I am in the testing branch. I am not sure what information I should provide, so please ask.
When I move a window to the second display, or if a window opens in the second display, then gnome desktop crashes and after 2 seconds of a black screen, gnome login appears and I can login into my account
I would like to add that I am in the testing branch, I think a recent update might have caused this.
Can you reproduce the issue after disabling all extensions and logging out?
Gnome seems to have disabled all extensions automatically after it crashed a few times.
The issue still persists.
Here you go:
Kernel: 5.12.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=2e036756-2010-4310-961a-06b41286e3b5 ro quiet splash apparmor=1
Desktop: GNOME 40.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: ASUSTeK product: TUF GAMING FX504GM_FX80GM v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX504GM v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX504GM.308 date: 06/10/2019
ID-1: BAT1 charge: 41.1 Wh (100.0%) condition: 41.1/48.1 Wh (85.5%)
volts: 4.0 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: Full
RAM: total: 15.49 GiB used: 2.44 GiB (15.7%)
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB bogomips: 52815
Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 901 7: 900 8: 900 9: 900 10: 900 11: 900 12: 901
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: ASUSTeK
driver: nvidia v: 470.42.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c20 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.12 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Sound Server-1: ALSA v: k5.12.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Argument "fuse.rclone" isn't numeric in numeric eq (==) at /usr/bin/inxi line 14943.
Local Storage: total: 704.24 GiB used: 355.16 GiB (50.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: A031 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 023 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 74.8 GiB (32.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 2e036756-2010-4310-961a-06b41286e3b5
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F61D-D84E
ID-3: /mnt/Data raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 280.37 GiB (61.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Data
uuid: 47730a53-d5a8-4cdb-af1b-ab2bf64678ec
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 256mA chip-ID: 258a:1007 class-ID: 0301
Device-2: 1-7:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 54.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 313 Uptime: 8m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1507 pacman: 1500 lib: 430
flatpak: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
Hmm, might be related to the issue with hybrid graphics posted in today’s Testing Update thread. Perhaps try downgrading xorg-server:
With xorg-server 1.20.12-1 my HDMI connected external monitor stopped working.
I can boot and log in with disconnected HDMI. When I connect the HDMI monitor I get back to SDDM greeter and when I try to login again the screen hangs at load animation. Here Xorg.0.log from that session.
If I boot with connected HDMI and login at SDDM the screen hangs at load animation as well.
After downgrading
[2021-07-11T18:41:05+0200] [ALPM] downgraded xorg-server-common (1.20.12-1 -> 1.20.11-1)
[2021-07-11T…
Which command would that be exactly? I don’t want to mess it up.
See Downgrading packages - Manjaro
sudo downgrade xorg-server xorg-server-common
Choose 1.20.11 for both packages.
Yeah this seems to have fixed the problem. So should I upgrade these packages when a newer version comes out?
Yes. Hopefully the next release will contain a fix.
