Gnome Freezing Shortly and becoming then sluggish after hitting activities
I had this or at least a similar problem when using pop os. I switched partly also from pop os to get a more stable expierence. Weirdly this problem still exists, at least in a very similar manner.
The Problem:
When I hit the super key sometimes the screen goes blank (in Manjaro gray) but the top bar stays visible. This view freezes then for a brief time. Then I can see that the gnome shell reloads. Often then the response becomes sluggish and slightly stuttery.
I checked the journal output and I suspect this being related to the freezing.
Attempting to call back into JSAPI during the sweeping phase of GC. This is most likely caused by not destroying a Clutter actor or Gtk+ widget with ::destroy signals connected, but can also be caused by using the destroy(), dispose(), or remove() vfuncs. Because it would crash the application, it has been blocked and the JS callback not invoked.
Let me know what information I can provide to get make this problem clearer to you.
Hi and welcome to the forum :partying_face:
Providing the basics system information, a more detailed journal output at the time this behavior occurs and a list of active extensions would help others help you diagnose. Start here:
Thanks for the very warm welcoming <3
I’ll do my best to provide you with all information needed:
  • Intel i7 8700k
  • Nvidia RTX 2080ti
  • 3 Monitor Setup (1080p vertical, 1440p 144hz, 1080p)
xrandr:
Screen 0: minimum 8 x 8, current 5560 x 1920, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected 1080x1920+0+0 right (normal left inverted right x axis y axis) 598mm x 336mm
   1920x1080     60.00*+
   1680x1050     59.95
   1440x900      59.89
   1280x1024     75.02    60.02
   1280x960      60.00
   1280x720      60.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   640x480       75.00    72.81    59.94
HDMI-0 connected (normal left inverted right x axis y axis)
   3840x2160     60.00 +  59.94    50.00    29.97    25.00    23.98
   4096x2160     59.94    50.00    24.00    23.98
   1920x1080    119.88   100.00    60.00    59.94    50.00    29.97    23.98
   1680x1050     59.95
   1600x900      60.00
   1280x1024     60.02
   1280x720      60.00    59.94    50.00    29.97    23.98
   1152x864      75.00
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       59.94
   640x480       59.94
DP-2 connected primary 2560x1440+1080+0 (normal left inverted right x axis y axis) 697mm x 392mm
   2560x1440    144.00*+ 120.00    99.95    59.95
   1920x1080     60.00    59.94    50.00
   1680x1050     59.95
   1600x900      60.00
   1440x900      59.89
   1280x800      59.81
   1152x864      75.00
   720x576       50.00
   720x480       59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected 1920x1080+3640+0 (normal left inverted right x axis y axis) 600mm x 340mm
   3840x2160     60.00 +  30.00
   2560x1440     59.95
   1920x1080     60.00*   59.94
   1600x900      60.00
   1280x1024     60.02
   1280x800      59.81
   1152x864      59.96
   1024x768      60.00
   800x600       60.32
   720x480       59.94
   640x480       59.94    59.93
DP-5 disconnected (normal left inverted right x axis y axis)
USB-C-0 disconnected (normal left inverted right x axis y axis)
Gnome-Extensions:
  • appindicatorsupport
  • gnome-ui-tune
  • places-menu
  • apps-menu
  • gsconnect
  • screenshot-window-sizer
  • arcmenu
  • gtk4-ding
  • user-theme
  • auto-move-windows
  • launch-new-instance
  • window-list
  • custom-accent-colors
  • legacyschemeautoswitcher
  • windowsNavigator
  • dash-to-dock
  • material-shell
  • workspace-indicator
  • dash-to-panel
  • native-window-placement
  • drive-menu
  • pamac-updates
What is the preferred way to share longer logfiles? Since there is quite a lot of output at the suspected time 14:09:17.
Mär 14 14:09:17 thomasdesktop gnome-shell[1243]: Attempting to call back into JSAPI during the sweeping phase of GC. This is most likely caused by not destroying a Clutter actor or Gtk+ widget with ::destroy signals connected, but can also be caused by using the destroy(), dispose(), or remove() vfuncs. Because it would crash the application, it has been blocked and the JS callback not invoked.
