Trying to use boxes to make a vm of fedora. It and fedora installed no issues but i get the following troubleshooting log when trying to actually launch a vm:
Broker URL: qemu+unix:///session
Domain: fedora33-wor
UUID: b6009279-08f4-4393-b26e-910b32e2a235
Persistent: yes
Cpu time: 0
Memory: 4152842 KiB
Max memory: 16387328 KiB
CPUs: 8
State: GVIR_DOMAIN_STATE_SHUTOFF
Domain config:
<domain type="qemu">
<name>fedora33-wor</name>
<uuid>b6009279-08f4-4393-b26e-910b32e2a235</uuid>
<title>Fedora 33 Workstation</title>
<metadata>
<boxes:gnome-boxes xmlns:boxes="https://wiki.gnome.org/Apps/Boxes">
<os-state>live</os-state>
<media-id>http://fedoraproject.org/fedora/33:0</media-id>
<media>/home/erin/Downloads/Fedora-Workstation-Live-x86_64-33-1.2.iso</media>
</boxes:gnome-boxes>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://fedoraproject.org/fedora/33"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">4152842</memory>
<currentMemory unit="KiB">4152842</currentMemory>
<vcpu placement="static">8</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-5.2">hvm</type>
<boot dev="cdrom"/>
<boot dev="hd"/>
<bootmenu enable="yes"/>
</os>
<features>
<acpi/>
<apic/>
</features>
<cpu mode="host-passthrough" check="none" migratable="on">
<topology sockets="1" dies="1" cores="8" threads="1"/>
</cpu>
<clock offset="utc">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>destroy</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2" cache="writeback" discard="unmap"/>
<source file="/home/erin/.local/share/gnome-boxes/images/fedora33-wor"/>
<target dev="vda" bus="virtio"/>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</disk>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="/home/erin/Downloads/Fedora-Workstation-Live-x86_64-33-1.2.iso" startupPolicy="mandatory"/>
<target dev="hdc" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="2"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<controller type="ccid" index="0">
<address type="usb" bus="0" port="1"/>
</controller>
<interface type="user">
<mac address="52:54:00:38:52:78"/>
<model type="virtio"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<smartcard mode="passthrough" type="spicevmc">
<address type="ccid" controller="0" slot="0"/>
</smartcard>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<channel type="spicevmc">
<target type="virtio" name="com.redhat.spice.0"/>
<address type="virtio-serial" controller="0" bus="0" port="1"/>
</channel>
<channel type="spiceport">
<source channel="org.spice-space.webdav.0"/>
<target type="virtio" name="org.spice-space.webdav.0"/>
<address type="virtio-serial" controller="0" bus="0" port="2"/>
</channel>
<input type="tablet" bus="usb">
<address type="usb" bus="0" port="2"/>
</input>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<graphics type="spice">
<listen type="none"/>
<image compression="off"/>
<gl enable="yes"/>
</graphics>
<sound model="ich9">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/>
</sound>
<video>
<model type="virtio" heads="1" primary="yes">
<acceleration accel3d="yes"/>
</model>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
</video>
<redirdev bus="usb" type="spicevmc">
<address type="usb" bus="0" port="3"/>
</redirdev>
<address type="usb" bus="0" port="4"/>
</redirdev>
<address type="usb" bus="0" port="5"/>
</redirdev>
<address type="usb" bus="0" port="6"/>
</redirdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</memballoon>
</devices>
</domain>
Any clues as to whats gone wrong would be greatly appreciated!
