Gnome-control-center doesn't open anymore
Hi!
Since last Friday, I can’t open GNOME parameters. So I tried to launch it from the terminal, but that’s the output:
$ gnome-control-center
gnome-control-center: error while loading shared libraries: libaccountsservice.so.0: cannot open shared object file: No such file or directory
So I tried to make a full update (sudo pacman -Syyuu), but to no avail, as everything is up to date. Then I searched if a package was missing:
$ pacman -Ss libaccountsservice
extra/accountsservice 26.13.3-1 [installé]
    D-Bus interface for user account query and manipulation
I even tried with Pamac in case it was something on the AUR which was missing, but it’s the same thing:
$ pamac search libaccountsservice
accountsservice-git  23.13.9-2                                                         AUR
accountsservice  26.13.3-1 [Installés]                                               extra
(I note that there’s a problem with Pamac translation into French; it should say [Installé] and not [Installés] I think.)
Now I’m lost. Should I try to reinstall accountsservice? Something else?
Thank you!
Edit: I wanted to see if something changed if I reinstalled gnome-control-center, and that was the output:
$ sudo pacman -S gnome-control-center
[sudo] Mot de passe de XXX :
résolution des dépendances…
recherche des conflits entre paquets…
:: gnome-control-center - 50.1-1 et gnome-control-center-x11-scaling - 48.4-1 sont en conflit. Supprimer gnome-control-center-x11-scaling ? [o/N] N
So there’s a conflict between gnome-control-center and gnome-control-center-x11-scaling. Is that linked to my problem acccording to you?
Second edit: Sorry I forgot the system information:
  Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=09830b35-6574-4cd8-84b9-6323143a7e3c rw quiet
    udev.log_priority=3 acpi_osi=
    bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash apparmor=1
    security=apparmor
  Desktop: GNOME v: 50.1 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: light-locker,swayidle,swaylock dm:
    1: GDM v: 50.0 2: LightDM v: 1.32.0 note: stopped Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: TUXEDO product: InfinityBook Pro 15 v5 v: N/A
  Mobo: NB01 model: N150CU serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: INSYDE v: 1.07.08RTR1
    date: 05/27/2020
  ID-1: BAT0 charge: 45.9 Wh (100%) condition: 45.9/53.2 Wh (86.3%)
    volts: 17.11 min: 15.4 model: Notebook BAT type: Li-ion serial: <filter>
    charging: status: full control: start: 70% end: 80% type: standard
    cycles: N/A
  System RAM: total: 16 GiB available: 15.31 GiB used: 4.3 GiB (28.1%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471A1K43CB1-CTD serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 min: 1.35 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471A1K43CB1-CTD serial: <filter>
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 900 min/max: 400/4900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
    8: 900 bogomips: 36799
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK
    ports: active: DP-1,eDP-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:9b41 class-ID: 0300
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: Philips PHL 193V5 serial: <filter> built: 2017
    res: 1366x768 dpi: 85 gamma: 1.2 chroma: red: x: 0.643 y: 0.341 green:
    x: 0.314 y: 0.631 blue: x: 0.157 y: 0.051 white: x: 0.314 y: 0.329
    size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9
    modes: 1366x768, 1280x1024, 1280x720, 1024x768, 800x600, 640x480, 720x400
  Monitor-2: eDP-1 model: AU Optronics 0x20ed built: 2018 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.580 y: 0.345 green: x: 0.353 y: 0.573
    blue: x: 0.157 y: 0.129 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9b41 memory: 14.95 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo wl: swaymsg x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
  Device-2: GN Netcom Jabra Evolve2 30 driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:29
    chip-ID: 0b0e:0e31 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.18.26-1-MANJARO status: kernel-api
  Server-3: PipeWire v: 1.6.4 status: active (process)
    with: pipewire-media-session status: active tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 17.0-98-gb096 status: off with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 3b:00.1 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp59s0f1 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 3c:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp60s0 state: up mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.4:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp58s0u1u4 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0029