Mär 14 14:09:17 thomasdesktop gnome-shell[1243]: == Stack trace for context 0x561cb4547170 ==
Mär 14 14:09:17 thomasdesktop gnome-shell[1243]: #0   7ffcdcf8add0 b   resource:///org/gnome/shell/ui/workspace.js:1355 (220ff46c33d0 @ 94)
Mär 14 14:09:17 thomasdesktop gnome-shell[1243]: #1   7ffcdcf8b7f0 I   resource:///org/gnome/shell/ui/windowPreview.js:345 (220ff46c3bf0 @ 822)
Mär 14 14:09:17 thomasdesktop gnome-shell[1243]: #2   7ffcdcf8b8b0 b   resource:///org/gnome/shell/ui/windowPreview.js:551 (220ff46c42e0 @ 18)
Mär 14 14:09:17 thomasdesktop gnome-shell[1243]: The offending signal was notify on MetaStage 0x561cb44dbaa0.
Please let me know if I can provide any more useful information. Thanks again for the very kind response.
Thanks for the data so far, could you add the output of inxi -v7azy so users have a better Idea of the system you run and how it is configured.
The snippet you posted earlier is generated by gnome-shell that is good to know.
The issue looks like a problem with a extension to me, but the log in not clear enough to point to a specific one. One way to check what is causing the freeze/sluggishness is to disable extensions and try to recreate, that way, you can check if it is extension related.
Another way to check if extensions are the cause is to use the Projects/GnomeShell/LookingGlass - GNOME Wiki! to spy on what the extensions are doing and if there are errors reported.
Sharing large logfiles:
One more datapoint that is usefull:
Reboot & share the output of journalctl --boot --priority=3 (this should not be that large) will show errors in the current session. Since you mention having the same on Pop!_OS this might lead to a issue specific to your situation.
A day later my hard drive died. It seemed like my hard drive was causing the issue. I am not sure yet, but having a fresh system on another drive hasn’t shown the issue so far yet. I will keep watching if this is going to happen again.
Given it happens again, I will update on the requested information. If I don’t, then the hard drive must have been to blame here.
The error returns again, so I share the requested info.
  Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=97edd2bb-94d6-46d3-a872-5fc965ae2865 rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Desktop Mobo: ASRock model: Z370 Extreme4 serial: <superuser required>
    UEFI: American Megatrends v: P4.20 date: 10/31/2019
  RAM: total: 15.55 GiB used: 8 GiB (51.4%)
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1041 high: 3700 min/max: 800/4700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 3700 12: 800 bogomips: 88824
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Gigabyte
    driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2023-02) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
  Device-2: Microsoft Microsoft LifeCam HD-5001 type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-11:8 chip-ID: 045e:076e
    class-ID: 0102
  Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 5560x1920 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 pos: left res: 1080x1920 hz: 60 dpi: 82
    size: 336x598mm (13.23x23.54") diag: 686mm (27.01") modes: N/A
  Monitor-2: DP-2 pos: primary,center res: 2560x1440 hz: 144 dpi: 93
    size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
  Monitor-3: DP-4 pos: right res: 1920x1080 hz: 60 dpi: 81
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  Monitor-4: HDMI-0 size-res: N/A modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX 2080
    Ti/PCIe/SSE2 direct-render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
    bus-ID: 1-11:8 v: kernel bus-ID: 00:1f.3 chip-ID: 045e:076e
    chip-ID: 8086:a2f0 class-ID: 0102 class-ID: 0403
  Device-2: NVIDIA TU102 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Device-3: Microsoft Microsoft LifeCam HD-5001 type: USB
  Device-4: SteelSeries ApS Arctis 7 type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:2 chip-ID: 1038:12ad
    class-ID: 0300
  Device-5: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen type: USB
    driver: snd-usb-audio bus-ID: 1-8:5 chip-ID: 1235:8202 class-ID: 0102
  Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
    bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
  Local Storage: total: 9.2 TiB used: 53.89 GiB (0.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
    model: T-FORCE TM8FP7002T size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: EGFM15.2 temp: 39.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 25.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ABA300
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 5940 serial: <filter> rev: ABB0 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM008-2DM166
    type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD PLUS 480GB
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 04RL
  ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SSD PLUS 1000GB
    size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 00RL scheme: GPT
  ID-7: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: Extreme Pro
    size: 119.25 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> scheme: MBR
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 53.89 GiB (2.9%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 97edd2bb-94d6-46d3-a872-5fc965ae2865
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0272-20F0
  ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 53.89 GiB (2.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 97edd2bb-94d6-46d3-a872-5fc965ae2865
  ID-4: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-5: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A
    uuid: 3603-6811
  ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 465.14 GiB fs: ntfs label: N/A
    uuid: 848E04628E044F5C
  ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 515 MiB fs: ntfs label: N/A
    uuid: 9A7086FF7086E0FD
  ID-5: /dev/sda1 maj-min: 8:1 size: 2.73 TiB fs: ext4 label: Downloads
    uuid: 600f2545-ee83-4a69-b43f-7abef0392218
  ID-6: /dev/sdb1 maj-min: 8:17 size: 2.73 TiB fs: ntfs label: Daten
    uuid: 7B99722B0150EBAA
  ID-7: /dev/sdd1 maj-min: 8:49 size: 300 MiB fs: vfat label: N/A
    uuid: B339-6AAB
  ID-8: /dev/sdd2 maj-min: 8:50 size: 931.22 GiB fs: btrfs label: N/A
    uuid: deedd160-c92d-47ce-b418-48013184ad32
  ID-9: /dev/sde1 maj-min: 8:65 size: 3.8 GiB fs: iso9660
  ID-10: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 7C4D-855A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-2:2 info: SteelSeries ApS Arctis 7 type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 1038:12ad class-ID: 0300
  Hub-2: 1-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-6:4 info: Ducky One 3 TKL type: HID,Keyboard,Mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s power: 100mA
    chip-ID: 3233:8011 class-ID: 0300 serial: <filter>
  Device-2: 1-8:5 info: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
    type: Audio driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s
    power: 500mA chip-ID: 1235:8202 class-ID: 0102
  Device-3: 1-9:6 info: Brother Industries DCP-J562DW
    type: Printer,Mass Storage driver: usb-storage,usblp interfaces: 3 rev: 2.0
    speed: 480 Mb/s power: 2mA chip-ID: 04f9:0380 class-ID: 0806
    serial: <filter>
  Device-4: 1-10:7 info: ROCCAT Kone Pro type: Mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 1e7d:2c88 class-ID: 0300
  Device-5: 1-11:8 info: Microsoft Microsoft LifeCam HD-5001
    type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 045e:076e class-ID: 0102
  Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-6:2 info: SanDisk Extreme Pro type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s chip-ID: 0781:5588
    class-ID: 0806 serial: <filter>
  Hub-4: 2-7:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 49 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
  Processes: 402 Uptime: 2h 25m wakeups: 3 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1356 libs: 305 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.25
It is really difficult to recreate. The issue happens rather randomly when I hit the super key. From what I have noticed this most often happens when there is actually a high load on the system. It happens when I usually press the super key. Instead of getting the overview of all open windows on the screen, the screen goes gray. The gray is very similar to the gdm login background. Also I have noticed, that the only screen going blank is my primary screen with the 144hz.
Looking glass tells me that none of the extensions report any errors.
Further, the error on Pop_OS felt a little different. There gnome restarted completely automatically when this error occured. Here, it only goes blank and everything is either fine afterwards or the gnome shell is unresponsive for a bit (few secs).
Mär 23 14:33:05 dektop kernel: x86/cpu: SGX disabled by BIOS.
Mär 23 14:33:05 dektop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
Mär 23 14:33:05 dektop kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Mär 23 14:33:05 dektop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
Mär 23 14:33:05 dektop kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Mär 23 14:33:06 dektop kernel:
Mär 23 14:33:17 dektop gdm-password][1162]: gkr-pam: unable to locate daemon control file
Mär 23 14:33:19 dektop systemd[1176]: Failed to start Application launched by gnome-session-binary.
Mär 23 14:33:25 dektop gdm-launch-environment][772]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mär 23 14:33:47 dektop pulseaudio[1363]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 23 14:36:32 dektop systemd-coredump[5050]: Process 4589 (gnome-character) of user 1000 dumped core.
