So I’ve tried opening Display settings in my GNOME install, yet it crashes everysingle time, at first this didn’t bother me, but now I want to plug in external displays via HDMI but it just doesn’t work.
Here is system info.
Kernel: 6.3.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=07b8bffc-5a6d-41f0-a9c5-b33be969211f rw quiet splash
udev.log_priority=3
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Laptop System: SAMSUNG product: 750XED v: P12CFG
Mobo: SAMSUNG model: NP750XED-KC1ES v: SAMSUNG_SW_REVISION_12345+0.0.0000
serial: <superuser required> UEFI: American Megatrends LLC.
v: P12CFG.038.230404.HQ date: 04/04/2023
ID-1: BAT1 charge: 55.6 Wh (100.0%) condition: 55.6/54.4 Wh (102.3%)
volts: 17.3 min: 15.4 model: SAMSUNG Electronics SR Real Battery type: Li-ion
serial: <filter> status: not charging cycles: 47
System RAM: available: 7.46 GiB used: 3.6 GiB (48.3%)
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x429
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2500 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 2500 2: 2500 3: 2500 4: 2500 5: 2500 6: 2500
7: 2500 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500 bogomips: 59916
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Samsung Co
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:46a8
class-ID: 0300
Device-2: SunplusIT 720p HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 5959:1502
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0a06 built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Samsung Co
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.3.3-1-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 501.08 GiB used: 25.04 GiB (5.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SL32G size: 29.72 GiB block-size:
physical: 512 B logical: 512 B type: USB tech: SSD serial: <filter>
scheme: GPT
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SBJ01101 temp: 35.9 C
scheme: GPT
ID-3: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: MZVLQ256HBJD-00B
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: FXM7AK1Q temp: 28.9 C
scheme: GPT
ID-1: / raw-size: 216.41 GiB size: 211.96 GiB (97.94%)
used: 24.96 GiB (11.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 07b8bffc-5a6d-41f0-a9c5-b33be969211f
ID-2: /boot/efi raw-size: 483 MiB size: 482 MiB (99.80%)
used: 79.1 MiB (16.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0041-EF11
ID-3: /run/media/kubad/F079-A30A raw-size: 29.72 GiB
size: 29.71 GiB (99.95%) used: 64 KiB (0.0%) fs: vfat dev: /dev/mmcblk0p1
maj-min: 179:1 label: N/A uuid: F079-A30A
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: a63c9bb3-f42b-47da-90c8-4e1959f2ac61
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 260 MiB fs: vfat label: SYSTEM
uuid: ACD6-454D
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 236.35 GiB fs: ntfs label: N/A
uuid: 2CA8D6F5A8D6BD10
ID-4: /dev/nvme1n1p4 maj-min: 259:8 size: 1000 MiB fs: ntfs
label: Windows RE tools uuid: 01D9171D6B1BBA50
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-2: 3-8:3 info: SunplusIT 720p HD Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5959:1502 class-ID: 0e02 serial: <filter>
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 302 Uptime: 36m wakeups: 7695 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1065 pm: pacman pkgs: 1059 libs: 302 tools: gnome-software,pamac
pm: flatpak pkgs: 6 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
Here is the error log:
may 19 22:24:23 kuba-750xed kernel: ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
may 19 22:24:23 kuba-750xed kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20221020/psargs-330)
may 19 22:24:23 kuba-750xed kernel: ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
may 19 22:24:23 kuba-750xed kernel: ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS04._PLD due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
may 20 00:14:48 kuba-750xed kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
may 20 00:14:49 kuba-750xed bluetoothd[405]: src/plugin.c:plugin_init() Failed to init vcp plugin
may 20 00:14:49 kuba-750xed bluetoothd[405]: src/plugin.c:plugin_init() Failed to init mcp plugin
may 20 00:14:49 kuba-750xed bluetoothd[405]: src/plugin.c:plugin_init() Failed to init bap plugin
may 20 00:14:49 kuba-750xed kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
may 20 00:14:50 kuba-750xed kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
may 20 00:14:50 kuba-750xed bluetoothd[405]: Failed to set mode: Failed (0x03)
may 20 00:14:51 kuba-750xed kernel: ucsi_acpi USBC000:00: possible UCSI driver bug 1
may 20 00:14:56 kuba-750xed kernel: ucsi_acpi USBC000:00: PPM init failed (-22)
may 20 00:14:57 kuba-750xed gdm-password][965]: gkr-pam: unable to locate daemon control file
may 20 00:14:58 kuba-750xed systemd[989]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 161 and the job result is failed.
░░ The job identifier is 157 and the job result is failed.
may 20 00:31:36 kuba-750xed kernel: watchdog: watchdog0: watchdog did not stop!
