(base) [21:22:36] firestar:~ $ ps aux | sort --numeric-sort --reverse --key=3,3 | head --lines=10
firestar 3234 78.5 8.3 2038400 677128 ? Rl 21:34 22:59 c:\Program Files\Tencent\WeChat\WeChatApp.exe --applet_init_config={"appId":"preload_1599140049364_0","appVersion":0,"brandName":"","clientVersion":1644626264,"debugType":0,"deviceType":"Windows+10","iconUrl":"","isNativeView":false,"isPreload":true,"isTest":false,"moduleListInfo":"","orientation":"","originalFlag":0,"originalRedirectUrl":"","referrer":{"agentId":"","appId":"","launchScene":10086,"sourceType":0},"shareKey":"","shareName":"","uin":"441099259","username":"","versionState":0,"wxIconUrl":""} --applet_init_config_ex={"clientJsExtInfo":"","dataPath":"C:\\users\\firestar\\My Documents\\WeChat Files\\wxid_2dmxlm6zy3gm22\\Applet\\","debugJsonInfo":"","enterPath":"","extraData":"","logPath":"C:\\users\\firestar\\APPL~JHT\\Tencent\\WeChat\\log\\","messageExtraData":"","nickName":"","openapiInvokeData":"","operationInfo":"","pkgDirPath":"","privateExtraData":"","signature":"","tmpPath":"","transitiveData":"","url":"","wxNickName":""}
firestar 2727 39.1 0.1 12088 9172 ? Rs 21:33 11:43 /usr/lib/i386-linux-gnu/deepin-wine/./wineserver.real -p0
firestar 2304 12.4 5.5 3523264 451116 ? Sl 21:23 4:57 /usr/lib/firefox/firefox --new-window
firestar 2722 10.8 3.3 2830572 269432 ? SLl 21:33 3:15 c:\Program Files\Tencent\WeChat\WeChat.exe
firestar 1453 7.6 4.6 4556036 372880 ? Ssl 21:19 3:19 /usr/bin/gnome-shell
firestar 2370 5.8 3.8 2971172 311184 ? Sl 21:23 2:18 /usr/lib/firefox/firefox -contentproc -childID 1 -isForBrowser -prefsLen 1 -prefMapSize 230042 -parentBuildID 20200824164321 -appdir /usr/lib/firefox/browser 2304 true tab
firestar 1371 5.0 2.0 754732 166444 tty2 Sl+ 21:19 2:13 /usr/lib/Xorg vt2 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -nolisten tcp -background none -noreset -keeptty -verbose 3
firestar 2805 2.0 0.4 434868 32632 ? Ssl 21:33 0:37 /usr/lib/tracker-store
firestar 2675 1.7 4.9 3025936 396764 ? Sl 21:33 0:31 /usr/lib/firefox/firefox -contentproc -childID 6 -isForBrowser -prefsLen 7784 -prefMapSize 230042 -parentBuildID 20200824164321 -appdir /usr/lib/firefox/browser 2304 true tab
firestar 1788 1.2 0.3 665524 32168 ? SNl 21:19 0:31 /usr/lib/tracker-miner-fs
(base) [22:03:26] firestar:~ $ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +45.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +44.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +43.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +45.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +43.0°C (high = +100.0°C, crit = +100.0°C)
pch_skylake-virtual-0
Adapter: Virtual device
temp1: +40.5°C
nvme-pci-0200
Adapter: PCI adapter
Composite: +43.9°C (low = -273.1°C, high = +81.8°C)
(crit = +84.8°C)
Sensor 1: +43.9°C (low = -273.1°C, high = +65261.8°C)
BAT1-acpi-0
Adapter: ACPI interface
in0: 8.63 V
free --human
Total Used Empty Share Cache Usable
Memory: 7.7Gi 3.0Gi 2.4Gi 793Mi 2.4Gi 3.7Gi
Swap: 8.0Gi 0B 8.0Gi
(base) [22:03:36] firestar:~ $ inxi --admin --verbosity=7 --filter --no-host
Kernel: 5.8.3-arch1-1-surface x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-surface
root=UUID=89f44092-3b3a-408b-98ad-164d3ed8caab rw quiet apparmor=1
Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Microsoft product: Surface Pro 6
