Hello everyone, I just upgraded my Manjaro Gnome today and I noticed a new feature in gnome settings, the power settings give me two options: “Energy Save” and “Balanced” but don’t show something like “Performance” or “High Performance”… should I worry? It’s not a laptop
inxi -Fxz ✔
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 41.1 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2006 date: 11/13/2019
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 cache: L2: 3 MiB
bogomips: 81469
Speed: 1516 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 1516 2: 2827 3: 3791 4: 1516 5: 3791 6: 1516 7: 3788 8: 1516 9: 1516
10: 2178 11: 3792 12: 2031
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 08:00.0
Display: x11 server: X.Org 1.21.1.1 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 1920x1080~70Hz
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.41.0
5.13.19-2-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 91.97 GiB (20.6%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 58.76 GiB used: 19.89 GiB (33.9%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 196.9 MiB used: 274 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 344.23 GiB used: 72.08 GiB (20.9%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) file: /swapfile1
System Temperatures: cpu: 53.8 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1126
Processes: 323 Uptime: 44m Memory: 15.56 GiB used: 3.17 GiB (20.4%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1244
Shell: Zsh v: 5.8 inxi: 3.3.08