                                                Stack trace of thread 4589:
                                                #0  0x00007f07e16a08ec n/a (libc.so.6 + 0x878ec)
                                                #1  0x00007f07e1651ea8 raise (libc.so.6 + 0x38ea8)
                                                #2  0x00007f07e163b53d abort (libc.so.6 + 0x2253d)
                                                #3  0x00007f07e1d6c06a n/a (libglib-2.0.so.0 + 0x1d06a)
                                                #4  0x00007f07e1dc7a90 g_assertion_message_expr (libglib-2.0.so.0 + 0x78a90)
                                                #5  0x00007f07d7c0d03c n/a (libgtk-4.so.1 + 0x40d03c)
                                                #6  0x00007f07e1d10114 g_object_unref (libgobject-2.0.so.0 + 0x22114)
                                                #7  0x00007f07e1ee871e n/a (libgjs.so.0 + 0x5a71e)
                                                #8  0x00007f07e1eeabe0 n/a (libgjs.so.0 + 0x5cbe0)
                                                #9  0x00007f07e1f50f36 n/a (libgjs.so.0 + 0xc2f36)
                                                #10 0x00007f07e1ee8935 n/a (libgjs.so.0 + 0x5a935)
                                                #11 0x00007f07e0e9e9ca n/a (libmozjs-102.so + 0x169e9ca)
                                                #12 0x00007f07e0e9d077 n/a (libmozjs-102.so + 0x169d077)
                                                #13 0x00007f07e1266032 n/a (libmozjs-102.so + 0x1a66032)
                                                #14 0x00007f07e1264d57 n/a (libmozjs-102.so + 0x1a64d57)
                                                #15 0x00007f07e0d23d01 n/a (libmozjs-102.so + 0x1523d01)
                                                #16 0x00007f07e0d20203 n/a (libmozjs-102.so + 0x1520203)
                                                #17 0x00007f07e0d1b276 n/a (libmozjs-102.so + 0x151b276)
                                                #18 0x00007f07e0d19f64 n/a (libmozjs-102.so + 0x1519f64)
                                                #19 0x00007f07e0ed2d76 n/a (libmozjs-102.so + 0x16d2d76)
                                                #20 0x00007f07e1f0b837 n/a (libgjs.so.0 + 0x7d837)
                                                #21 0x00007f07e1da5052 n/a (libglib-2.0.so.0 + 0x56052)
                                                #22 0x00007f07e1da482b g_main_context_dispatch (libglib-2.0.so.0 + 0x5582b)
                                                #23 0x00007f07e1dfbcc9 n/a (libglib-2.0.so.0 + 0xaccc9)
                                                #24 0x00007f07e1da30e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
                                                #25 0x00007f07e1bfe76e g_application_run (libgio-2.0.so.0 + 0xde76e)
                                                #26 0x00007f07e1ad84f6 n/a (libffi.so.8 + 0x74f6)
                                                #27 0x00007f07e1ad4f5e n/a (libffi.so.8 + 0x3f5e)
                                                #28 0x00007f07e1ad7b73 ffi_call (libffi.so.8 + 0x6b73)
                                                #29 0x00007f07e1edc408 n/a (libgjs.so.0 + 0x4e408)
                                                #30 0x00007f07e1edcb28 n/a (libgjs.so.0 + 0x4eb28)
                                                #31 0x00007f07e0a9f6f6 n/a (libmozjs-102.so + 0x129f6f6)
                                                #32 0x00007f07e0df588b n/a (libmozjs-102.so + 0x15f588b)
                                                #33 0x00007f07e0ed3858 n/a (libmozjs-102.so + 0x16d3858)
                                                #34 0x00007f07e1086187 n/a (libmozjs-102.so + 0x1886187)
                                                #35 0x00007f07e1f16d27 n/a (libgjs.so.0 + 0x88d27)
                                                #36 0x00007f07e1f19bb8 gjs_context_eval (libgjs.so.0 + 0x8bbb8)
                                                #37 0x000055b06e54cb3d n/a (gjs-console + 0x2b3d)
                                                #38 0x00007f07e163c790 n/a (libc.so.6 + 0x23790)
                                                #39 0x00007f07e163c84a __libc_start_main (libc.so.6 + 0x2384a)
                                                #40 0x000055b06e54cf05 n/a (gjs-console + 0x2f05)
                                                Stack trace of thread 4598:
                                                #0  0x00007f07e17139df __poll (libc.so.6 + 0xfa9df)
                                                #1  0x00007f07e1dfbc2f n/a (libglib-2.0.so.0 + 0xacc2f)
                                                #2  0x00007f07e1da30e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
                                                #3  0x00007f07e1da3132 n/a (libglib-2.0.so.0 + 0x54132)
                                                #4  0x00007f07e1dd1db5 n/a (libglib-2.0.so.0 + 0x82db5)
                                                #5  0x00007f07e169ebb5 n/a (libc.so.6 + 0x85bb5)
                                                #6  0x00007f07e1720d90 n/a (libc.so.6 + 0x107d90)
                                                Stack trace of thread 4601:
                                                #0  0x00007f07e169b766 n/a (libc.so.6 + 0x82766)