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: see --recommends
  Local Storage: total: 465.76 GiB used: 387.45 GiB (83.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-1: / raw-size: 457.26 GiB size: 449.01 GiB (98.20%)
    used: 387.45 GiB (86.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 09830b35-6574-4cd8-84b9-6323143a7e3c
    used: 148 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 3036-FD13
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 970cb365-cbbc-44f5-90a3-a942e89110c7
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:29 info: GN Netcom Jabra Evolve2 30 type: audio,HID
    driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Hub-2: 1-3:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
  Device-1: 1-3.1:6 info: Chicony KU-0420 keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 04f2:0403 class-ID: 0300
  Device-2: 1-3.2:7 info: Avago Pte. ADNS-5700 Optical Mouse Controller
    (3-button) type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 192f:0416 class-ID: 0301
  Hub-3: 1-3.3:8 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0801 class-ID: 0900
  Device-1: 1-3.3.2:9 info: GEMBIRD MicroSD Card Reader/Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 150mA
    chip-ID: 1908:0226 class-ID: 0806
  Device-2: 1-6:4 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 06cb:00a8 class-ID: ff00 serial: <filter>
  Device-3: 1-10:5 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 4-1:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 2109:0822
  Device-1: 4-1.3:10 info: Silicon Motion - Taiwan (formerly Feiya )
    type: N/A driver: N/A rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 chip-ID: 090c:3267 class-ID: 0000
  Device-2: 4-1.4:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  System Temperatures: cpu: 50.0 C pch: 43.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2397 pm: pacman pkgs: 2363 libs: 501
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 20 pm: snap pkgs: 14
    1: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    3: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 313
  1: cpu: 18.0% command: firefox pid: 8195 mem: 679.5 MiB (4.3%)
  2: cpu: 13.9% command: firefox pid: 30645 mem: 426.1 MiB (2.7%)
  3: cpu: 10.2% command: gnome-shell pid: 3062 mem: 309.0 MiB (1.9%)
  4: cpu: 2.5% command: firefox pid: 8431 mem: 305.8 MiB (1.9%)
  5: cpu: 1.9% command: firefox pid: 20652 mem: 533.2 MiB (3.4%)
  Memory top: 5 of 313
  1: mem: 679.5 MiB (4.3%) command: firefox pid: 8195 cpu: 18.0%
  2: mem: 533.2 MiB (3.4%) command: firefox pid: 20652 cpu: 1.9%
  3: mem: 426.1 MiB (2.7%) command: firefox pid: 30645 cpu: 13.9%
  4: mem: 378.2 MiB (2.4%) command: firefox pid: 19942 cpu: 1.4%
  5: mem: 351.2 MiB (2.2%) command: firefox pid: 8964 cpu: 1.0%
  Processes: 313 Power: uptime: 47m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.08 GiB services: gsd-power,upowerd
    Init: systemd v: 260 default: graphical tool: systemctl
  Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Bash (su) v: 5.3.9
    running-in: gnome-terminal inxi: 3.3.40
Hi @Emanuel
I am not a gnome user. But as far as I know gnome = wayland
When installing again go for gnome-control-center.
Choose o…
This did the trick! I always fear to break something when I remove something I did not directly install… but it was actually the conflict which was the origin of the problem. I just don’t understand why now and not sooner, but that won’t prevent me to sleep ^^.
Thanks!
Please only use the correct command to perform a sync/update:
sudo pacman -Syu
:point_up:
That’s what I do generally, but I read somewhere that a possible cause of my problem was a synchronization problem during an update, and that this command was a solution (it didn’t work).
By curiosity, what would be the risk using only -Syyuu?
If you look at the man page, you will see that a double y forces a download of the databases, even if your local copy of them is up-to-date — which puts an unnecessary extra load on the server — and that a double u allows for package downgrades, which you (normally) would not want. :backhand_index_pointing_down:
man pacman
Yes. You need to allow replacing gnome-control-center-x11-scaling with gnome-control-center. Also make sure to allow replacing mutter-x11-scaling with mutter if applicable. The X11 scaling packages no longer exist.
