org/freedesktop/secrets/collection/Default_5fkeyring/4, but it's already registered
Nis 22 19:36:39 ceres-pc NetworkManager[391]: <info> [1619109399.7754] dhcp4 (wlp2s0): state changed extended -> extended, address=192.168.1.39
Nis 22 19:36:39 ceres-pc dbus-daemon[390]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=391 comm="/usr/bin/NetworkManager --no-daemon ")
Nis 22 19:36:39 ceres-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
Nis 22 19:36:39 ceres-pc dbus-daemon[390]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nis 22 19:36:39 ceres-pc systemd[1]: Started Network Manager Script Dispatcher Service.
Nis 22 19:36:50 ceres-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
inxi:
System: Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=6b0569e6-71a6-459e-99cc-ac225fe06b91 rw
intel_pstate=active udev.log_priority=3 audit=0 ec_sys.write_support=1 sysrq_always_enabled=1
systemd.unified_cgroup_hierarchy=true mitigations=off noibrs noibpb no_stf_barrier tsx=on
resume=/dev/disk/by-uuid/19a0c71e-ed32-45ea-8489-9e31e24b22d7
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: plank wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: Acer product: Aspire S3-391 v: V2.17 serial: <filter>
Mobo: Acer model: Hummingbird2 v: V2.17 serial: <filter> UEFI-[Legacy]: Insyde v: 2.17 date: 07/18/2013
Battery: ID-1: BAT0 charge: 32.6 Wh (100.0%) condition: 32.6/35.5 Wh (91.7%) volts: 12.4 min: 11.1 model: SANYO AP11D3F
type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525 serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13568
Speed: 798 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Acer Incorporated ALI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 3-4:3 chip-ID: 04f2:b33b class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 120 size: 290x160mm (11.4x6.3") diag: 331mm (13")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.0.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Network: Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Foxconn driver: ath9k v: kernel port: 2040
bus-ID: 02:00.0 chip-ID: 168c:0034 class-ID: 0280
Bluetooth: Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-1.4:5 chip-ID: 0489:e056 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 2.1 lmp-v: 4.0 sub-v: 1 hci-v: 4.1 rev: 1102
Info: acl-mtu: 1022:8 sco-mtu: 183:5 link-policy: rswitch hold sniff link-mode: slave accept
service-classes: rendering, capturing, object transfer, audio
Drives: Local Storage: total: 223.57 GiB used: 134.75 GiB (60.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37240G size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 87RA scheme: MBR
Partition: ID-1: / raw-size: 182.62 GiB size: 178.75 GiB (97.88%) used: 130.37 GiB (72.9%) fs: ext4 dev: /dev/sda2
maj-min: 8:2
Swap: Kernel: swappiness: 80 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.38 GiB used: 4.39 GiB (52.3%) priority: -2 dev: /dev/sda3 maj-min: 8:3
Sensors: System Temperatures: cpu: 56.0 C mobo: 51.0 C
Info: Processes: 214 Uptime: 18h 20m wakeups: 36 Memory: 3.67 GiB used: 3.16 GiB (86.1%) Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1828 lib: 467 Shell: Bash v: 5.1.0 running-in: konsole
inxi: 3.3.04
