as the title suggests, i am unable to use dark theme in gnome, and themes in gdm are broken
Do you have xdg-desktop-portal-gnome installed?
yes i do, also thanks for the near instant reply, i am not sure what had happened but i just booted into windows and back (dual boot system) and now everything works though, i feel a lot of jitters now
update : the issue is still there actually… it sometimes happens now when i reboot/log in or out
i have to then log in / out ( not reboot) to get it to work again…
i have no clue as to what could be causing this as i have read most if not all forum posts about this issue
and the performance hit is still there… only in gnome tho… ( like the shell itself… animations, loading, etc… the apps work fine)
I have the same issue, and xdg-desktop-portal-gnome is installed