v: 124000000000000000000000D:0B:13F:5C:10P:38S:01E:0 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Microsoft model: Surface Pro 6 serial: <filter> UEFI: Microsoft
v: 235.3192.768 date: 03.24.2020
ID-1: BAT1 charge: 39.8 Wh condition: 39.8/45.0 Wh (88%) volts: 8.6/7.6
model: SMP M1009169 type: Li-ion serial: <filter> status: Full cycles: 213
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: Discharging
RAM: total: 7.70 GiB used: 3.10 GiB (40.2%)
RAM Report:
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10)
microcode: D6 L2 cache: 6144 KiB bogomips: 28808
Speed: 1100 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 1100 2: 1100
3: 1100 4: 1100 5: 1100 6: 1100 7: 1100 8: 1100
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Microsoft driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917
Display: x11 server: X.Org 1.20.9 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :1 screens: 1
Screen-1: 0 s-res: 2736x1824 s-dpi: 96 s-size: 723x482mm (28.5x19.0")
s-diag: 869mm (34.2")
Monitor-1: eDP1 res: 2736x1824 hz: 60 dpi: 267 size: 260x170mm (10.2x6.7")
diag: 311mm (12.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit
driver: ipu3-imgu alternate: ipu3_imgu bus ID: 00:05.0 chip ID: 8086:1919
Device-2: Intel CSI-2 Host driver: ipu3-cio2 alternate: ipu3_cio2
bus ID: 00:14.3 chip ID: 8086:9d32
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.3-arch1-1-surface
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
v: 1.0 port: 3000 bus ID: 01:00.0 chip ID: 11ab:2b38
Device-2: Marvell Bluetooth and Wireless LAN Composite type: USB
driver: btusb bus ID: 1-5:4 chip ID: 1286:204c serial: <filter>
Local Storage: total: 238.47 GiB used: 93.84 GiB (39.3%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter>
rev: ADMS0101 scheme: GPT
ID-1: / raw size: 108.13 GiB size: 105.93 GiB (97.97%)
used: 39.37 GiB (37.2%) fs: ext4 dev: /dev/nvme0n1p6 label: N/A
uuid: 89f44092-3b3a-408b-98ad-164d3ed8caab
ID-2: /boot/efi raw size: 260.0 MiB size: 256.0 MiB (98.46%)
used: 25.9 MiB (10.1%) fs: vfat dev: /dev/nvme0n1p1 label: SYSTEM
uuid: C8B8-2E22
ID-3: /mnt/8494B8C594B8BACE raw size: 64.10 GiB size: 64.10 GiB (100.00%)
used: 24.20 GiB (37.8%) fs: ntfs dev: /dev/nvme0n1p3 label: System
uuid: 8494B8C594B8BACE
ID-4: /mnt/A2668A50668A24DF raw size: 64.10 GiB size: 64.10 GiB (100.00%)
used: 30.24 GiB (47.2%) fs: ntfs dev: /dev/nvme0n1p4 label: Data
uuid: A2668A50668A24DF
ID-1: swap-1 type: file size: 8.00 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 size: 128.0 MiB fs: <superuser/root required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p5 size: 1.77 GiB fs: ntfs label: Windows RE tools
uuid: 4614BADC14BACE65
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 046d:c52f
Device-2: 1-5:4 info: Marvell Bluetooth and Wireless LAN Composite
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 480 Mb/s
Device-3: 1-7:3 info: Microsoft Surface Type Cover type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
chip ID: 045e:09c0
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 40.5 C mobo: N/A
Processes: 302 Uptime: 44m Init: systemd v: 246 Compilers: gcc: 10.2.0
clang: 10.0.1 Packages: pacman: 1261 lib: 335 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
