I connected it and allowed file transfer but laptop doesn’t react. P.S. phone is charging through laptop.
More data needed. Android or iPhone etc.
Xiaomi Redmi Note 5
Android 9 PKQ1
Snapdragon 636 - processor
MIUI 12.0.2 Stable (Xiaomi OS)
If you run the command lsusb, do you see your device?
Just type Isusb in terminal? I will try
It does see my phone:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 003 Device 002: ID 13d3:56cb IMC Networks USB2.0 HD IR UVC WebCam
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 001 Device 002: ID 09da:f891 A4Tech Co., Ltd. USB Device
Bus 001 Device 005: ID 2717:ff40 Xiaomi Inc. Mi/Redmi series (MTP)
Edit: but there’s still quiet in Nautilus and Disks app.
It is there:
If it is in charge mode, then there will be nothing visible.
If you need MTP in nautilus, then install gvfs-mtp
. It is a optional dependency of gvfs
It helped, thank you!
