hey guys, need some help troubleshooting a problem with gnome-control-center, this is the only application that refuses to go in light mode, I tried to enable the option “light” in the settings itself and all the system comes to light mode perfectly except for the gnome-control-center, so I tried to reinstall it using the command sudo pacman -S gnome-control-center but it didn’t work, tried to reboot my computer also, in tweaks the system is set to a light theme, any tips on what i should try to do?
inxi -Fxz ✔
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: GNOME v: 42.1 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2006
date: 11/13/2019
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2097 high: 3792 min/max: 1550/3400 boost: enabled
cores: 1: 3482 2: 1517 3: 1349 4: 1845 5: 3788 6: 1685 7: 1416 8: 1371
9: 1472 10: 1765 11: 3792 12: 1685 bogomips: 81468
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 08:00.0
Device-2: A4Tech REDRAGON Live Camera type: USB driver: uvcvideo
bus-ID: 3-2:2
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon gpu: amdgpu
resolution: 1920x1080~70Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Device-3: A4Tech REDRAGON Live Camera type: USB driver: uvcvideo
bus-ID: 3-2:2
Device-4: FIFINE Microphones K670 Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:3
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 201.18 GiB (45.0%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 58.76 GiB used: 31.88 GiB (54.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 196.9 MiB used: 274 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 379.8 GiB used: 169.3 GiB (44.6%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) file: /swapfile1
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1110
Processes: 350 Uptime: 57m Memory: 15.62 GiB used: 3.63 GiB (23.2%)
Init: systemd Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1422
Shell: Zsh v: 5.9 inxi: 3.3.16
