Hi fellas,
So, as it is said in the title, after recent update, all of my gnome plugins, and mostly one that allors ALT TAB to switch between apps in current screen and not entire workspace, are disabled.
When i try to turn a plugin on (via the gnome shell manager on firefox) it doesn’t.
plus ( this is a detail but realy annoying) the app bar is locked at the bottom of main screen, and i like it better on the left, but i can’t move it.
is there a way to solve this ? Is this a kown issue ?
thanks beforehand
After some more research, it seems that i’m having a problem with gnome extensions.
It dnesn’t look enabled :
The screen share fonctionnality also seems to be affected, it works-ish.
Should i re-install gnome completely ?
or could there be a link broken somewhere ?
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=87a141c8-ba4d-4858-ad80-fc1b7c845167 rw quiet splash apparmor=1
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: LENOVO product: 20Y1000SFR v: ThinkPad P14s Gen 1
Mobo: LENOVO model: 20Y1000SFR serial: <superuser required> UEFI: LENOVO
v: R1BET61W(1.30 ) date: 12/21/2020
ID-1: BAT0 charge: 51.2 Wh (99.4%) condition: 51.5/50.5 Wh (101.9%)
volts: 12.9 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
status: full cycles: 78
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
status: discharging
RAM: total: 22.78 GiB used: 12.2 GiB (53.6%)
RAM Report:
Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2297 high: 3696 min/max: 1400/1700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2726 2: 3608
3: 3696 4: 3256 5: 2221 6: 1890 7: 1687 8: 1779 9: 3289 10: 1848 11: 1711
12: 1854 13: 1855 14: 1850 15: 1808 16: 1676 bogomips: 54321
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-3,DP-4,eDP-1
empty: DP-1, DP-2, DP-5, HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1636
class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 13d3:5406 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: Philips PHL 243V7 serial: <filter> built: 2018
res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-4 model: Philips PHL 243V7 serial: <filter> built: 2018
Monitor-3: eDP-1 model: LG Display 0x05fa built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.41-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-4: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 5-1.3:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp7s0f3u1u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 6-4:4
Local Storage: total: 238.47 GiB used: 69.84 GiB (29.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS256GD9TNI-L2B0B size: 238.47 GiB block-size: physical: 512 B
rev: 11720C10 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 19.17 GiB (33.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 87a141c8-ba4d-4858-ad80-fc1b7c845167
label: NO_LABEL uuid: 7F5A-6318
ID-3: /home raw-size: 179.58 GiB size: 175.7 GiB (97.84%)
used: 50.67 GiB (28.8%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 47b3301b-f15b-4b53-b235-9538d9cda084
Hub-1: 1-0:1 info: Full speed or root hub ports: 1 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 2-2:2 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 3-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-4: 4-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-6: 4-1.2:5 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 4-1.5:6 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
Device-2: 4-2:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 4-3:4 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
chip-ID: 058f:9540 class-ID: 0b00
Hub-7: 5-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 5-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 5-1.3:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-9: 6-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 6-2:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c548 class-ID: 0300
Device-2: 6-3:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-3: 6-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-10: 7-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 79.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): fan-1: 4000
Processes: 421 Uptime: 5h 19m wakeups: 9 Init: systemd v: 250
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1283
pacman: 1271 lib: 332 flatpak: 0 snap: 12 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.16
I tried to turn everything off, removed extensions from ~/.local/share…
nothing worked.
even the native Manjaro top bar extension for showing updates is broken. Is it safe to delete the extensions in /usr/share/gnome-shell/extensions
I’m out of ideas
