The templates plugin seems to be not working for my set-up of evolution (3.50.2-1) installed from the repository.After several new starts, it suddenly works also in the version from the repository.
I tried also with the flatpak package (3.50.1) using the backup of the evolution from repository. There it works. -
Does anyone have experience with this plugin? I didn’t understand how to use it properly when creating new mails (not replying to previously received ones). I made a template
Dear $ORIG[to],
If I open that template message, insert a recipient and send the mail, then the template field does not get replaced. Only if I use the Reply with Template
then I get it replaced (although with extra space before the comma to e.g., Dear John Doe ,
Edit: first point got magically resolved
