Gnome-commander won't start
Recent gnome-commander won’t start. Attempting from terminal results in this error:
$ /usr/bin/gnome-commander
(gnome-commander:32594): GLib-GIO-ERROR **: 21:07:12.812: Settings schema ‘org.gnome.gnome-commander.plugins.general’ does not contain a key named ‘autoload’
Abgebrochen (Speicherabzug geschrieben) /usr/bin/gnome-commander
This is from stable.
Any hints please?
I’m not able to reproduce the issue with 2.03-1. It does indeed contain a key named autoload. What’s the output of:
gsettings get org.gnome.gnome-commander.plugins.general autoload
EDIT: In the future please preface commands with LC_ALL=C in order to paste the output in English here. If you wish to speak in German, feel free to post in Other Languages > Deutsch.
This is the output here:
$ LC_ALL=C gsettings get org.gnome.gnome-commander.plugins.general autoload
No such key ?autoload?
Do I need something from GNOME? Using XFCE desktop.
I just tested it on Xfce & Cinnamon with no issue as well. The key is empty by default anyway, so maybe try resetting it.
gsettings reset org.gnome.gnome-commander.plugins.general autoload
The default value appears as @as [] using the gsettings get command I posted above.
Resetting the key would not work:
$ LC_ALL=C gsettings reset org.gnome.gnome-commander.plugins.general autoload
Try reinstalling it which will also recompile the schema files.
Make sure you’re up to date first:
sudo pacman -Syu
Then reinstall it:
sudo pacman -S gnome-commander
Update and reinstall went through flawlessly, but the error remains.
I found that there was some file remaining from a git installation here:
/usr/local/share/glib-2.0/schemas
After deleting and reinstall the application starts again. In a fresh VM of Manjaro everything is okay.
Now I just have to find out why the applications menu is gone, but is is another issue.
Best regards for your hints!
steve1
FYI: Main menu of gnome-commander can be restored by pressing F12 :slight_smile: This may change with future versions…
Best regards
steve1
