Hi,
Since Gnome 3.38 i have problems with tracker. I want to search keywords in my files content (.odt ou .pdf by example). As far I know, the only way to use GUI to do that is to use gnome-documents.
Tracker3 seems to works fine, announcing that files has been indexed and that indexation is ended. But gnome-documents is unusable, announcing that no file as been found.
I already tried to remove tracker database, reinitialize indexation with no luck. Is someone could help me to have fully functionnal search tool ? Is there an alternative to gnome-documents ?
Thanks.