                                                #1  0x00007f07e169df90 pthread_cond_wait (libc.so.6 + 0x84f90)
                                                #2  0x00007f07e0d8e2b1 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x158e2b1)
                                                #3  0x00007f07e0d8e1a3 n/a (libmozjs-102.so + 0x158e1a3)
                                                #4  0x00007f07e0f40eae n/a (libmozjs-102.so + 0x1740eae)
                                                Stack trace of thread 4695:
                                                #3  0x00007f07cba9efde n/a (libdconfsettings.so + 0x5fde)
                                                Stack trace of thread 4606:
                                                Stack trace of thread 4607:
                                                Stack trace of thread 4608:
                                                Stack trace of thread 4602:
                                                Stack trace of thread 4604:
                                                Stack trace of thread 4605:
                                                Stack trace of thread 4603:
                                                Stack trace of thread 4600:
                                                #2  0x00007f07e1da3d8f g_main_loop_run (libglib-2.0.so.0 + 0x54d8f)
                                                #3  0x00007f07e1c2aaec n/a (libgio-2.0.so.0 + 0x10aaec)
                                                Stack trace of thread 4696:
                                                #0  0x00007f07e17190dd syscall (libc.so.6 + 0x1000dd)
                                                #1  0x00007f07e1df53e3 g_cond_wait_until (libglib-2.0.so.0 + 0xa63e3)
                                                #2  0x00007f07e1d72893 n/a (libglib-2.0.so.0 + 0x23893)
                                                #3  0x00007f07e1dd767b n/a (libglib-2.0.so.0 + 0x8867b)
Mär 23 15:42:49 dektop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
Mär 23 15:42:49 dektop kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Mär 23 15:42:49 dektop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
Mär 23 15:42:49 dektop kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Mär 23 16:06:25 dektop pulseaudio[1363]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Mär 23 16:06:25 dektop pulseaudio[1363]: Most likely this is a bug in the ALSA driver 'snd_usb_audio'. Please report this issue to the ALSA developers.
Mär 23 16:06:25 dektop pulseaudio[1363]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Mär 23 16:17:19 dektop systemd-coredump[28743]: Process 28321 (gnome-character) of user 1000 dumped core.
                                                 Stack trace of thread 28321:
                                                 #0  0x00007f779baa08ec n/a (libc.so.6 + 0x878ec)
                                                 #1  0x00007f779ba51ea8 raise (libc.so.6 + 0x38ea8)
                                                 #2  0x00007f779ba3b53d abort (libc.so.6 + 0x2253d)
                                                 #3  0x00007f779c1b906a n/a (libglib-2.0.so.0 + 0x1d06a)
                                                 #4  0x00007f779c214a90 g_assertion_message_expr (libglib-2.0.so.0 + 0x78a90)
                                                 #5  0x00007f779280d03c n/a (libgtk-4.so.1 + 0x40d03c)
                                                 #6  0x00007f779c15d114 g_object_unref (libgobject-2.0.so.0 + 0x22114)
                                                 #7  0x00007f779c33571e n/a (libgjs.so.0 + 0x5a71e)
                                                 #8  0x00007f779c337be0 n/a (libgjs.so.0 + 0x5cbe0)
                                                 #9  0x00007f779c39df36 n/a (libgjs.so.0 + 0xc2f36)
                                                 #10 0x00007f779c335935 n/a (libgjs.so.0 + 0x5a935)
                                                 #11 0x00007f779b29e9ca n/a (libmozjs-102.so + 0x169e9ca)
                                                 #12 0x00007f779b29d077 n/a (libmozjs-102.so + 0x169d077)
                                                 #13 0x00007f779b666032 n/a (libmozjs-102.so + 0x1a66032)
                                                 #14 0x00007f779b664d57 n/a (libmozjs-102.so + 0x1a64d57)
                                                 #15 0x00007f779b123d01 n/a (libmozjs-102.so + 0x1523d01)
                                                 #16 0x00007f779b120203 n/a (libmozjs-102.so + 0x1520203)
                                                 #17 0x00007f779b11b276 n/a (libmozjs-102.so + 0x151b276)
                                                 #18 0x00007f779b119f64 n/a (libmozjs-102.so + 0x1519f64)
                                                 #19 0x00007f779b2d2d76 n/a (libmozjs-102.so + 0x16d2d76)
                                                 #20 0x00007f779c358837 n/a (libgjs.so.0 + 0x7d837)
                                                 #21 0x00007f779c1f2052 n/a (libglib-2.0.so.0 + 0x56052)
                                                 #22 0x00007f779c1f182b g_main_context_dispatch (libglib-2.0.so.0 + 0x5582b)
                                                 #23 0x00007f779c248cc9 n/a (libglib-2.0.so.0 + 0xaccc9)
                                                 #24 0x00007f779c1f00e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
