Gnome freezes everyday
My gpu is intel hd graphics 3000… and I use the video-linux driver…
after running my laptop for about 1.5-2.5 hours, my laptop freezes - theres nothing I can do… my mouse and keyboard doesn’t work when pc freezes. I always have to hard reboot it…
Someone told me to change my display server from wayland to xorg… What should I do!?
Please post your system info as outlined here:
  Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=58be6df1-4173-425c-bb5f-e8585e518acd ro quiet udev.log_priority=3
  Desktop: GNOME 3.38.4 tk: GTK 3.24.27 wm: gnome-shell dm: GDM 3.38.2.1
  Type: Portable System: Dell product: Inspiron N4050 v: N/A serial: <filter>
  Chassis: type: 8 serial: <filter>
  Mobo: Dell model: 0X0DC1 v: A09 serial: <filter> BIOS: Dell v: A09
  date: 11/02/2012
  RAM: total: 3.76 GiB used: 2.64 GiB (70.4%)
  Info: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 3 MiB bogomips: 16768
  Speed: 798 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
  4: 798
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx
  monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
  pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2
  sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
  vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
  class-ID: 0300
  Device-2: Realtek Integrated Webcam type: USB driver: uvcvideo
  bus-ID: 1-1.5:4 chip-ID: 0bda:58c1 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa
  OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
  v: 3.3 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
  vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: yes
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter
  vendor: Hewlett-Packard driver: wl v: kernel modules: bcma port: e000
  bus-ID: 09:00.0 chip-ID: 14e4:4727 class-ID: 0280
  IF: wlp9s0 state: down mac: <filter>
  Message: No Bluetooth data was found.
  Message: No LVM data was found.
  Local Storage: total: 465.76 GiB used: 12.7 GiB (2.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD050
  size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 1A scheme: GPT
  Optical-1: /dev/sr0 vendor: MATSHITA model: DVD+-RW UJ8B1 rev: D.05
  dev-links: cdrom
  ID-1: / raw-size: 15 GiB size: 14.71 GiB (98.01%) used: 9.74 GiB (66.2%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 58be6df1-4173-425c-bb5f-e8585e518acd
  ID-2: /home raw-size: 45.53 GiB size: 44.56 GiB (97.88%)
  used: 2.96 GiB (6.6%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: d4712707-27f4-4b68-a587-ece89f82f88b
  Kernel: swappiness: 1 (default 60) cache-pressure: 50 (default 100)
  ID-1: swap-1 type: file size: 1.5 GiB used: 101 MiB (6.6%) priority: -2
  file: /swapfile
  ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: <superuser required> label: N/A
  uuid: N/A
  ID-2: /dev/sda4 maj-min: 8:4 size: 32.69 GiB fs: ext4 label: Timeshift
  uuid: fc02e91a-f5bd-4c86-95b4-534aa78466a5
  ID-3: /dev/sda5 maj-min: 8:5 size: 93.13 GiB fs: ext4 label: Rakin
  uuid: 991d4bc0-8150-4947-b570-667f5dbe2eb9
  ID-4: /dev/sda6 maj-min: 8:6 size: 93.13 GiB fs: ext4 label: Entertainment
  uuid: 2a4331b1-4da5-4503-a171-bb916cf52ebb
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.2:3 info: Xiaomi Mi Wireless Combo type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 2717:5010 class-ID: 0301
  Device-2: 1-1.5:4 info: Realtek Integrated Webcam type: Video
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.2:3 info: China Resource Semico Usb Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 98mA chip-ID: 1a2c:0042 class-ID: 0301
  Device-2: 2-1.6:4 info: Realtek RTS5138 Card Reader Controller
  type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0
  speed: 480 Mb/s power: 500mA chip-ID: 0bda:0138 class-ID: 0806
  serial: <filter>
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 3495
  Processes: 217 Uptime: 4h 36m wakeups: 1 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1122 lib: 363
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.03
I switched to xorg… Im having no problem with that… Should I stick with that!?
You might want to increase your swapfile size to at least 5.5 GB. I would set swappiness to 10 so you’re not completely out of RAM when swapping starts.
Try it out and see. I’m not sure why you would be having issues with Wayland but not Xorg.
I have that swap file made of a hard disk, not ssd… and I dont go out of RAM even when swapping doesnt start. I always look my RAM and swap usage at htop…
But should I increase swappiness?? RAM is faster that hdd…that’s why I did set swappiness to 1.
Why Gnome uses wayland instead of xorg??
I am using Xorg as I was having some other issues with Wayland. but I am currently facing similar freezing issue.
@Yochanan I have 16 GB or ram and 18 GB of swap on an SSD ( I don’t know why I configured it this way!!) and my swappiness is set to 10 still my laptop freezes.
@rakin09 Take a look at this post if you have not done so already. “Hard Reset” can be damaging for your HDD.
for me, Alt + PrtScr worked as the SysRq key. Making the change in sysctl did not work for me. I had to edit the /etc/default/grub file.
