lfs
12 February 2021 15:04
1
Hello,
I’m running manjaro on Dell G5 with Gnome and nvidia hybrid drivers. Since around Xmas updates the UI started to freeze for couple of seconds when I’m starting some larger application.
Example: I have 8GB mem free, system is pretty much idle, the fans are off. I click to start IntelliJ and the system freezes for like 3-5 seconds (the clock stops, can move the mouse, can’t switch windows, etc.), after those couple of seconds the fans starts spinning and the UI becomes responsive again.
Any hints on what to check or where the problem could be?
Here’s the output from inxi about my system confiuration
System: Host: Haven Kernel: 5.4.95-1-MANJARO x86_64 bits: 64 Desktop: GNOME 3.38.3 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: G5 5590 v: N/A serial: <superuser required>
Mobo: Dell model: 0CNDTP v: A01 serial: <superuser required> UEFI: Dell v: 1.14.0 date: 10/20/2020
Battery: ID-1: BAT0 charge: 83.3 Wh condition: 83.3/90.0 Wh (93%)
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP L2 cache: 12 MiB
Speed: 1390 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 1390 2: 2721 3: 1042 4: 3506 5: 1168 6: 1560 7: 1984
8: 1758 9: 1083 10: 944 11: 1066 12: 1386
Graphics: Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] driver: nvidia v: 460.39
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia unloaded: intel,nouveau
resolution: 1920x1080~144Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
Audio: Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Sound Server: ALSA v: k5.4.95-1-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
IF: wlo1 state: up mac: c0:b8:83:24:2c:d2
Device-2: Realtek driver: r8168
IF: enp60s0 state: down mac: 8c:04:ba:9a:6a:ae
IF-ID-1: docker0 state: up speed: N/A duplex: N/A mac: 02:42:8b:bf:54:b7
IF-ID-2: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-3: vethd0e6fcb state: up speed: 10000 Mbps duplex: full mac: 1e:38:bc:46:84:33
IF-ID-4: vethf41e780 state: up speed: 10000 Mbps duplex: full mac: 0e:c4:85:c1:5d:38
IF-ID-5: ztrf2z3eko state: unknown speed: 10 Mbps duplex: full mac: 4a:80:e8:53:fc:99
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 476.94 GiB used: 738.57 GiB (154.9%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC601 NVMe 512GB size: 476.94 GiB
Partition: ID-1: / size: 464.21 GiB used: 368.92 GiB (79.5%) fs: ext4 dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 15.5 MiB (5.2%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 4.02 GiB used: 731.8 MiB (17.8%) dev: /dev/dm-1
Sensors: System Temperatures: cpu: 61.0 C mobo: N/A
Info: Processes: 485 Uptime: 21h 51m Memory: 15.46 GiB used: 10.75 GiB (69.6%) Shell: Zsh inxi: 3.3.01
Fabby
14 February 2021 15:00
2
What’s the output of:
free --human
before you start said application
and:
free --human
after?
lfs
15 February 2021 12:17
3
The output of: inxi --admin --verbosity=7 --filter --no-host --width
is:
Kernel: 5.4.95-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=53daf429-2de4-483a-8c5b-fe0f3ceac68f rw quiet
cryptdevice=UUID=41593711-c62d-4035-ab81-3f9b87284891:luks-41593711-c62d-4035-ab81-3f9b87284891
root=/dev/mapper/luks-41593711-c62d-4035-ab81-3f9b87284891
resume=/dev/mapper/luks-41593711-c62d-4035-ab81-3f9b87284891 apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 info: docker wm: gnome-shell
dm: GDM 3.38.2.1 Distro: Manjaro Linux
Type: Laptop System: Dell product: G5 5590 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 0CNDTP v: A01 serial: <filter> UEFI: Dell v: 1.14.0
date: 10/20/2020
ID-1: BAT0 charge: 83.3 Wh condition: 83.3/90.0 Wh (93%) volts: 13.1/11.4
model: BYD DELL 6YV0V94 type: Li-poly serial: <filter> status: Full
RAM: total: 15.46 GiB used: 10.06 GiB (65.1%)
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 12 MiB bogomips: 62431
Speed: 2894 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 2894 2: 3185
3: 1833 4: 2222 5: 1395 6: 2520 7: 2514 8: 2506 9: 2252 10: 1494 11: 3285
12: 3617
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
driver: nvidia v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f11 class ID: 0300
bus ID: 1-5:3 chip ID: 0bda:5521 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver:
loaded: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
display ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348 class ID: 0403
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus ID: 00:14.3 chip ID: 8086:a370 class ID: 0280
Device-2: Realtek vendor: Dell driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus ID: 3c:00.0 chip ID: 10ec:2502 class ID: 0200
IF: enp60s0 state: down mac: <filter>
IF-ID-1: docker0 state: up speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: veth9edfea9 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-3: vethc383833 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: ztrf2z3eko state: unknown speed: 10 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus ID: 1-14:5 chip ID: 8087:0aaa class ID: e001
Local Storage: total: 476.94 GiB used: 737.35 GiB (154.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC601 NVMe 512GB
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 80002111 scheme: GPT
ID-1: / raw size: 472.62 GiB size: 464.21 GiB (98.22%)
used: 368.49 GiB (79.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-41593711-c62d-4035-ab81-3f9b87284891 label: N/A
uuid: 53daf429-2de4-483a-8c5b-fe0f3ceac68f
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 15.5 MiB (5.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 939D-27A0
ID-3: /home/<filter>/RobotFramework/archives/docker-images/overlay2/21be7207fcb003590e82a9b2215cee4bd029b11a8cb70011b2ee922c66044cca/merged raw size: N/A size: 464.21 GiB used: 368.49 GiB (79.4%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-4: /home/<filter>/RobotFramework/archives/docker-images/overlay2/398c1daeca36a979192a9fcdb27bab5442da24e11dca81cbd90c13c2bc96dc65/merged raw size: N/A size: 464.21 GiB used: 368.49 GiB (79.4%) fs: overlay
ID-1: swap-1 type: partition size: 4.02 GiB used: 356.8 MiB (8.7%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-71bf355f-aba9-4678-832c-1996ea497265 label: N/A
uuid: d7cf9e64-918c-4080-926e-54850c4bac54
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:2 info: Trust Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 145f:0263 class ID: 0301
Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:5521
Device-3: 1-9:4 info: Shenzhen Goodix Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 27c6:530c class ID: ff00
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 515 Uptime: 2d 3h 30m wakeups: 8469 Init: systemd v: 247
Compilers: gcc: 10.2.0 Packages: pacman: 1462 lib: 457 flatpak: 0 Shell: Zsh
v: 5.8 running in: guake inxi: 3.3.01
The output of free --human
before is:
total used free shared buff/cache available
Mem: 15Gi 5,4Gi 3,2Gi 4,3Gi 6,9Gi 5,4Gi
Swap: 4,0Gi 356Mi 3,7Gi
The free --human
output afterwards is:
Mem: 15Gi 6,7Gi 2,1Gi 4,4Gi 6,7Gi 4,0Gi
Swap: 4,0Gi 796Mi 3,2Gi
Fabby
15 February 2021 15:45
4
Your swap
is on an encrypted volume and swapping is taking place. That’s the only thing I can think of, so: move the swap to an unencrypted partition / file…
lfs
19 February 2021 18:42
5
Hum, pretty sure that’s not it. I’ve just tried to run the program with having 8G free memory and the UI was still lagging.