                                                 #25 0x00007f779c04b76e g_application_run (libgio-2.0.so.0 + 0xde76e)
                                                 #26 0x00007f779bf254f6 n/a (libffi.so.8 + 0x74f6)
                                                 #27 0x00007f779bf21f5e n/a (libffi.so.8 + 0x3f5e)
                                                 #28 0x00007f779bf24b73 ffi_call (libffi.so.8 + 0x6b73)
                                                 #29 0x00007f779c329408 n/a (libgjs.so.0 + 0x4e408)
                                                 #30 0x00007f779c329b28 n/a (libgjs.so.0 + 0x4eb28)
                                                 #31 0x00007f779ae9f6f6 n/a (libmozjs-102.so + 0x129f6f6)
                                                 #32 0x00007f779b1f588b n/a (libmozjs-102.so + 0x15f588b)
                                                 #33 0x00007f779b2d3858 n/a (libmozjs-102.so + 0x16d3858)
                                                 #34 0x00007f779b486187 n/a (libmozjs-102.so + 0x1886187)
                                                 #35 0x00007f779c363d27 n/a (libgjs.so.0 + 0x88d27)
                                                 #36 0x00007f779c366bb8 gjs_context_eval (libgjs.so.0 + 0x8bbb8)
                                                 #37 0x0000558f65dc3b3d n/a (gjs-console + 0x2b3d)
                                                 #38 0x00007f779ba3c790 n/a (libc.so.6 + 0x23790)
                                                 #39 0x00007f779ba3c84a __libc_start_main (libc.so.6 + 0x2384a)
                                                 #40 0x0000558f65dc3f05 n/a (gjs-console + 0x2f05)
                                                 Stack trace of thread 28335:
                                                 #0  0x00007f779ba9b766 n/a (libc.so.6 + 0x82766)
                                                 #1  0x00007f779ba9df90 pthread_cond_wait (libc.so.6 + 0x84f90)
                                                 #2  0x00007f779b18e2b1 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x158e2b1)
                                                 #3  0x00007f779b18e1a3 n/a (libmozjs-102.so + 0x158e1a3)
                                                 #4  0x00007f779b340eae n/a (libmozjs-102.so + 0x1740eae)
                                                 #5  0x00007f779ba9ebb5 n/a (libc.so.6 + 0x85bb5)
                                                 #6  0x00007f779bb20d90 n/a (libc.so.6 + 0x107d90)
                                                 Stack trace of thread 28338:
                                                 Stack trace of thread 28337:
                                                 Stack trace of thread 28336:
                                                 Stack trace of thread 28339:
                                                 Stack trace of thread 28340:
                                                 Stack trace of thread 28334:
                                                 Stack trace of thread 28330:
                                                 #0  0x00007f779bb139df __poll (libc.so.6 + 0xfa9df)
                                                 #1  0x00007f779c248c2f n/a (libglib-2.0.so.0 + 0xacc2f)
                                                 #2  0x00007f779c1f00e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
                                                 #3  0x00007f779c1f0132 n/a (libglib-2.0.so.0 + 0x54132)
                                                 #4  0x00007f779c21edb5 n/a (libglib-2.0.so.0 + 0x82db5)
                                                 Stack trace of thread 28332:
                                                 #2  0x00007f779c1f0d8f g_main_loop_run (libglib-2.0.so.0 + 0x54d8f)
                                                 #3  0x00007f779c077aec n/a (libgio-2.0.so.0 + 0x10aaec)
                                                 Stack trace of thread 28381:
                                                 #0  0x00007f779bb190dd syscall (libc.so.6 + 0x1000dd)
                                                 #1  0x00007f779c2423e3 g_cond_wait_until (libglib-2.0.so.0 + 0xa63e3)
                                                 #2  0x00007f779c1bf893 n/a (libglib-2.0.so.0 + 0x23893)
                                                 #3  0x00007f779c1bfa37 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23a37)
                                                 #4  0x00007f779c2244c6 n/a (libglib-2.0.so.0 + 0x884c6)
                                                 #5  0x00007f779c21edb5 n/a (libglib-2.0.so.0 + 0x82db5)
                                                 #6  0x00007f779ba9ebb5 n/a (libc.so.6 + 0x85bb5)
                                                 #7  0x00007f779bb20d90 n/a (libc.so.6 + 0x107d90)
                                                 Stack trace of thread 28415:
                                                 #3  0x00007f779011cfde n/a (libdconfsettings.so + 0x5fde)
                                                 Stack trace of thread 28333:
Mär 23 16:58:19 dektop sudo[48648]:   thomas : a password is required ; TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/sbin/file -s /dev/nvme1n1p2
Note that the time stamps don’t relate to the occurence of the error. The error hasn’t appeared at the displayed times.
