Lala
30 June 2022 07:17
1
Following last stable update, after reboot, when I login, I’m stuck on this screen:
It’s not a full freeze:
mouse move, but clicks does nothing
keyboard does nothing, but cap-lock is recognized as I have an extension on top right that toggle when cap lock is toggled.
But I cannot go to terminal (ctrl+alt+Fx does nothing).
What can I do ?
Lala
30 June 2022 07:24
2
ok, finally journalctl output a lot of extensions errors, so I used command
gsettings set org.gnome.shell disable-user-extensions true
now I have to find the guilty
Lala
30 June 2022 07:33
3
Ok for the record => it was caused by a not compatible but disabled extension
I uninstalled it.
That’s very curious: I would not have imagined that a disabled extension could cause problem.
extension cause issue is this one:
https://extensions.gnome.org/extension/307/dash-to-dock/
it was working well in the past, but not anymore with gnome42 (I replaced by Dash to Dock for COSMIC - GNOME Shell Extensions )
=> problem solved, but this behaviour (disable extension causes issues) looks a bit like a bug.
Dash to Dock has been compatible with GNOME 42 for quite awhile. You should install gnome-shell-extension-dash-to-dock from the Manjaro community repo, not from the GNOME Extensions website.
Dash to Dock for COSMIC is only for Pop!_OS as it describes.
Thanks Lala I had the same issue. GNOME 42 has been a pain in the ass Dash to Dock only gave me problems, i had to migrate to Dash to Dock for COSMIC too
system
Closed
3 July 2022 15:48
6
