Cheese says “There was an error playing video from the webcam”
I have already tried lowering the resolution but it doesn’t work.
I was able to make it work only by using sudo.
This problem persists even when I switch to xorg. As an alternative I used guvcview but it can not record video properly on wayland. It works fine on xorg though.
I am on the 5.15 kernel and the system is up to date. I didn’t have this problem using Cheese 3.38 version. Also, the flatpak version works properly probably because it’s not the latest version.
Is this an upstream problem or specific to my device?
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 41.3
Type: Laptop System: Dell product: Inspiron 5459 v: N/A serial: <superuser required>
Mobo: Dell model: 0F1J0W v: A00 serial: <superuser required> UEFI: Dell v: 1.9.0
date: 09/07/2020
ID-1: BAT0 charge: 29.0 Wh (100.0%) condition: 29.0/32.6 Wh (89.2%) volts: 16.7 min: 14.8
model: SMP DELL VN3N047 status: Full
Info: dual core model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake rev: 3 cache:
L1: 128 KiB L2: 512 KiB L3: 4 MiB
Speed (MHz): avg: 3046 high: 3085 min/max: 400/3100 cores: 1: 3038 2: 3059 3: 3002 4: 3085
bogomips: 20810
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
vendor: Dell driver: radeon v: kernel bus-ID: 01:00.0
Device-3: Microdia Integrated Webcam HD type: USB driver: uvcvideo bus-ID: 1-5:3
Display: x11 server: X.org 1.21.1.3 driver: loaded: ati,modesetting,radeon
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.45 running: yes
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel bus-ID: 02:00.0
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel
port: d000 bus-ID: 03:00.0
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: see --recommends
Local Storage: total: 931.51 GiB used: 437.85 GiB (47.0%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB
ID-1: / size: 83.11 GiB used: 23.14 GiB (27.8%) fs: ext4 dev: /dev/sda8
ID-2: /boot/efi size: 96 MiB used: 40.7 MiB (42.4%) fs: vfat dev: /dev/sda2
ID-3: /home size: 85.08 GiB used: 38.15 GiB (44.8%) fs: ext4 dev: /dev/sda10
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sda9
System Temperatures: cpu: 53.0 C pch: 46.0 C mobo: 45.0 C sodimm: SODIMM C gpu: radeon
temp: 51.0 C
Fan Speeds (RPM): cpu: 0
Processes: 265 Uptime: 1h 56m Memory: 7.66 GiB used: 3.03 GiB (39.6%) Init: systemd Compilers:
gcc: 11.1.0 Packages: 1439 Client: gnome-shell v: 41.3 inxi: 3.3.12