Setting up some swap would be a a good idea, if it happens under load the system might want to use it and when not needed it will not be used.
The error log does not show any glaring issues that I can tell, all are harmless or expected or just happen sometimes, if interested paste them in a search engine and lose some hours of your life.
The ACPI error could be caused by a older BIOS, then again, it might just be that, a bug in the BIOS that might be fixed, might not. Updating might help, read the release notes if it could help. I have a asrock MB and have not updated since 2020, no usefull updates in the release notes, just warnings to only upgrade when having issues and I have none.
Gnome-character crashing happens on my system to, not that bothered by it, it came after a update, no cause to be found, it will probably go away in future updates.
When looking glass does not report anything the extensions are probably oke and not cause it.
I doubt that its related to no swap being there, but I will check. For being sure I will configure Swap Space.
I am pretty sure that the error is related to this log, because I always check the time it happens, and I always get these logs when the error happens, also can't update stage view actor sounds at first glance something like what I am experiencing without knowing the technical implications of this assertion.
The log below is from the last time I got the error. Maybe I should head out to the gnome community.
Mär 23 16:54:55 dektop gnome-shell[1313]: Attempting to call back into JSAPI during the sweeping phase of GC. This is most likely caused by not destroying a Clutter actor or Gtk+ widget with ::destroy signals connected, but can also be caused by using the destroy(), dispose(), or remove() vfuncs. Because it would crash the application, it has been blocked and the JS callback not invoked.
Mär 23 16:54:55 dektop gnome-shell[1313]: The offending signal was button-press-event on Gjs_ui_panel_Panel 0x560b74e80980.
Mär 23 16:54:55 dektop gnome-shell[1313]: Attempting to run a JS callback during garbage collection. This is most likely caused by destroying a Clutter actor or GTK widget with ::destroy signal connected, or using the destroy(), dispose(), or remove() vfuncs. Because it would crash the application, it has been blocked.
Mär 23 16:54:55 dektop gnome-shell[1313]: The offending callback was SourceFunc().
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b771c3be0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b7a2b18b0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b7486d540] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b77d10490] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbc9d0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b7a2d8100] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b782c1990] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b79365e60] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b7621baa0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbc6a0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b7854f650] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b78874f20] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b79f148e0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b76876890] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b78dbea80] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b77cd1c50] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b782a46f0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b7830d410] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b79a21ee0] is on because it needs an allocation.
Mär 23 16:54:57 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbd030] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b7854f650] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b78874f20] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b79f148e0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b76876890] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b78dbea80] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b77cd1c50] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b782a46f0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b7830d410] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b79a21ee0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbd030] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b7762cc50] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b792d91d0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b7a0c18c0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b7714ebb0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbd360] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b771c3be0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b7a2b18b0] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b7486d540] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b77d10490] is on because it needs an allocation.
Mär 23 16:54:58 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbc9d0] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b7762cc50] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b792d91d0] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b7a0c18c0] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b7714ebb0] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbd360] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StLabel>:0x560b771c3be0] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterText>:0x560b7a2b18b0] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StButton>:0x560b7486d540] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<StIcon>:0x560b77d10490] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: Can't update stage views actor <unnamed>[<ClutterActor>:0x560b79cbc9d0] is on because it needs an allocation.
Mär 23 16:54:59 dektop gnome-shell[1313]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
It will not hurt to have swap.
I agree that this looks/sounds directly related, and to me extension related.
That is an option to pursue, I’m out of ideas to help.
