When you open Nautilus in the directory where the animated webp file is located, it eats up all the memory and all the swap and throws it out of the session
The file causing the crash is packed in zip
Please do not spread such - possible - malware - malware in the sense of not working as you expect.
Hello @andxbes
I tested it and I agree, it takes a lot of RAM when it creates a thumbnail of such a big webp file. About 8G of RAM. The reason is simply that it decompresses all pictures into RAM (open it) and then create a thumbnail. It use libwebp directly from Google.
I tried simply that:
Also opening it with gnomes eog
picture viewer takes 8G RAM:
~/Downloads smem -ntkP eog ✔ 3s
PID User Command Swap USS PSS RSS
229166 1000 python /usr/bin/smem -ntkP 0 11.2M 12.0M 17.6M
228617 1000 eog Untitled.webp 0 8.4G 8.4G 8.4G
2 1 0 8.4G 8.4G 8.5G
I would say, webp is not made to be such a big file. It is for small web images.
Also if it eats all your RAM, then it close gracefully the session for safety reasons.
That being said, there is nothing you can do. Install more RAM or use a another format which doesn’t take so much RAM.
gdk-pixbuf-thumbnailer
has this issue with the animated webp. If you need functionality, try to install webp-pixbuf-loader
from the repo and follow the setup.This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
