Hello together. It seems there is an issue with
“gnome-shell-extension-gtk4-desktop-icons-ng”. I had enabled this extension and
since some days I’ve noticed that I can’t move desktop icons anymore. If I try that, the moved icon will “doubled” and I can’t click that icon. I never noticed that before. I don’t know, if this is a known issue.
I have tried to disable all other extensions, but this didn’t help to solve the issue. As a workaround, i have installed now “gnome-shell-extension-desktop-icons-ng” from AUR.
Many thx. Didn’t found it, after searching for updates. That’s why I tried that way. But it’s ok. The next standard update will overwrite it from standard repository. Anyway… It works. Many thx for your support.
