After update Iβm trouble with gnome boxes. It stucks when I try to setup an image.
When I do -
journalctl -p 3 -xf
I get -
jun 16 09:38:53 fo-satellitel50c kernel: DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000008d800000-0x000000008fffffff], contact BIOS vendor for fixes
jun 16 09:38:53 fo-satellitel50c systemd[1]: Failed to start Setup Virtual Console.
jun 16 09:38:53 fo-satellitel50c systemd-vconsole-setup[254]: /usr/bin/loadkeys failed with exit status 1.
jun 16 09:39:05 fo-satellitel50c kernel:
jun 16 09:39:25 fo-satellitel50c gnome-session-binary[875]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
jun 16 09:40:40 fo-satellitel50c gdm-password][1145]: gkr-pam: unable to locate daemon control file
jun 16 09:41:02 fo-satellitel50c gdm-launch-environment][803]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
jun 16 09:41:44 fo-satellitel50c virtqemud[1753]: unsupported configuration: chardev 'spicevmc' not supported without spice graphics
jun 16 09:44:45 fo-satellitel50c kernel: ntfs3: Unknown parameter 'windows_names'
jun 16 09:45:15 fo-satellitel50c virtqemud[1753]: Unable to read from monitor: Connection reset by peer
jun 16 09:45:15 fo-satellitel50c virtqemud[1753]: internal error: qemu unexpectedly closed the monitor: ioctl(KVM_CREATE_VM) failed: 16 Device or resource busy
2022-06-16T08:45:15.715470Z qemu-system-x86_64: -accel kvm: failed to initialize kvm: Device or resource busy
jun 16 09:45:15 fo-satellitel50c virtqemud[1753]: internal error: process exited while connecting to monitor: ioctl(KVM_CREATE_VM) failed: 16 Device or resource busy
jun 16 09:45:39 fo-satellitel50c virtqemud[1753]: End of file while reading data: Input/output error
jun 16 09:46:10 fo-satellitel50c virtqemud[1753]: Unable to read from monitor: Connection reset by peer
jun 16 09:46:10 fo-satellitel50c virtqemud[1753]: internal error: qemu unexpectedly closed the monitor: ioctl(KVM_CREATE_VM) failed: 16 Device or resource busy
2022-06-16T08:46:10.018888Z qemu-system-x86_64: -accel kvm: failed to initialize kvm: Device or resource busy
jun 16 09:46:10 fo-satellitel50c virtqemud[1753]: internal error: process exited while connecting to monitor: ioctl(KVM_CREATE_VM) failed: 16 Device or resource busy
jun 16 09:46:32 fo-satellitel50c virtqemud[1753]: End of file while reading data: Input/output error
jun 16 09:49:14 fo-satellitel50c virtqemud[2975]: Unable to create KVM VM for TSC probing: Device or resource busy
jun 16 09:50:55 fo-satellitel50c virtqemud[2975]: Unable to read from monitor: Connection reset by peer
jun 16 09:50:55 fo-satellitel50c virtqemud[2975]: internal error: qemu unexpectedly closed the monitor: ioctl(KVM_CREATE_VM) failed: 16 Device or resource busy
2022-06-16T08:50:55.462101Z qemu-system-x86_64: -accel kvm: failed to initialize kvm: Device or resource busy
jun 16 09:50:55 fo-satellitel50c virtqemud[2975]: internal error: process exited while connecting to monitor: ioctl(KVM_CREATE_VM) failed: 16 Device or resource busy
jun 16 09:51:26 fo-satellitel50c virtqemud[2975]: End of file while reading data: Input/output error
jun 16 10:09:22 fo-satellitel50c virtlogd[3925]: Unable to open file: /home/fo/.cache/libvirt/qemu/log/manjaro-gnom.log: No such file or directory
jun 16 10:09:22 fo-satellitel50c virtqemud[3879]: Unable to open file: /home/fo/.cache/libvirt/qemu/log/manjaro-gnom.log: No such file or directory
jun 16 10:12:26 fo-satellitel50c virtqemud[3879]: Cannot recv data: Connection reset by peer
jun 16 10:13:14 fo-satellitel50c virtqemud[3879]: argument unsupported: QEMU guest agent is not configured
jun 16 10:14:59 fo-satellitel50c virtqemud[3879]: unsupported configuration: chardev 'spicevmc' not supported without spice graphics
jun 16 10:26:41 fo-satellitel50c virtqemud[3879]: unsupported configuration: chardev 'spicevmc' not supported without spice graphics
jun 16 10:27:29 fo-satellitel50c virtqemud[3879]: End of file while reading data: Input/output error
jun 16 10:29:42 fo-satellitel50c virtqemud[3879]: unsupported configuration: chardev 'spicevmc' not supported without spice graphics
jun 16 10:30:39 fo-satellitel50c virtqemud[3879]: End of file while reading data: Input/output error
jun 16 10:37:37 fo-satellitel50c virtqemud[6731]: unsupported configuration: Emulator '/usr/bin/qemu-system-x86_64' does not support virt type 'kvm'
jun 16 10:37:38 fo-satellitel50c virtqemud[6731]: unsupported configuration: Emulator '/usr/bin/qemu-system-x86_64' does not support virt type 'kvm'
jun 16 10:37:46 fo-satellitel50c virtqemud[6731]: Unable to create KVM VM for TSC probing: Device or resource busy
jun 16 10:37:47 fo-satellitel50c virtqemud[6731]: Unable to create KVM VM for TSC probing: Device or resource busy
jun 16 10:37:55 fo-satellitel50c virtqemud[6731]: unsupported configuration: chardev 'spicevmc' not supported without spice graphics
jun 16 10:38:40 fo-satellitel50c systemd[1163]: Failed to start Tracker metadata extractor.
ββ Subject: A start job for unit UNIT has failed
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit UNIT has finished with a failure.
ββ
ββ The job identifier is 795 and the job result is failed.
ββ
ββ
ββ The job identifier is 815 and the job result is failed.
jun 16 10:38:41 fo-satellitel50c systemd[1163]: Failed to start Tracker metadata extractor.
ββ
ββ
ββ The job identifier is 835 and the job result is failed.
ββ
ββ
ββ The job identifier is 855 and the job result is failed.
ββ
ββ
ββ The job identifier is 875 and the job result is failed.
ββ
ββ
ββ The job identifier is 895 and the job result is failed.
